Geotab-feed protocol
Fetch telemetry vehicle data from the MyGeotab fleet management platform via Data Feed API.
flespi parses the Geotab-feed protocol messages into a JSON object with the fields listed below in the Parameters tab.
Protocol used to fetch continuously synchronized telemetry vehicle data from the MyGeotab fleet management platform via Data Feed API.
To create a channel you need to obtain database name, username and password from your Geotab manager and ask to enable MyGeotab Data Feed via API for your account.
Unsupported data points may appear as warnings in the channel logs, please contact flespi team to upgrade the integration.
DiagnosticAccelerometerCalibratedId
accident.event
Accident event detected
DiagnosticAccidentDataUploadEventId
Generic distance to forward vehicle (alpG8aRLN3UKxR4dSaDdwcQ)
adas.headway.measurement
Time headway to the vehicle ahead measured by ADAS
GO ADAS headway measurement (aLGhLYrdjJECpZicjN3maSg)
DiagnosticFuelAlcoholCompositionId
alternator.ignition.off.alarm
Alternator voltage detected while vehicle ignition is off
Alternator voltage detected while vehicle ignition off (auwkbEMRgik6GtINx8EotVA)
battery.cranking.voltage
Minimum battery level during cranking
DiagnosticCrankingVoltageId
can.abs.active.status
ABS active status read from CAN
Generic ABS active (aG3QE28EtpUSvjLEUXAGLKw)
can.abs.indicator.status
DiagnosticAbsWarningLightId
Accelerator pedal position (a8E-MlXuWg0-3oH2dO424Qw)
DiagnosticOutsideTemperatureId
can.asr.status
DiagnosticTractionControlSystemEnabledId
can.awd.status
4WD engaged (agZZT2jBQrUOVC-B3JOUxcA)
Barometric pressure (anhSofTlT20ayntgV7IvW8A)
can.carb.passthrough
CARB (California Air Resources Board) emissions data passthrough state code
Passthrough Carb (aVVhkvxM34U6-4caL3hDQmg)
DiagnosticEngineWarningLightId
DiagnosticCruiseControlActiveId
can.dpf.regeneration.force.status
DPF forced regeneration switch status read from CAN
Generic DPF filter regen force switch (aXfHYX0HFtUaOOr_scNuSsg)
can.dpf.regeneration.inhibit.status
DPF regeneration inhibit status read from CAN
Generic AFT regen inhibit switch (aoQsV7O16ykqeR_r1f_hf1A)
DiagnosticGearPositionId
can.driver.door.status
Driver door open (aJOz9RKIf50OSZYemH1u34Q)
DiagnosticDriverSeatbeltId
Time since codes cleared (aQ5YJk_z_KkWFL_69xOZ-Vg)
Distance traveled since codes cleared (aKpyOK5cMZkmSE_isEqk8iA)
Warmups since codes cleared (a6KUdqGiXdEGGVJ6tgfmagQ)
DiagnosticEngineCoolantTemperatureId
can.engine.data.status
Engine CAN data feed is active
DiagnosticEngineDataActiveId
DiagnosticEngineHotWarningLightId
can.engine.misfire.status
Engine misfire condition confirmed status, read from CAN
Misfire condition confirmed (aGKYO7DMo3kmQrZFqX0-S8A)
DiagnosticRawEngineHoursId,
Raw engine hours (aXXPbOfGzWke4CYTL3RkHjg)
DiagnosticEngineOilLifeRemainingId
DiagnosticOilPressureId
can.engine.oil.service.status
Engine oil service status
DiagnosticOilChangeDueWarningLightId
DiagnosticEngineOilTemperatureID
can.engine.remote.start.status
Engine running due to the vehicle remote starter, read from CAN
DiagnosticEngineRunningDueToVehicleRemoteStarterId
DiagnosticEngineSpeedId
can.engine.start.disabled.indicator.status
Engine starting disabled indicator status, read from CAN
DiagnosticEngineStartingDisabledWarningLightId
HV battery current (aoceAsl774UaFnkAEklMajw)
High voltage battery actual state of charge (a-wr5fUdd8kuQvAvhiTOR7g)
Battery maximum cell temperature (agwqfZ6T8TEWBHU_ITGMlEw)
Battery minimum cell temperature (abc1Y3KfBkkKISu6DuGj1ZA)
DiagnosticBatteryTemperatureId
HV battery voltage (a4kUpYGyQ4E2uoQTp-ed0Ow)
Electric vehicle on-board charger AC input current (amTN4ovXneUuMHWk2FIgOdA)
can.ev.evse1.ac.energy
EVSE1 AC energy delivered to the on-board charger, read from CAN
