ACTIA iCAN
The ACTIA iCAN is a plug-and-play telematics box that connects directly to the vehicle’s OBD Diag port, allowing real-time reading of original manufacturer vehicle data. It combines OBD, CAN, and DIAG protocols to access over 300 data points, including status and live information, and translates proprietary diagnostic trouble codes for connected maintenance.
Parameters (227)
ACTIA iCAN
Flespi parses telemetry data from your ACTIA iCAN into a standardized JSON and lets you send commands to ACTIA iCAN via API.
    "device.type.id": "ACTIA iCAN",
    "protocol.id": "actia"
iCAN_ID 20220
accelerometer.state.enum
Accelerometer function status (0: deactivated / 3: activated and calibration pending / 4: activated and calibration done)
iCAN_ID 20219
iCAN_ID 157
iCAN_ID 185,
iCAN_ID 20368
bluetooth.command.name
Bluetooth command name
iCAN_ID 159
bluetooth.mode
Bluetooth mode
iCAN_ID 20362
TGU-R ID 71
can.accelerator.pedal.up.distance
Accelerator pedal up distance from CAN bus
iCAN_ID 337
can.accelerator.pedal.up.duration
Accelerator pedal up time from CAN bus
iCAN_ID 336
can.adblue.refill.mileage
Mileage left until Adblue tank refill
iCAN_ID 20206
TGU-R ID 60,
iCAN_ID 20217
iCAN_ID 20099
can.alternator.status
TGU-R ID 43,
TGU-R ID 44
TGU-R ID 35
TGU-R ID 13
TGU-R ID 63
can.battery.max.voltage
Max Battery voltage from CAN bus
iCAN_ID 268
can.battery.min.voltage
Min Battery voltage from CAN bus
iCAN_ID 267
can.battery.regeneration.duration
Battery regeneration duration,read from CAN bus
iCAN_ID 20173
can.battery.regeneration.mileage
Battery regeneration mileage,read from CAN bus
iCAN_ID 20172
can.carbon.dioxide.exhausted
iCAN_ID 20253
can.connection.type
Type of service (OBD, OEM specific, etc...)
iCAN_ID 20066
can.diagnostic.attempt
Diagnostic attempt status at start of service (1: Diag attempted / 0: Diag not attempted)
iCAN_ID 20339
can.dpf.regeneration.active.duration
Duration of DPF regeneration in active mode
iCAN_ID 20181
can.dpf.regeneration.passive.duration
Duration of DPF regeneration in passive mode
iCAN_ID 20182
TGU-R ID 72
can.engine.cylinders.count
Number of Cylinders read from CAN bus
iCAN_ID 20129
TGU-R ID 54
can.engine.inappropriate.start.count
Enginge inappropriate start count from CAN bus
iCAN_ID 20069
TGU-R ID 14,
iCAN_ID 14,
iCAN_ID 20268
can.engine.oil.max.temperature
Maximum engine oil temperature, read from CAN bus
TGU-R ID 65,
iCAN_ID 20019
can.engine.oil.min.temperature
Minimum engine oil temperature, read from CAN bus
iCAN_ID 20018
TGU-R ID 61,
TGU-R ID 73
TGU-R ID 10,
iCAN_ID 10
can.engine.start.count
iCAN_ID 212
TGU-R ID 34,
iCAN_ID 34
can.excess.battery.voltage.count
Excess battery voltage count read from CAN bus
iCAN_ID 542
can.excess.battery.voltage.distance
Excess battery voltage distance read from CAN bus
iCAN_ID 544
can.excess.battery.voltage.duration
Excess battery voltage duration read from CAN bus
iCAN_ID 543
can.excess.engine.coolant.temperature.count
Excess engine coolant temperature count read from CAN bus
iCAN_ID 516
can.excess.engine.coolant.temperature.distance
Excess engine coolant temperature drive distance read from CAN bus
iCAN_ID 518
can.excess.engine.coolant.temperature.duration
Excess engine coolant temperature duration read from CAN bus
iCAN_ID 517
can.excess.engine.oil.temperature.count
