How to add address resolved by Google reverse geocoding into the message?
Using plugins to resolve position coordinates into address using Google reverse geocoding API and add it into the device messages.
The "google-reverse-geocoding" plugin type is used to apply Google reverse geocoding functionality to resolve position coordinates into the specific address.
Important: you need to have a Google Geocoding API key to make the plugin work.
Let's define a new plugin to resolve coordinates into addresses. Specify the required plugin type in the Type id field, fill in the API Key configuration fields. You can also specify which address components to add to the output parameter (Address Components field) and whether to add a prefix with the service name to each parameter (Parameter naming name field).
assign google reverse geocoding plugin
And then you should be able to see the address fields in the new device messages. Go to the Logs & Messages tab for the given device to check:
check address added by google reverse geocoding plugin
Done.
  • We cannot guarantee the performance or stability of the third-party systems involved in the process — in case of their service interruptions flespi will not be able to save messages to devices and will respond with negative ACK and will also terminate the connection if the required flag is set.
Change log
Subscribe to the Google reverse geocoding plugin change log to stay in sync with any updates.
More plugin types
