Access connected vehicle data exposed by Renault Trucks Developer APIs via flespi REST API and MQTT. Forward normalized JSON data to AWS, Azure, Wialon, etc.
flespi parses the Renault-trucks protocol messages into a JSON object with the fields listed below in the Parameters tab.
To access connected vehicle data exposed by Renault Trucks Developer APIs you should create flespi channel and configure it with API credentials. You can obtain these credentials in one of three ways, depending on your role:
  • Contact Renault Trucks Developer Portal support and ask for API credentials.
  • Request API credentials from the customer who hired you.
  • Generate credentials yourself in Renault Trucks Developer Portal
Disclaimer: All trademarks, logos, and company names appearing on this site are the property of their respective owners and are used solely to identify compatibility. No trademark owner has reviewed, authorized, endorsed, certified, or otherwise approved our company, its products, or this content as an official supplier or partner.
adas.lane.departure.count
Total number of lane keeping support warnings
accumulatedData.volvoGroupAccumulated.lanekeepingWarningCounter
triggerType.tellTaleInfo.ANTI_LOCK_BRAKE_FAILURE.state,
uptimeData.tellTaleInfo.ANTI_LOCK_BRAKE_FAILURE.state
triggerType.tellTaleInfo.ABS_TRAILER.state,
uptimeData.tellTaleInfo.ABS_TRAILER.state
triggerType.tellTaleInfo.ACC.state,
uptimeData.tellTaleInfo.ACC.state
snapshotData.catalystFuelLevel
triggerType.tellTaleInfo.ADBLUE_LEVEL.state,
uptimeData.tellTaleInfo.ADBLUE_LEVEL.state
triggerType.tellTaleInfo.AIRBAG.state,
uptimeData.tellTaleInfo.AIRBAG.state
triggerType.tellTaleInfo.AIR_FILTER_CLOGGED.state,
uptimeData.tellTaleInfo.AIR_FILTER_CLOGGED.state
snapshotData.ambientAirTemperature
triggerType.tellTaleInfo.BATTERY_CHARGING_CONDITION.state,
uptimeData.tellTaleInfo.BATTERY_CHARGING_CONDITION.state
triggerType.tellTaleInfo.BRAKE_MALFUNCTION.state,
uptimeData.tellTaleInfo.BRAKE_MALFUNCTION.state
triggerType.tellTaleInfo.BRAKE_LIGHTS.state,
uptimeData.tellTaleInfo.BRAKE_LIGHTS.state
can.convoy.full.distance
Distance driven with full convoy weight
accumulatedData.volvoGroupAccumulated.convoyWeightMeters.FULL.value
can.convoy.light.distance
Distance driven with light convoy weight
accumulatedData.volvoGroupAccumulated.convoyWeightMeters.LIGHT.value
can.convoy.medium.distance
Distance driven with medium convoy weight
accumulatedData.volvoGroupAccumulated.convoyWeightMeters.MEDIUM.value
triggerType.tellTaleInfo.EBS.state,
uptimeData.tellTaleInfo.EBS.state
triggerType.tellTaleInfo.EBS_TRAILER_1_2.state,
uptimeData.tellTaleInfo.EBS_TRAILER_1_2.state
can.edrive.performance.mode.energy
Electrical drive PERFORMANCE mode counters for energy
accumulatedData.volvoGroupAccumulated.edriveMode.PERFORMANCE.watthours
can.edrive.performance.mode.mileage
Electrical drive PERFORMANCE mode counters for mileage
accumulatedData.volvoGroupAccumulated.edriveMode.PERFORMANCE.meters
can.edrive.performance.mode.time
Electrical drive PERFORMANCE mode counters for time
accumulatedData.volvoGroupAccumulated.edriveMode.PERFORMANCE.seconds
can.edrive.range.mode.energy
Electrical drive RANGE mode counters for energy
