How to add address resolved by OSM reverse geocoding into the message?
Using plugins to resolve position coordinates into address using Nominatim OSM reverse geocoding API and add it into the device messages.
The "nominatim-reverse-geocoding" plugin type is used to apply Nominatim OSM reverse geocoding functionality to resolve position coordinates into the specific address.
Let's define a new plugin to resolve coordinates into addresses:
add osm nominatim reverse geocoding plugin
Note: here are the instructions to install and run Nominatim on your server.
assign osm nominatim reverse geocoding plugin
And then you should be able to see the address fields in the new device messages. Go to the Logs & Messages tab for the given device to check:
check address added by osm nominatim reverse geocoding plugin
Done.
  • We cannot guarantee the performance or stability of the third-party systems involved in the process — in case of their service interruptions flespi will not be able to save messages to devices and will respond with negative ACK and will also terminate the connection if the required flag is set.
Change log
Subscribe to the OSM Nominatim plugin change log to stay in sync with any updates.
More plugin types
Using a webhook plugin to make requests to the script on your custom server to modify messages.
Manually posting messages into a flespi device.