DiagnosticTotalLifetimeOnBoardChargerEnergyInDuringACChargingInId
can.ev.evse1.ac.power
EVSE1 AC input power of the on-board charger, read from CAN
DiagnosticOnBoardChargerACInputPowerId
DiagnosticOnBoardChargerAcInputVoltageId
Front left-side door open (axLpaB5ZgD0mTQTdIzwkCKQ)
DiagnosticPassengerSeatbeltViolationId
DiagnosticPassengerOccupancyId
Front right-side door open (aVb1jNIGRJkCpTE5HqUsTUQ)
can.front.tire.placard.pressure
Recommended front tire pressure from the vehicle placard, read from CAN
Placard pressure - front (a8OOTd0phr0uY5KlFnoVuNA)
can.fuel.cap.indicator.status
Check fuel filler cap indicator status, read from CAN
DiagnosticEngineCheckFuelFillerCapWarningLightId
DiagnosticTotalFuelUsedId
can.fuel.filter.life
Remaining useful life of the fuel filter, read from CAN
DiagnosticFuelFilterLifeRemainingId
DiagnosticChangeFuelFilterWarningLightId
can.fuel.tank.capacity
Fuel tank capacity read from CAN
DiagnosticFuelTankCapacityId
DiagnosticFuelUnitsId
Hazard light status (aTmO5Yw_INUyk56qFp2SuZQ)
High beam light status (aOaUh5oFl-UCs2Qvlw9v4SQ)
can.idle.fuel.consumed
DiagnosticDeviceTotalIdleFuelId
DiagnosticCabInteriorTemperatureId
can.left.front.tire.pressure
DiagnosticTirePressureFrontLeftId
Front left tire pressure status (a20Pk9DZrz0Km9Rypxd2pkQ)
can.left.rear.tire.pressure
DiagnosticTirePressureRearLeftId
Rear left tire pressure status (aZOFr-XzNXE2_DkqN7fvtUg)
DiagnosticLeftTurnSignalId
Distance remaining until service required (aR9J8CsZtQ022141NHJSdtA)
Distance traveled with MIL on (ak0pLOA92RkSyQDvovh8Afg)
Time since Malfunction Indicator Lamp (MIL) turned on (aJZBOgP_o_0yhyyIsmF8Nyw)
DiagnosticOilLevelLowWarningLightId
DiagnosticOilLightOnId
Distance remaining until oil change required (aiC9tvNgojEC_9iFVc6rYew)
Time remaining until oil change required (a1wxeXdKZRE2f-xo1pERsgQ)
DiagnosticParkingBrakeId
can.passenger.door.status
Passenger door open (aI7zmF_XrH0GOVvlNJIsj0w)
DiagnosticPowerTakeoffEngagedId
Total lifetime engine PTO governor fuel used (a2rHqVdNQwE-4aUqv3Nt2vg)
PTO governor state (a9NB5YZ5w60OIet7Vy5YREw)
DiagnosticLeftRearDoorOpenId
DiagnosticSecondRowLeftSeatbeltId
DiagnosticRightRearDoorOpenId
DiagnosticSecondRowRightSeatbeltId
can.rear.tire.placard.pressure
Recommended rear tire pressure from the vehicle placard, read from CAN
Placard pressure - rear (aNZ5WhnlLwEqJV3kZtiYDJg)
can.right.front.tire.pressure
DiagnosticTirePressureFrontRightId
Front right tire pressure status (ajcO-zRd750Cb29ZUcyh5XQ)
can.right.rear.tire.pressure
DiagnosticTirePressureRearRightId
Rear right tire pressure status (asibym4qhrkSYRvebiOvHXw)
DiagnosticRightTurnSignalId
Time remaining until service required (aybl8B7xQt0yrRkcSZSq0vw)
DiagnosticChangeCleanExhaustFilterWarningLightId
can.tpms.indicator.status
DiagnosticTireWarningLightId
Trailer attachment detected (atOWK6u_59km8YoRjQTbvgw)
can.transmission.oil.service.status
Transmission oil change required status, read from CAN
DiagnosticTransmissionOilChangeWarningLightId
DiagnosticEngineTransmissionOilTemperatureId
Check transmission lamp (a5ka7L36ML0Cl8vPT6J-Xhw)
can.vehicle.battery.charge.type
Vehicle battery charging type (e.g. quick), detected from CAN
DiagnosticElectricVehicleChargingStateId
DiagnosticElectricVehicleChargingStateId,
Hybrid / electric vehicle charging status (a9jsWRHbl1UihOYDNx7kpxA)
can.vehicle.battery.energy
Vehicle battery current stored energy, read from CAN
Electric vehicle battery charge remaining (aY90Ek5CMxkGFJSNmlZDuHA)
DiagnosticElectricEnergyInId
can.vehicle.battery.energy.recuperated.idle
Energy into the vehicle battery while idling, read from CAN
DiagnosticTotalLifetimeEnergyInWhileIdlingId
Generic EV battery state of health (aiC3laRAhVEOzOSvicbN9og)