accumulatedData.volvoGroupAccumulated.edriveMode.RANGE.watthours
can.edrive.range.mode.mileage
Electrical drive RANGE mode counters for mileage
accumulatedData.volvoGroupAccumulated.edriveMode.RANGE.meters
can.edrive.range.mode.time
Electrical drive RANGE mode counters for time
accumulatedData.volvoGroupAccumulated.edriveMode.RANGE.seconds
can.edrive.standard.mode.energy
Electrical drive STANDARD mode counters for energy
accumulatedData.volvoGroupAccumulated.edriveMode.STANDARD.watthours
can.edrive.standard.mode.mileage
Electrical drive STANDARD mode counters for mileage
accumulatedData.volvoGroupAccumulated.edriveMode.STANDARD.meters
can.edrive.standard.mode.time
Electrical drive STANDARD mode counters for time
accumulatedData.volvoGroupAccumulated.edriveMode.STANDARD.seconds
triggerType.tellTaleInfo.ADVANCED_EMERGENCY_BREAKING.state,
uptimeData.tellTaleInfo.ADVANCED_EMERGENCY_BREAKING.state
triggerType.tellTaleInfo.ENGINE_COOLANT_LEVEL.state,
uptimeData.tellTaleInfo.ENGINE_COOLANT_LEVEL.state
uptimeData.engineCoolantTemperature
triggerType.tellTaleInfo.ENGINE_COOLANT_TEMPERATURE.state,
uptimeData.tellTaleInfo.ENGINE_COOLANT_TEMPERATURE.state
triggerType.tellTaleInfo.ENGINE_EMISSION_FAILURE.state,
uptimeData.tellTaleInfo.ENGINE_EMISSION_FAILURE.state
can.engine.energy.consumed
Total energy used by electric motor for propulsion read from CAN
accumulatedData.volvoGroupAccumulated.electricEnergyPropulsion
triggerType.tellTaleInfo.ENGINE_MIL_INDICATOR.state,
uptimeData.tellTaleInfo.ENGINE_MIL_INDICATOR.state
totalEngineHours
triggerType.tellTaleInfo.ENGINE_OIL.state,
uptimeData.tellTaleInfo.ENGINE_OIL.state
triggerType.tellTaleInfo.ENGINE_OIL_LEVEL.state,
uptimeData.tellTaleInfo.ENGINE_OIL_LEVEL.state
triggerType.tellTaleInfo.ENGINE_OIL_TEMPERATURE.state,
uptimeData.tellTaleInfo.ENGINE_OIL_TEMPERATURE.state
snapshotData.engineSpeed
triggerType.tellTaleInfo.ESC_INDICATOR.state,
uptimeData.tellTaleInfo.ESC_INDICATOR.state
triggerType.tellTaleInfo.FRONT_FOG_LIGHT.state,
uptimeData.tellTaleInfo.FRONT_FOG_LIGHT.state
engineTotalFuelUsed
triggerType.tellTaleInfo.FUEL_FILTER_DIFF_PRESSURE.state,
uptimeData.tellTaleInfo.FUEL_FILTER_DIFF_PRESSURE.state
can.fuel.level.1
Fuel level in tank read from CAN #1
snapshotData.fuelLevel1
triggerType.tellTaleInfo.FUEL_LEVEL.state,
uptimeData.tellTaleInfo.FUEL_LEVEL.state
accumulatedData.volvoGroupAccumulated.totalFuelUsedGaseous
grossCombinationVehicleWeight
triggerType.tellTaleInfo.HAZARD_WARNING.state,
uptimeData.tellTaleInfo.HAZARD_WARNING.state
triggerType.tellTaleInfo.HEIGHT_CONTROL.state,
uptimeData.tellTaleInfo.HEIGHT_CONTROL.state
triggerType.tellTaleInfo.HIGH_BEAM_MAIN_BEAM.state,
uptimeData.tellTaleInfo.HIGH_BEAM_MAIN_BEAM.state
can.hv.consumed
The electric energy the auxiliary high voltage system have consumed
accumulatedData.volvoGroupAccumulated.electricEnergyAuxClass.HV.watthours
can.hv.driving.consumed
The electric energy the auxiliary high voltage system have consumed while driving
accumulatedData.volvoGroupAccumulated.electricEnergyAuxClass.HV_WHEELBASED_SPEED_OVER_ZERO.watthours
can.hv.idling.consumed
The electric energy the auxiliary high voltage system have consumed while idling
