axle.weight
Axle weigth
getTemperatureDataForVehicles/axle_load_sum
getTemperatureDataForVehicles/ignitionStatus
getTemperatureDataForVehicles/ambientTemperature
freezer.alarm.code
Transport Refrigeration Unit alarm code
getTemperatureDataForVehicles/alarmCode
freezer.alarm.description
Transport Refrigeration Unit alarm description
getTemperatureDataForVehicles/alarmDescription
freezer.alarm.response
Transport Refrigeration Unit alarm response type (e.g. Shut Down)
getTemperatureDataForVehicles/alarmRecommendation
getTemperatureDataForVehicles/voltage
getTemperatureDataForVehicles/doorStatus
getTemperatureDataForVehicles/electricalHours
freezer.engine.rpm
Freezer engine RPM
getTemperatureDataForVehicles/engineRpm
getTemperatureDataForVehicles/engineHours
getTemperatureDataForVehicles/fuelLevel
freezer.id
Unique identifier of the asset
getTemperatureDataForVehicles/externalId
freezer.maindoor.status
TRUE = main door switch detected door was open FALSE = main door switch detected door was closed
getTemperatureDataForVehicles/doorOpen
freezer.name
Asset name
getTemperatureDataForVehicles/vehicleName
freezer.operating.mode
Freezer operating mode
getTemperatureDataForVehicles/unitModeDetail
freezer.power.source
Power Source
getTemperatureDataForVehicles/powerSource
freezer.power.status
Power Status
getTemperatureDataForVehicles/powerOn
freezer.serial.number
Asset serial number
getTemperatureDataForVehicles/reeferSerialNumber
freezer.switch1.status
TRUE = remote door switch 1 detected door was open FALSE = remote door switch 1 detected door was closed
getTemperatureDataForVehicles/zone1DoorOpen
freezer.switch2.status
TRUE = remote door switch 2 detected door was open FALSE = remote door switch 2 detected door was closed
getTemperatureDataForVehicles/zone2DoorOpen
freezer.switch3.status
TRUE = remote door switch 3 detected door was open FALSE = remote door switch 3 detected door was closed
getTemperatureDataForVehicles/zone3DoorOpen
getTemperatureDataForVehicles/totalHours
getTemperatureDataForVehicles/operatingMode1
getTemperatureDataForVehicles/returnAir1
getTemperatureDataForVehicles/dischargeAir1
getTemperatureDataForVehicles/setPoint1
getTemperatureDataForVehicles/operatingMode2
getTemperatureDataForVehicles/returnAir2
getTemperatureDataForVehicles/dischargeAir2
getTemperatureDataForVehicles/setPoint2
getTemperatureDataForVehicles/operatingMode3
getTemperatureDataForVehicles/returnAir3
getTemperatureDataForVehicles/dischargeAir3
getTemperatureDataForVehicles/setPoint3
geofence.name
Geofence name
getTemperatureDataForVehicles/geoFenceName
getTemperatureDataForVehicles/geoAccessTypeDescription
inside.vehicle.humidity
Humidity sensor inside vehicle value, i.e. relative air humidity level
getTemperatureDataForVehicles/humidity
getTemperatureDataForVehicles/stationary
position.address
Location Address
getTemperatureDataForVehicles/locationDescription
getTemperatureDataForVehicles/latitude
getTemperatureDataForVehicles/longitude
getTemperatureDataForVehicles/speed
getTemperatureDataForVehicles/latitude,
sensor.temperature.1
From getTemperatureDataForVehicles/indSensor1
sensor.temperature.2
From getTemperatureDataForVehicles/indSensor2
sensor.temperature.3
From getTemperatureDataForVehicles/indSensor3
sensor.temperature.4
From getTemperatureDataForVehicles/indSensor4
sensor.temperature.5
From getTemperatureDataForVehicles/indSensor5
sensor.temperature.6
From getTemperatureDataForVehicles/indSensor6
getTemperatureDataForVehicles/wheel_tyre_pressure
getTemperatureDataForVehicles/tyrePressureDetection
trailer.couple.status
Trailer coupled/decoupled status
getTemperatureDataForVehicles/is_coupled
trailer.vin
Trailer VIN
getTemperatureDataForVehicles/trailer_VIN
getTemperatureDataForVehicles/odometer
getTemperatureDataForVehicles/truck_VIN