DiagnosticStateOfChargeId
DiagnosticElectricVehicleBatteryPowerId
Electric vehicle distance remaining (aFGR6Q9guoUeiaAZI1fD6oQ)
can.vehicle.energy.ac.charged
Total electric energy charged from AC chargers read from CAN
DiagnosticTotalLifetimeBatteryEnergyInDuringACChargingId
can.vehicle.energy.dc.charged
Total electric energy charged (system DC) read from CAN
DiagnosticTotalLifetimeBatteryEnergyInDuringDCChargingId
can.vehicle.energy.driving.consumed
The electric energy the vehicle has consumed while driving
DiagnosticElectricEnergyOutId
DiagnosticTotalLifetimeEnergyOutWhileIdlingId
DiagnosticRawOdometerId
Generic distance remaining (a2_fnVeTUEEKcl6GoX-8pxw)
DiagnosticEngineRoadSpeedId
Wash fluid level low (arxh26O-_AUa-5a5h46T75g)
DiagnosticWaterDetectedInFuelWarningLightId
Windshield wipers on (aHI_G0yzIvEWYLDRM9VEKIA)
cargo.door.open.status
Cargo door open status
Cargo door open (axr6AvdhETUa80GLwKmBoJA)
continuous.connection.status
Always-on cellular connection feature is active
Continuous Connect status (aUcx6anGZUEqcyg7N4BdbWQ)
DiagnosticCruiseControlEnabledId
deviceType
DiagnosticAux1Id-DiagnosticAux8Id
DiagnosticIgnitionId
engine.limp.mode
Engine limp mode status
DiagnosticEngineOperatingInReducedPowerModeWarningLightId
DiagnosticEngineHoursAdjustmentId,
DiagnosticEngineHoursId
DiagnosticGpsLogReasonId
DiagnosticDevicePowerChangeId
DiagnosticGoDeviceVoltageId
DiagnosticDeviceTotalFuelId
DiagnosticFuelLevelId
fuel.sensor.input.status
Fuel level sensor digital input state
Fuel tap harness digital input (aBxEbMBH7yEi23qzJ4HUAzw)
fuel.sensor.input.voltage
Voltage on the fuel level sensor input
Fuel tap harness analog input (aMahgo0xe60CReIGKZiSeig)
gnss.acceleration
GNSS-derived longitudinal acceleration
GPS-based longitudinal acceleration (aLLFcKEg5sEiugRoQQhZVVg)
DiagnosticPositionValidAtDeviceId
gnss.snr
dB
GNSS signal-to-noise ratio
Strongest satellite signal carrier-to-noise ratio (aFzVpeQqXskGNRmG8avPJ9Q)
Cellular modem signal strength (a4Cq3dWtCV0yoo9j_v__LbQ)
harness.9pin.status
9-pin diagnostic harness detected
DiagnosticHarnessDetected9PinId
harness.standard.status
Standard wiring harness detected
DiagnosticStandardHarnessDetectedId
harness.type.enum
Detected wiring harness type code
Intelligent harness type detected (aTWDkdT3qWEy_M_tENiZcdg)
Headlight light status (aeHlGnnVb-0GrzZcQsYhDug)
DiagnosticVehicleActiveId
modem.type.enum
Modem type
Cellular modem radio access technology (aV90hCq8zakusGKE1UsfXrw)
Altitude above mean sea level (aZ_PCPTFQJUWGgwTodd5nhA)
latitude
longitude
GNSS tracked satellite count (aAjxil0OkYUO72Ydmz5AVog)
position.satellites.visible
Satellites visible to the GPS module (ajfqpJjtowEy9j99LTeB2Gg)
speed
DiagnosticPositionValidId
dateTime
DiagnosticTotalTripFuelUsedId,
Trip fuel accumulator (a1bdu70JvqkqH3ehkxExuQQ)
trip.idle.fuel.consumed
Trip idle fuel consumption
DiagnosticTotalTripIdleFuelUsedId,
Trip idle fuel accumulation (aPqUDFT7gCk2FNzDI7y9PtQ)
Trip distance with tracked fuel (aJ-_7bPdOC0mtST7tnb6iwQ),
Trip distance with tracked fuel accumulator (aWkAeN_3MXUuNWbGmZ6a7xA)
DiagnosticJ1939CanEngineProtocolDetectedId
vehicle.data.contract.active
Vehicle data contract is active
Generic vehicle data contract active (anjw6IIGoRU2ZHeUKGlekpg)
DiagnosticOdometerAdjustmentId,
DiagnosticOdometerId
vehicle.name
Vehicle name
name
DiagnosticVehicleClassId
vehicleIdentificationNumber
vehicle.workshop.status
Vehicle is in workshop service mode
Generic workshop mode enabled (aywyV_zbhvUajpnTQf0Dz8A)
vehicle.workshop.suspected.status
Vehicle is suspected to be in a workshop
Suspected vehicle in workshop (aqPuvPon7lEWU-qWASIlSCA)
DiagnosticAccelerationForwardBrakingId
DiagnosticAccelerationSideToSideId
DiagnosticAccelerationUpDownId
