How to add address resolved by Google reverse geocoding into the message?
Using plugins to resolve position coordinates into address using Google reverse geocoding API and add it into the device messages.
The "google-reverse-geocoding" plugin type is used to apply Google reverse geocoding functionality to resolve position coordinates into the specific address.
Important: you need to have a Google Geocoding API key to make the plugin work.
Let's define a new plugin to resolve coordinates into addresses:
add google reverse geocoding plugin
assign google reverse geocoding plugin
And then you should be able to see the address fields in the new device messages. Go to the Logs & Messages tab for the given device to check:
check address added by google reverse geocoding plugin
Done.
  • We cannot guarantee the performance or stability of the third-party systems involved in the process — in case of their service interruptions flespi will not be able to save messages to devices and will respond with negative ACK and will also terminate the connection if the required flag is set.
Change log
Subscribe to the Google reverse geocoding plugin change log to stay in sync with any updates.
More plugin types
Using plugins to add the known BLE tag position into tracker messages for indoor monitoring.
