Gosuncn GD201E
GD201E is a plug-and-play OBDII dongle featuring Cellular LPWA (LTE-M/NB-IoT), GNSS, G-sensor, 3-axis gyro, and Bluetooth 5.2. It supports real-time tracking, trip logging, driving behavior analysis and judgment, vehicle fault diagnosis (DTC), and alarm notifications. Ideal for connected-car and fleet applications, it delivers reliable connectivity, precise positioning, and easy in-vehicle installation.
Parameters (151)
Gosuncn GD201E
Flespi parses telemetry data from your Gosuncn GD201E into a standardized JSON and lets you send commands to Gosuncn GD201E via API.
    "device.type.id": "Gosuncn GD201E",
    "protocol.id": "gosuncn"
Data type major 0x04
Configurable data flow key 1019 of Data type major 0x03,
Configurable data flow key 1043 of Data type major 0x03,
Configurable data flow key 1041 of Data type major 0x03,
Configurable data flow key 1009 of Data type major 0x03,
Configurable data flow key 1035 of Data type major 0x03,
can.clutch.slip
Configurable data flow key 1050 of Data type major 0x03,
Configurable data flow key 1011 of Data type major 0x03,
can.driver.door.status
Configurable data flow key 1044 of Data type major 0x03
Configurable data flow key 1016 of Data type major 0x03,
Configurable data flow key 1054 of Data type major 0x03
Configurable data flow key 1003 of Data type major 0x03,
Configurable data flow key 1005 of Data type major 0x03,
Configurable data flow key 1031 of Data type major 0x03
Configurable data flow key 1001 of Data type major 0x03,
Configurable data flow key 1040 of Data type major 0x03,
Data type major 0x00,
Configurable data flow key 1039 of Data type major 0x03
Configurable data flow key 1010 of Data type major 0x03,
can.fuel.level.2
Configurable data flow key 1055 of Data type major 0x03
Configurable data flow key 1029 of Data type major 0x03,
Configurable data flow key 1034 of Data type major 0x03
Configurable data flow key 1051 of Data type major 0x03,
Configurable data flow key 1037 of Data type major 0x03
Configurable data flow key 1008 of Data type major 0x03,
Configurable data flow key 1007 of Data type major 0x03,
Configurable data flow key 1030 of Data type major 0x03,
Configurable data flow key 1032 of Data type major 0x03,
Configurable data flow key 1033 of Data type major 0x03
Configurable data flow key 1006 of Data type major 0x03,
Configurable data flow key 1027 of Data type major 0x03,
Configurable data flow key 1012 of Data type major 0x03,
can.passenger.door.status
Configurable data flow key 1045 of Data type major 0x03
Configurable data flow key 1046 of Data type major 0x03
Configurable data flow key 1047 of Data type major 0x03
Configurable data flow key 1052 of Data type major 0x03,
Configurable data flow key 1053 of Data type major 0x03
Configurable data flow key 1036 of Data type major 0x03
Configurable data flow key 1004 of Data type major 0x03,
Configurable data flow key 1028 of Data type major 0x03,
Configurable data flow key 1048 of Data type major 0x03
Configurable data flow key 1042 of Data type major 0x03
Configurable data flow key 1024 of Data type major 0x03,
Configurable data flow key 1022 of Data type major 0x03,
Configurable data flow key 1021 of Data type major 0x03,
Configurable data flow key 1020 of Data type major 0x03,
Configurable data flow key 1026 of Data type major 0x03,
Configurable data flow key 1023 of Data type major 0x03,
Configurable data flow key 1025 of Data type major 0x03,
Configurable data flow key 1002 of Data type major 0x03,
Data type major 0x05
ecu.hardware.version
ECU hardware version
engine.oil.pressure
Engine oil pressure
Configurable data flow key 1038 of Data type major 0x03,
Data type major 0x01,
Data type major 0x04,
fota.state
FOTA status
Configurable data flow key 1014 of Data type major 0x03
gps.module.version
GPS module version
Data type major 0x02
Data type major 0x02,
gsm.network.name
message.seqnum
message.type.enum
Message Type
power.off.timestamp
Power off time
report.interval.time
Report interval time
Configurable data flow key 1013 of Data type major 0x03,
total.trip.mileage
Total trip mileage
trip.harsh.braking.number
trip.harsh.cornering.number
trip.idle.fuel.consumed
Trip idle fuel consumption
trip.start.altitude
Trip start altitude
trip.start.direction
Trip start direction
trip.start.satellites
trip.start.speed
Speed at the start of the trip
trip.stop.altitude
Trip stop altitude
trip.stop.direction
Trip stop direction
trip.stop.satellites
trip.stop.speed
Speed at the end of the trip
wifi.channel
WiFi channel number
