How to stream IoT & telematics data to Pulsar broker
Sending telemetry data from flespi to Pulsar Broker
If you want to feed the telemetry data from flespi to the Pulsar broker, you can create a stream following the steps below.
Pulsar is a multi-tenant, high-performance solution for server-to-server messaging. Originally developed by Yahoo, Pulsar is under the stewardship of the Apache Software Foundation.
1. Configure the stream in flespi
    Navigate to the Telematics Hub tab, then select Streams, and click on the "+" icon located at the bottom right corner. Fill out the stream configuration.
2. Subscribe the stream to the channel or device
    Navigate to the Channels or Devices tab, depending on whether you want to relay data from a specific device or from all devices within a channel. Click on the "+" icon located at the bottom right corner and add the desired items.
3. Check message delivery
    Navigate to the Logs tab. If you see the "stream has sent messages" log records, it means flespi started forwarding the data via the stream:
Change log
To stay in sync with all improvements and changes to the Pulsar stream, subscribe to the change log on the forum.
Sending telemetry data from flespi to SENT-GEO
