How to stream IoT & telematics data to GPSWOX?
Sending telemetry data from flespi to the GPSWOX tracking system.
GPSWOX is a powerful online GPS tracking software and fleet management system If you want to feed the telemetry data from flespi to GPSWOX, follow the steps below.
1. Create a unit in GPSWOX
  • Follow this guide to add a new device. The most important part here is to specify the same Device IMEI that your device connected to flespi has.
2. Configure stream in flespi
  • When in the flespi panel, navigate to Telematics hub -> Streams -> "+" to add a new stream
  • Protocol_id — gpswox
  • The Host and Port values will be populated automatically once you pick the proper GPSWOX datacenter location in the configuration dropdown.
create flespi stream gpswox
3. Subscribe the stream to the channel
  • Once the stream is created, click on it to open settings.
  • Navigate to the Channels tab (or Devices tab if you want to forward data from specific devices only).
  • Click the green '+' button to pick the channel (or device) to instruct the stream to forward data from it.
subscribe flespi stream gpswox to channel
4. Check message delivery
If you see the “stream has sent messages” log records in the stream Toolbox tab, it means flespi started forwarding the data via the stream:
flespi stream gpswox toolbox
And you should now see your messages in the GPSWOX system.
Change log
To stay in sync with all improvements and changes to the GPSWOX stream, subscribe to the change log on the forum.
Give your flespi AI agent a Traccar token: devices, users, geofences and reports handled on your behalf, live alerts in the chat, and diagnosis across flespi and Traccar
Give your flespi AI agent an Onomondo API key: SIM states, network logs, data limits and webhooks acted on for you, alerts and a live SIM dashboard for your team
