How to add address resolved by Here reverse geocoding into the message?
Using plugins to resolve position coordinates into address using Here reverse geocoding API and add it into the device messages.
The "here-reverse-geocoding" plugin type is used to apply Here reverse geocoding functionality to resolve position coordinates into the specific address.
Important: you need to have a Here Geocoding API key to make the plugin work.
How to get Here API key?
Step 1: Click on the Sign up button at the top right corner of the https://www.here.com/.
here sign up
Step 2: Fill out the personal information form and click Verify email.
here verify email
Step 3: Confirm the password and click Next.
here create account
Step 4: Choose whether you want to have a paid plan or not.
here pick pricing plan
Step 5: Press “Get started with HERE platform”.
here get started
Step 6: Navigate to Access Manager.
here access manager
Step 7: Select the Apps tab.
here access manager apps
Step 8: Press Register new app and fill out the credentials after press the newly created app.
here register new app
Step 9: Go to API Keys, press Create API key, and then copy the generated key.
here api keys
How to use Here reverse geocoding plugin in flespi
Let's define a new plugin to resolve coordinates into addresses. Specify the required plugin type in the Type id field, fill in the API Key configuration fields. You can also specify which address components to add to the output parameter (Address Components field) and whether to add a prefix with the service name to each parameter (Parameter naming field).
Hint: alternatively you can navigate to the Devices tab for the given plugin and do the same.
And then you should be able to see the address fields in the new device messages. Go to the Logs & Messages tab for the given device to check:
Done.
  • We cannot guarantee the performance or stability of the third-party systems involved in the process — in case of their service interruptions flespi will not be able to save messages to devices and will respond with negative ACK and will also terminate the connection if the required flag is set.
Change log
Subscribe to the Here plugin change log to stay in sync with any updates.
More plugin types
