Omnicomm Light
Omnicomm Light is a basic GPS/GLONASS tracking device suitable for commercial vehicles monitoring. The device features 2 universal inputs and 1 output, CAN, RS-485, built-in accelerometer, 650 mAh backup battery, external antennas and more.
Parameters (94)
Omnicomm Light
Flespi parses telemetry data from your Omnicomm Light into a standardized JSON and lets you send commands to Omnicomm Light via API.
    "device.type.id": "Omnicomm Light",
    "protocol.id": "omnicomm"
accelerometer.state
Accelerometer calibration state 0 - n/a, 1 - is calibrating, 2 - calibrated, 3 - axis detection error
accelleration.threshold
Safe driving acceleration threshold
braking.threshold
Safe driving braking threshold
can.axis.index
Axis index read from CAN
can.daily.fuel.consumption
Daily fuel consumtion read from CAN
can.daily.vehicle.mileage
Daily vehicle mileage read from CAN
can.doors.state
Doors state read from CAN
can.engine.fuel.rate.count
The number of fuel rate values read from CAN used to calculate mean engine fuel rate
can.pedal.clutch.level
Clutch pedal level read from CAN
can.spn.id
CAN SPN ID
can.spn.value
CAN SPN value
device.tamper.status
external.powersource.level
lateral.accelleration.threshold
Safe driving lateral acceleration threshold
motorhours.counter
Motorhours calculated with coefficient applied
onboard.equipment.id
The ID of the onboard equipment
passengers.in.count
passengers.out.count
passengers.sensor.mask
Passengers sensor doors bitmask
rpm.threshold
Safe driving rpm threshold
safe.driving.bitmask
Safe driving event cause bitmask, bit0 - speed, bit1 - rpm, bit2 - acceleration, bit3 - lateral acceleration, bit4 - braking, bit5 - vertical acceleration
speed.threshold
Safe driving speed threshold
vehicle.speed
Vehicle speed
vertical.accelleration.threshold
Safe driving vertical acceleration threshold
wifi.signal.level
WiFi signal level, percentage
