Teltonika-mobility-mqtt protocol
Protocol used by mobility tracking devices manufactured by Teltonika headquartered in Lithuania.
flespi parses the Teltonika-mobility-mqtt protocol messages into a JSON object with the fields listed below in the Parameters tab.
This MQTT-based protocol with CBOR payload is used by some Teltonika Mobility devices.
For device configuration on the Teltonika portal, in the MQTT Settings form use the channel host and port in the IP and Port fields.
teltonika mqtt client configuration
The Login and Password fields are used only if you enable the Authenticate incoming MQTT connections option in the flespi channel configuration. The User ID field is used as an MQTT Client ID string which should be unique within all devices of your channel.
IO ID 29
IO ID 21
IO ID 39
IO ID 20
IO ID 43...69
can.error.code
Vehicle error code reported by CAN bus
IO ID 32
can.status.code
Vehicle status code reported by CAN bus
IO ID 31
can.vehicle.battery.error
Vehicle battery error code reported by CAN bus
IO ID 36
IO ID 33
can.vehicle.lock.state
Vehicle lock status reported by CAN bus
IO ID 37
IO ID 34
can.vehicle.mode
Vehicle mode reported by CAN bus
IO ID 38
IO ID 30,
IO ID 70
can.vehicle.trip.mileage
Vehicle odometer reported by CAN bus
IO ID 35
IO ID 22,
IO ID 23,
IO ID 24
IO ID 25
IO ID 19
IO ID 16
IO ID 17
IO ID 18
IO ID 18
IO ID 18
IO ID 15
IO ID 40
IO ID 41
IO ID 11
IO ID 4
IO ID 5
position.fix.type
IO ID 10
IO ID 7
IO ID 2
IO ID 3
IO ID 8
IO ID 6
IO ID 9
sleep.mode
Sleep mode
IO ID 42
IO ID 1
IO ID 28
IO ID 27
IO ID 26
IO ID 12
IO ID 13
IO ID 14
Connect to configured FOTA WEB server
{"payload":"@fota_web_connect"}
