Dragino S31B-CB
The Dragino S31x-CB is a highly precise NB-IoT/LTE-M Temperature and Humidity Sensor. It features the SHT31 sensor for reliable measurements, supports various IoT protocols including MQTT and CoAP, offers a long-term use with its 8500mAh battery, and has a waterproof design with a range of -40°C to 80°C.
Parameters (25)
Dragino S31B-CB
Flespi parses telemetry data from your Dragino S31B-CB into a standardized JSON and lets you send commands to Dragino S31B-CB via API.
    "device.type.id": "Dragino S31B-CB",
    "protocol.id": "dragino-mqtt"
How to send commands to Dragino S31B-CB?
HEX format Payload(Type=0)
product.model.enum
Product model
Set GNSS open time
gnss_open_time
period: Set the GPS positioning time
Turn on/off GPS
gps
switch: Switch
Set GPS positioning interval
gps_positioning_interval
When GPS is enabled, the node automatically locates and uplinks each time it passes GTDC time after activation.
period: Period
GPS Request
gps_request
Set the receiving time
receiving_time
delay: Receiving time delay
Reset
Change update interval
update_interval
period: Period
Custom Command
More devices from Dragino
No results found.