accumulatedData.volvoGroupAccumulated.electricEnergyAuxClass.HV_WHEELBASED_SPEED_ZERO.watthours
triggerType.tellTaleInfo.LANE_DEPARTURE_INDICATOR.state,
uptimeData.tellTaleInfo.LANE_DEPARTURE_INDICATOR.state
triggerType.tellTaleInfo.LOW_BEAM_DIPPED_BEAM.state,
uptimeData.tellTaleInfo.LOW_BEAM_DIPPED_BEAM.state
triggerType.tellTaleInfo.GENERAL_FAILURE.state,
uptimeData.tellTaleInfo.GENERAL_FAILURE.state
triggerType.tellTaleInfo.PARKING_HEATER.state,
uptimeData.tellTaleInfo.PARKING_HEATER.state
triggerType.tellTaleInfo.PARKING_BRAKE.state,
uptimeData.tellTaleInfo.PARKING_BRAKE.state
triggerType.tellTaleInfo.POSITION_LIGHTS.state,
uptimeData.tellTaleInfo.POSITION_LIGHTS.state
can.pto.all.energy
All PTO energy
accumulatedData.volvoGroupAccumulated.ptoActiveClass.ALL.watthours
can.pto.all.time
All PTO active time
accumulatedData.volvoGroupAccumulated.ptoActiveClass.ALL.seconds
can.pto.driving.energy
PTO active energy while driving
accumulatedData.volvoGroupAccumulated.ptoActiveClass.ALL_WHEELBASED_SPEED_OVER_ZERO.watthours
can.pto.gearbox.count
Gearbox PTO counter
accumulatedData.volvoGroupAccumulated.ptoActiveClass.GEARBOX.counter
can.pto.gearbox.time
Gearbox PTO active time
accumulatedData.volvoGroupAccumulated.ptoActiveClass.GEARBOX.seconds
can.pto.idle.time
PTO active time while idling
accumulatedData.ptoActiveClass.WHEELBASED_SPEED_ZERO.seconds
can.pto.idling.energy
PTO active energy while idling
accumulatedData.volvoGroupAccumulated.ptoActiveClass.ALL_WHEELBASED_SPEED_ZERO.watthours
can.pto.idling.time
accumulatedData.volvoGroupAccumulated.ptoActiveClass.ALL_WHEELBASED_SPEED_ZERO.seconds
can.pto.mech.count
MECH PTO counter
accumulatedData.volvoGroupAccumulated.ptoActiveClass.MECH.counter
can.pto.mech.energy
MECH PTO energy
accumulatedData.volvoGroupAccumulated.ptoActiveClass.MECH.watthours
can.pto.mech.time
MECH PTO active time
accumulatedData.volvoGroupAccumulated.ptoActiveClass.MECH.seconds
triggerType.tellTaleInfo.REAR_FOG_LIGHT.state,
uptimeData.tellTaleInfo.REAR_FOG_LIGHT.state
triggerType.tellTaleInfo.RETARDER.state,
uptimeData.tellTaleInfo.RETARDER.state
can.service.brake.air.pressure.1
Service brake air pressure circuit #1
uptimeData.serviceBrakeAirPressureCircuit1
uptimeData.serviceBrakeAirPressureCircuit2
triggerType.tellTaleInfo.SERVICE_CALL_FOR_MAINTENANCE.state,
uptimeData.tellTaleInfo.SERVICE_CALL_FOR_MAINTENANCE.state
uptimeData.serviceDistance
triggerType.tellTaleInfo.STEERING_FAILURE.state,
uptimeData.tellTaleInfo.STEERING_FAILURE.state
triggerType.tellTaleInfo.TACHOGRAPH_INDICATOR.state,
uptimeData.tellTaleInfo.TACHOGRAPH_INDICATOR.state
triggerType.tellTaleInfo.TIRE_MALFUNCTION.state,
triggerType.tellTaleInfo.state,
uptimeData.tellTaleInfo.TIRE_MALFUNCTION.state
accumulatedData.durationWheelbaseSpeedOverZero
accumulatedData.durationWheelbaseSpeedZero
triggerType.tellTaleInfo.TRAILER_CONNECTED.state,
uptimeData.tellTaleInfo.TRAILER_CONNECTED.state
can.transmission.auto.duration
Total time for transmission in AUTO mode
accumulatedData.volvoGroupAccumulated.transmissionModeSeconds.AUTO.value
triggerType.tellTaleInfo.TRANSMISSION_MALFUNCTION.state,
uptimeData.tellTaleInfo.TRANSMISSION_MALFUNCTION.state
