How to stream IoT & telematics data to RabbitMQ or AMQP?
Sending telemetry data from flespi to RabbitMQ or other AMQP 0-9-1 Broker.
If you want to feed the telemetry data from flespi to the RabbitMQ broker, you can create a stream to any AMQP 0-9-1 Broker such as CloudAMQP following the steps below.
CloudAMQP automates the setup, operation, and scaling of RabbitMQ clusters and is available for all major cloud and application platforms worldwide.
1. Create an account in CloudAMQP
open cloudamqp
2. Create a New Instance
create new instance on cloudamqp
3. Click on the instance name
open cloudamqp instance configuration
4. Copy the broker URL for future reference
copy cloudamqp broker url
5. Go to the RabbitMQ Manager
open rabbitmq manager
6. Create a queue
create a queue in rabbitmq manager
7. Configure the stream in flespi
create flespi stream to cloudamqp
8. Subscribe the stream to the channel
subscribe flespi stream to channel
9. Check message delivery
If you see the "stream has sent messages" log records in the stream Logs & Messages tab, it means flespi started forwarding the data via the stream:
check flespi stream logs
And you should also see your messages coming to RabbitMQ:
check rabbitmq queue status
Learn how to scale your MQTT data processing with flespi's shared subscriptions
Sending telemetry data from flespi to SENT-GEO
