Dragino-mqtt protocol
Dragino gateway MQTT communication protocol.
flespi parses the Dragino-mqtt protocol messages into a JSON object with the fields listed below in the Parameters tab.
dragino-mqtt channel works as a separate MQTT broker. In the channel card you may see MQTT broker URI to connect your devices and optionally configure authentication and enable TLS. MQTT client id can be any, as devices are identified by the first 8 bytes in the payload.
Different device types will require different topics to publish telemetry to. Currently supported devices and topics correspondence:
If you need to connect unlisted hardware that works over Dragino MQTT protocol - contact flespi team.
HEX format Payload(Type=0)
product.model.enum
Product model