triggerType.tellTaleInfo.TRANSMISSION_FLUID_TEMPERATURE.state,
uptimeData.tellTaleInfo.TRANSMISSION_FLUID_TEMPERATURE.state
can.transmission.manual.duration
Total time for transmission in MANUAL mode
accumulatedData.volvoGroupAccumulated.transmissionModeSeconds.MANUAL.value
can.transmission.power.duration
Total time for transmission in POWER mode
accumulatedData.volvoGroupAccumulated.transmissionModeSeconds.POWER.value
triggerType.tellTaleInfo.TURN_SIGNALS.state,
uptimeData.tellTaleInfo.TURN_SIGNALS.state
snapshotData.volvoGroupSnapshot.batteryPackChargingStatus,
triggerType.volvoGroupTrigger.chargingStatusInfo.event
can.vehicle.battery.distanse.recuperated
Recuperated distance read from CAN
accumulatedData.volvoGroupAccumulated.electricEnergyRecuperation.meters
accumulatedData.volvoGroupAccumulated.totalElectricEnergyUsed
accumulatedData.volvoGroupAccumulated.electricEnergyRecuperation.watthours
snapshotData.volvoGroupSnapshot.hybridBatteryPackRemainingCharge
can.vehicle.battery.time.recuperated
Recuperated time read from CAN
accumulatedData.volvoGroupAccumulated.electricEnergyRecuperation.seconds
can.vehicle.charge.connection.state
CAN vehicle battery charge connection state
triggerType.volvoGroupTrigger.chargingConnectionStatusInfo.event
can.vehicle.electric.motorhours
The total hours the electric motor is ready for propulsion read from CAN
accumulatedData.volvoGroupAccumulated.totalElectricMotorHours
can.vehicle.energy.ac.charged
Total electric energy charged from AC chargers read from CAN
accumulatedData.volvoGroupAccumulated.electricEnergyFromChargingDeviceClass.AC.watthours
can.vehicle.energy.dc.charged
Total electric energy charged (system DC) read from CAN
accumulatedData.volvoGroupAccumulated.electricEnergyFromChargingDeviceClass.DC.watthours
can.vehicle.energy.driving.consumed
The electric energy the vehicle has consumed while driving
accumulatedData.volvoGroupAccumulated.electricEnergyWheelbasedSpeedOverZero
can.vehicle.energy.plugged.consumed
Total electric energy consumed by the vehicle, including when plugged in for charging
accumulatedData.volvoGroupAccumulated.totalElectricEnergyUsedPluggedInIncluded
accumulatedData.volvoGroupAccumulated.electricEnergyWheelbasedSpeedZero
hrTotalVehicleDistance
snapshotData.wheelBasedSpeed
triggerType.tellTaleInfo.WINDSCREEN_WASHER_FLUID.state,
uptimeData.tellTaleInfo.WINDSCREEN_WASHER_FLUID.state
triggerType.tellTaleInfo.WORN_BRAKE_LININGS.state,
uptimeData.tellTaleInfo.WORN_BRAKE_LININGS.state
dsm.warning.count
Total number of DSM warnings
accumulatedData.volvoGroupAccumulated.driverAlertWarningMinorCounter
triggerType.triggerType.ENGINE_ON,ENGINE_OFF
event.name
Protocol-specific event name
event.type
Event Type
triggerType.context
accumulatedData.volvoGroupAccumulated.brakeCount
accumulatedData.volvoGroupAccumulated.coasting.milliLitres
accumulatedData.volvoGroupAccumulated.coasting.meters
accumulatedData.volvoGroupAccumulated.coasting.seconds
accumulatedData.fuelConsumptionDuringCruiseActive
accumulatedData.distanceCruiseControlActive
accumulatedData.durationCruiseControlActive
accumulatedData.volvoGroupAccumulated.stopCount
front.trailer.axle.weight
