How to add position coordinates resolved by Wialon LBS geocoding into the message?
Using plugins to resolve the coordinates of GSM base stations into position coordinates using Wialon LBS geocoding and add them into the device messages.
The "wialon-lbs-geocoding" plugin type is used to apply Wialon LBS service functionality to resolve the coordinates of GSM base stations into position coordinates. This may be helpful if for some reason GPS data is unavailable.
Let's define a new plugin to resolve coordinates into addresses:
add wialon lbs geocoding plugin
We recommend putting into validate_message field next value: $position.latitude == 0 || $position.longitude == 0 || $position.valid == false. This filter will activate the plugin only for messages that do not contain valid coordinates or which coordinates are invalid.
Cool feature! You can set up the plugin to automatically put the LBS data into position.latitude and position.longitude parameters if the GNSS data is not available — just enable the option in the configuration.
assign wialon lbs geocoding plugin
And then you should be able to see the position.lbs.latitude and position.lbs.longitude fields in the new device messages. Go to the Logs & Messages tab for the given device to check:
check that position parameters added by wialon lbs plugin
Done.
  • We cannot guarantee the performance or stability of the third-party systems involved in the process — in case of their service interruptions, flespi will not be able to save messages to devices and will respond with negative ACK and will also terminate the connection if the required flag is set.
Change log
Subscribe to the Wialon LBS geocoding plugin change log to stay in sync with any updates.
More plugin types
Using plugins to parse downloaded tachograph files (driver cards and vehicle unit memory files) and extract their structured data: driver activity, work period, vehicle usage, etc
