How to add address resolved by OSM reverse geocoding into the message?
Using plugins to resolve position coordinates into address using Nominatim OSM reverse geocoding API and add it into the device messages.
The "nominatim-reverse-geocoding" plugin type is used to apply Nominatim OSM reverse geocoding functionality to resolve position coordinates into the specific address.
Let's define a new plugin to resolve coordinates into addresses. Specify the required plugin type in the Type id field, fill in the Uri configuration fields. You can also specify which address components to add to the output parameter (Address Components field), what additional parameters you want to see in the message (Extratags components field) and whether to add a prefix with the service name to each parameter (Parameter naming field).
Use extratags to request specific features from your Nominatim server. For example you may receive the maxspeed value to retrieve posted speed limit according to the device position, compare it with the speed reported by the device (position.speed parameter) and trigger the over-speeding alert either with calculator or plugin.
In case authorization is required, you can configure a custom HTTP headers array. For example Authorization: Basic XXX.
Note: here are the instructions to install and run Nominatim on your server.
assign osm nominatim reverse geocoding plugin
And then you should be able to see the address fields in the new device messages. Go to the Logs & Messages tab for the given device to check:
check address added by osm nominatim reverse geocoding plugin
Done.
  • We cannot guarantee the performance or stability of the third-party systems involved in the process — in case of their service interruptions flespi will not be able to save messages to devices and will respond with negative ACK and will also terminate the connection if the required flag is set.
Change log
Subscribe to the OSM Nominatim plugin change log to stay in sync with any updates.
More plugin types
