You can obtain telematics data from any Queclink device in 6 easy steps:
- Create a free account on flespi.io.
- Set up the Queclink channel in your flespi.io interface.
- Point a Queclink device to your flespi account using the device configurator from Teltonika or by sending an SMS command to the device.
- Confirm that the device data is being received and parsed.
- Access Queclink device data via API.
For Queclink devices with video functionality we have a specialized quick start guide which you use instead.
2. Set up the Queclink channel on flespi.io
The Channel dialogue box will show up. Enter the name for the channel (any text will suffice), select “queclink” in the protocol_id drop-down menu, click 'SAVE + OPEN'.
3. Point your Queclink device to your flespi channel
You can do it with the Queclink device configurator tool or by sending an SMS command to the device. The domain name and port to point to are located in the Channel box. You should select ASCII flavor of the protocol and we suggest to enable server ACK setting. Both TCP and UDP transports are supported although we generally recommend to use TCP for more transparent data flow.
While in the Channel dialogue box, click on the Logs and Messages tab. Inspect log records to confirm that your device has successfully connected to flespi. The presence of messages in the lower half of the screen will confirm that the incoming data is parsed. Please keep in mind that in as Logs section runs in realtime it will reflect any connection attempt. Hint: you can right-click on a message or log to show corresponding raw traffic.
5. Access Queclink device data via API
6. Create a flespi device
What's next?
