How to fill missing message parameters with telemetry values?
Using plugins to add cached telemetry values in place of missing device message parameters.
The "item-telemetry" plugin type is used to add missing message parameters by taking their values from cached device telemetry.
Note: similar functionality but with more flexible configuration is offered by a dedicated pipe-cache-params channel.
Let's define a new plugin that will add certain CAN parameters that are missing from the message:
add plugin of item telemetry type
assign plugin to flespi device
And then you should be able to see the new calculated field in the new device messages. Go to the Logs & Messages tab for the given device to check:
missing parameter in device messages
Done.
Change log
Subscribe to the telemetry plugin change log to stay in sync with any updates.
More plugin types
Using a webhook plugin to make requests to the script on your custom server to modify messages.
Manually posting messages into a flespi device.
