Teltonika EMB100
Teltonika EMB100 is an IoT device for e-bikes with integrated ECU data reading, GSM/GNSS connectivity. The device features LTE CAT-1/LTE CAT-M1/LTE Nb-IoT/GSM support, Bosch, Bafang, Shimano, and other power-train support, possibility to have additional features such as battery levels and battery health, IP67 waterproof casing, different mounting options, 600 mAh Li-Pol battery, and more.
Parameters (51)
Teltonika EMB100
Flespi parses telemetry data from your Teltonika EMB100 into a standardized JSON and lets you send commands to Teltonika EMB100 via API.
    "device.type.id": "Teltonika EMB100",
    "protocol.id": "teltonika-mobility-mqtt"
How to send commands to Teltonika EMB100?
IO ID 29
IO ID 21
IO ID 39
IO ID 20
IO ID 43...69
can.error.code
Vehicle error code reported by CAN bus
IO ID 32
can.status.code
Vehicle status code reported by CAN bus
IO ID 31
can.vehicle.battery.error
Vehicle battery error code reported by CAN bus
IO ID 36
IO ID 33
can.vehicle.lock.state
Vehicle lock status reported by CAN bus
IO ID 37
IO ID 34
can.vehicle.mode
Vehicle mode reported by CAN bus
IO ID 38
IO ID 30,
IO ID 70
can.vehicle.trip.mileage
Vehicle odometer reported by CAN bus
IO ID 35
IO ID 22,
IO ID 23,
IO ID 24
IO ID 25
IO ID 19
IO ID 16
IO ID 17
IO ID 18
IO ID 18
IO ID 18
IO ID 15
IO ID 40
IO ID 41
IO ID 11
IO ID 4
IO ID 5
position.fix.type
IO ID 10
IO ID 7
IO ID 2
IO ID 3
IO ID 8
IO ID 6
IO ID 9
sleep.mode
Sleep mode
IO ID 42
IO ID 1
IO ID 28
IO ID 27
IO ID 26
IO ID 12
IO ID 13
IO ID 14
Connect to configured FOTA WEB server
{"payload":"@fota_web_connect"}
