How to stream IoT & telematics data to GpsGate?
Sending telemetry data from flespi to the GpsGate tracking system.
GpsGate is a real-time fleet tracking platform suitable for a wide range of telematics applications.
Following is the guide on how to send telemetry data from flespi to GpsGate.
1. Create a device in GpsGate
Follow this guide to create a new device in GpsGate.
2. Configure a stream in flespi
When in the flespi panel, navigate to Telematics hub -> Streams -> "+" to add a new stream
Pick gpsgate from the protocol_id drop-down.
In the URI field of the configuration specify the proper host and port of the Gpsgate server:
create gpsgate stream
3. Subscribe the stream to the device
  • Once the stream is created, click on it to open settings.
  • Navigate to the Devices tab.
  • Click the green "+" button to pick the device(s) to forward the data from.
assign devices to gpsgate stream
4. Check message delivery
If you see the “stream has sent messages” log records in the stream Logs tab, it means flespi started forwarding the data via the stream:
gpsgate stream logs
And you should now see your messages in the GpsGate platform.
Change log
To stay in sync with all improvements and changes to the GpsGate stream, subscribe to the change log on the forum.
Give your flespi AI agent a Traccar token: devices, users, geofences and reports handled on your behalf, live alerts in the chat, and diagnosis across flespi and Traccar
Give your flespi AI agent an Onomondo API key: SIM states, network logs, data limits and webhooks acted on for you, alerts and a live SIM dashboard for your team
