Wialon-retranslator protocol
Special protocol by Gurtam allowing retranslation of messages from multiple devices between Wialon servers within a single TCP connection​.
flespi parses the Wialon-retranslator protocol messages into a JSON object with the fields listed below in the Parameters tab.
Wialon Retranslator is a universal protocol supported by devices of multiple manufacturers. The protocol is designed by Gurtam for quick message retranslation from multiple devices between Wialon servers within a single TCP connection.
See protocol specification here.
Note for transmitting data from Wialon to flespi:
In order to transfer object sensors as parameters to the flespi, several conditions have to be met:
1. On the Wialon side it is necessary to use the "wialon_v2" protocol.
2. Enable option "Attach sensors" (In the settings of the retranslator)
3. All sensors should have name according to follow format: only lower case for Latin letters from a to z. Numbers from 0 to 9. The symbol _ can be used. Example: sensor_name - is fully valid.
P.S: This is not a limitation of flespi, these are mandatory requirements of the retranslator on the Wialon side.
Block 'accelerometer'
absolute.deceleration
Block 'accel_res'
Block 'alarm trigger'
Block 'impulse fuel consumption',
Block 'instant fuel consumption'
Block 'battery'
Block 'pwr_int'
Block 'axis_weight'
Block 'cool_temp'
Block 'engine_temp'
Block 'fuel_volume'
Block 'avl_inputs'
Block 'avl_outputs'
engine.efficiency
Engine efficiency sensor
Block 'engine efficiency'
Block 'engine operation',
Block 'ign'
Block 'engine hours',
Block 'engine_hours'
engine.oil.pressure
Engine oil pressure
Block 'oil_pressure'
Block 'engine rpm',
Block 'engine_rpm'
Block 'pwr_ext',
Block 'voltage'
Block 'absolute fuel consumption',
Block 'fuel_consumption'
Block 'fuel_level'
Block 'fuel level impulse sensor',
Block 'fuel level'
Block 'cell_id',
Block 'gsm_cell'
Block 'lac'
Block 'mcc'
Block 'mnc'
Block 'hw_cfg_in_roaming'
Block 'gsm'
Block 'avl_driver',
Block 'ibutton'
Block 'real-time motion sensor'
Block 'posinfo'
Block 'posinfo'
Block 'hdop'
Block 'posinfo'
Block 'posinfo'
Block 'posinfo'
Block 'posinfo'
Block 'private mode'
Block 'hw_cfg_protocol_version'
Block 'temperature'
Block 'taho_speed'
touch.memory.id
Touch Memory Key ID
Block 'touch_key'
Block 'relative engine hours'
Block 'odometer'
Block 'mileage'
Block 'accel_x'
Block 'accel_y'
Block 'accel_z'
