Queclink protocol
Parse and decode Queclink binary messages into JSON. Get parsed data from Queclink devices via REST API and MQTT. Forward normalized data from Queclink trackers to AWS, Azure, etc.
flespi parses the Queclink protocol messages into a JSON object with the fields listed below in the Parameters tab.
Step-by-step guide on how-to obtain telematics data from Queclink devices via API.
flespi supports two variants of Queclink protocol: Track Air Interface protocol (ASCII) (the majority of legacy devices) and binary Track Protocol Pro (the latest generation of devices). For the specific device model we support only one of these protocols and require to configure device correspondingly before you are able to connect it to the channel.
Alternative HEX format of Track Air Interface protocol is completely unsupported.
If the device is trying to connect with unsupported protocol variant for this specific device flespi channel will generate a parsing error with the information on which protocol variant you should reconfigure it.
Both TCP and UDP are supported on a transport layer.
If you see parsing errors mentioning '(unknown type XX)' in device logs, this indicates the device is registered with an incorrect device type. Verify the actual device model and select the correct device type in flespi, or contact support if your specific model is not listed.
Server ACK setting
Queclink devices can be configured whether the device needs to receive Server acknowledgments.
In order to decide if the server should send an acknowledgment for the report, it uses the Server ACK setting value. For Queclink devices, this value can be configured using the Backend Server Setup setting on the Connectivity tab.
flespi disable server ack setting
So, if Server ACK is enabled in the device's settings, the server replies to the reports with acknowledgments; if Server ACK is disabled, the server doesn't send acknowledgments to the reports received from the tracker.
That's why it's extremely important to keep the value of this device setting actual since unsynchronized configuration can cause unexpected behavior of the tracker — repetition of the same report several times.
We recommend you change the Backend Server setting of the tracker using the Setbox configuration tool. In this case, the server will always know the latest actual configuration of the device.
If you changed the Backend Server configuration of the tracker by any other means — either with the GTSRI command, or SMS, or with the standalone configurator — please don't forget to reread the setting from the tracker in order to synchronize the configuration of the tracker with flespi device.
flespi synchronize server ack setting
Timestamps troubleshooting
For Queclink protocol the value of timestamp message parameter is taken from the <Send Time> field of the report.
If report contains single GNSS position, then value of <GNSS UTC Time> of the position is registered additionally as position.timestamp message parameter.
For example, for the following report with one GNSS position:
+RESP:GTFRI,270F01,867155443322110,,,11,1,1,10.7,232,2796.8,-78.479081,-0.092869,20240426141850,0740,0001,38A7,7BE0,00,100454.1,,,,0,220100,,,,20240426141852,4051$
the messages registered will contain the time-related parameters shown below:
"position.timestamp": 1714141130		// <GNSS UTC Time>: 2024/04/26 14:18:50
"timestamp": 1714141132 // <Send Time>: 2024/04/26 14:18:52
If report contains multiple GNSS positions, then several messages will be registered, one for each position.
For all the messages except the last one, timestamp and position.timestamp parameters have the same values that are taken from <GNSS UTC Time> field of the corresponding position.
For the last registered message position.timestamp value will be taken from the <GNSS UTC Time> field of the last position, whereas timestamp - from the <Send Time> field of the report.
 For example, for the below report with two GNSS positions in it:
+RESP:GTFRI,270F01,867155443322110,,,10,2,1,44.4,235,2784.8,-78.476927,-0.091389,20240426141805,0740,0001,38A8,7BE0,00,1,50.3,233,2789.4,-78.477829,-0.092023,20240426141814,0740,0001,38A8,7BE0,00,100454.1,,,,0,220100,,,,20240426141825,404E$
the first registered message will have both timestamp and position.timestamp the same (taken form <GNSS UTC Time> of the first position):
"position.latitude": -0.091389
"position.longitude": -78.476927
"position.speed": 44.4
"position.timestamp": 1714141085     // <GNSS UTC Time>: 2024/04/26 14:18:05
"timestamp": 1714141085     // <GNSS UTC Time>: 2024/04/26 14:18:05
and the last message will have different values of position.timestamp and timestamp parameters, that come from  <GNSS UTC Time> and <Send Time> fields correspondingly:
"position.latitude": -0.092023
"position.longitude": -78.477829
"position.speed": 50.3
"position.timestamp": 1714141094     // <GNSS UTC Time>: 2024/04/26 14:18:14
"timestamp": 1714141105    // <Send Time>: 2024/04/26 14:18:25
Therefore, to build accurate tracks basing on the GNSS data sent by Queclink devices, we recommend using parameter position.timestamp as a time reference value.
If you want to override default behavior and store in all device messages <GNSS UTC Time> instead of <Send Time> in timestamp property you may easily implement this with msg-expression plugin.
FTP Server configuration for video commands
The Queclink CV100 and Queclink CV200 devices use the FTP protocol to send videos and photos to the server. To do this, you need to configure the connection parameters to the flespi FTP server using the Server for Transferring Files setting:
Upload mode is FTP, FTP server port is 21, FTP File path can be anything, FTP mode is FTP.
Please note that the FTP username and FTP password fields must be unique for each device. As FTP server uses gw.flespi.io, in the FTP username field, enter the flespi device ID (or device ID|channel ID) (in the example it is 8737), in the FTP password field you must enter the password that is specified in the flespi device configuration:
To simplify configuration FTP server settings will be automatically uploaded to your Queclink video device by the flespi channel when you will attempt to execute any video-related command that requires this FTP setting to be correctly configured on the device.
Serial Data Transfer Troubleshooting
To transmit serial data from a device to a server, the GTDAT and GTDTT packets can be utilized, and configured via the AT+GTURT command (Working Mode = 7 or 8). The GTDAT packet is limited to transmitting only text data, whereas the GTDTT packet is capable of sending serial data in either HEX or HEX-string format.
Due to this distinction, the GTDAT packet has a restriction on the use of the comma (",") character, as it is used to delimit fields within the packet and may interfere with data parsing. If you need to transmit the comma (",") character in the serial data, please use the GTDTT packet.
Event ID 30 of Report GTDSS
Report GTTEM
Report GTTEM
The car synchronization state
can.idle.gas.fuel.consumed
Total natural gas idle fuel used, read from CAN
Report GTTEM
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTTEM
Harsh behaviour event type 4 of Report GTHBM
Harsh behaviour event type 5 of Data ID 140
Report GTRTL
Request tachograph file
request_tachograph_file
Stop videostream
stop_videostream
Stop videostream