Weight on front trailer axle
snapshotData.volvoGroupSnapshot.trailerAxleWeight.FRONT.value
front.vehicle.axle.weight
Weight on front vehicle axle
snapshotData.volvoGroupSnapshot.axleWeights.FRONT.value
triggerType.triggerInfo
triggerType.triggerType.GEOFENCE
accumulatedData.volvoGroupAccumulated.roadOverspeed.seconds
overspeeding.fuel.consumed
Overspeeding fuel consumed
accumulatedData.volvoGroupAccumulated.roadOverspeed.milliLitres
overspeeding.gas.consumed
Overspeeding gas consumed
accumulatedData.volvoGroupAccumulated.roadOverspeed.kilograms
accumulatedData.volvoGroupAccumulated.roadOverspeed.meters
snapshotData.gnssPosition.altitude
snapshotData.gnssPosition.heading
snapshotData.gnssPosition.latitude
snapshotData.gnssPosition.longitude
snapshotData.gnssPosition.speed
rear.trailer.axle.weight
Weight on rear trailer axle
snapshotData.volvoGroupSnapshot.trailerAxleWeight.REAR.value
rear.vehicle.axle.weight
Weight on rear vehicle axle
snapshotData.volvoGroupSnapshot.axleWeights.REAR.value
remaining.range.battery
Estimated distance to empty, battery pack
snapshotData.volvoGroupSnapshot.estimatedDistanceToEmpty.batteryPack
remaining.range.fuel
Estimated distance to empty, fuel tank
snapshotData.volvoGroupSnapshot.estimatedDistanceToEmpty.fuel
remaining.range.gas
Estimated distance to empty, gas tank
snapshotData.volvoGroupSnapshot.estimatedDistanceToEmpty.gas
remaining.range.total
Estimated distance to empty, summarizing fuel, gas and battery
snapshotData.volvoGroupSnapshot.estimatedDistanceToEmpty.total
send.timestamp
Message send timestamp
createdDateTime
triggerType.driverId.tachoDriverIdentification.driverIdentification
tacho.driver.card.code.1
Driver identification card id for tacho #1
driver1Id.tachoDriverIdentification.driverIdentification
tacho.driver.card.issuer
The country alpha code of the Member State having issued the driver card
triggerType.driverId.tachoDriverIdentification.cardIssuingMemberState
tacho.driver.card.issuer.1
The country alpha code of the Member State having issued the driver card #1
driver1Id.tachoDriverIdentification.cardIssuingMemberState
tacho.driver.card.renewal.1
Driver card renewal index #1
driver1Id.tachoDriverIdentification.cardRenewalIndex
tacho.driver.card.replacement.1
Driver card replacement index #1
driver1Id.tachoDriverIdentification.cardReplacementIndex
tacho.driver.card.type
Driver identification card type, protocol specific type name
triggerType.driverId.tachoDriverIdentification.driverAuthenticationEquipment
tacho.driver.card.type.1
Driver identification card type, protocol specific type name #1
driver1Id.tachoDriverIdentification.driverAuthenticationEquipment
tacho.driver.daily.driving.duration.1
Current daily driving time read from Tacho #1
snapshotData.volvoGroupSnapshot.driver1WorkingTimeToday
tacho.driver.daily.rest.duration.1
Current daily rest time read from Tacho #1
snapshotData.volvoGroupSnapshot.driver1WaitingTimeToday
tacho.driver.work.state.1
Protocol-specific driver work state name #1
snapshotData.driver1WorkingState
snapshotData.tachographSpeed
snapshotData.gnssPosition.positionDateTime
total.trailer.weight
Total trailer weight
snapshotData.volvoGroupSnapshot.trailerTotalWeight