Excess engine oil temperature count read from CAN bus
iCAN_ID 524
can.excess.engine.oil.temperature.distance
Excess engine oil temperature distance read from CAN bus
iCAN_ID 526
can.excess.engine.oil.temperature.duration
Excess engine oil temperature duration read from CAN bus
iCAN_ID 525
can.excess.engine.rpm.count
Excess engine RPM count read from CAN bus
iCAN_ID 506
can.excess.engine.rpm.distance
Excess engine RPM drive distance read from CAN bus
iCAN_ID 508
can.excess.engine.rpm.duration
Excess engine RPM duration read from CAN bus
iCAN_ID 507
can.excess.speed.count
Excess vehicle speed count read from CAN bus
iCAN_ID 503
can.excess.speed.distance
Excess vehicle speed drive distance read from CAN bus
iCAN_ID 505
can.excess.speed.duration
Excess vehicle speed duration read from CAN bus
iCAN_ID 504
can.excess.throttle.count
Excess throttle count read from CAN bus
iCAN_ID 500
can.excess.throttle.distance
Excess throttle drive distance read from CAN bus
iCAN_ID 502
can.excess.throttle.duration
Excess throttle duration read from CAN bus
iCAN_ID 501
can.fault.reading.abs.esp.status
ABS/ESP fault reading status read from CAN bus
iCAN_ID 20128
can.fault.reading.airbag.status
Airbag fault reading status read from CAN bus
iCAN_ID 20125
can.fault.reading.central.ecu.status
Central ECU fault reading status read from CAN bus
iCAN_ID 20126
can.fault.reading.dashboard.status
Dashboard fault reading status read from CAN bus
iCAN_ID 20124
can.fault.reading.gearbox.status
Gearbox fault reading status read from CAN bus
iCAN_ID 20121
can.fault.reading.headlights.status
Headlights fault reading status read from CAN bus
iCAN_ID 20122
can.fault.reading.injection.status
Injection fault reading status read from CAN bus
iCAN_ID 20119
TGU-R ID 3,
iCAN_ID 20120
can.fault.reading.power.steering.status
Power steering fault reading status read from CAN bus
iCAN_ID 20123
can.fault.reading.tire.ecu.status
Tire ECU fault reading status read from CAN bus
iCAN_ID 20127
TGU-R ID 7,
iCAN_ID 8
TGU-R ID 55
iCAN_ID 20067
can.fuel.injection.cut.distance
Distance with injection cut-off from CAN bus
iCAN_ID 273
can.fuel.injection.cut.duration
Duration with injection cut-off from CAN bus
iCAN_ID 272
TGU-R ID 9,
iCAN_ID 20384,
iCAN_ID 9
iCAN_ID 2009
iCAN_ID 20385
TGU-R ID 48
can.harsh.acceleration.count
Harsh Accel count read from CAN bus
iCAN_ID 513
can.harsh.brake.count
Harsh Brake count read from CAN bus
iCAN_ID 512
can.nox.absorber.desulfurization.duration
Duration of NOX absorber desulfurization
iCAN_ID 20184
can.nox.absorber.regeneration.duration
Duration of NOX absorber regeneration
iCAN_ID 20183
can.nox.exhausted
mg
Amount of NOx emitted during the journey
iCAN_ID 20252
CAN at least one PTO engaged
TGU-R ID 56
can.pto.run.time
iCAN_ID 20272
TGU-R ID 4
TGU-R ID 41,
TGU-R ID 42
iCAN_ID 10025,
iCAN_ID 20192
can.service.start.battery.voltage
Battery voltage at start of service from CAN bus
iCAN_ID 245
can.service.start.tell.tale.state
Tell-tale status at the start of service
iCAN_ID 243
can.service.stop.battery.voltage
Battery voltage at end of service from CAN bus
iCAN_ID 246
can.service.stop.tell.tale.state
Tell-tale status at the end of service
iCAN_ID 244
iCAN_ID 10015,
iCAN_ID 20193
TGU-R ID 33
iCAN_ID 221
TGU-R ID 66
can.vehicle.autonomy.mileage
Vehicle autonomy mileage, read from CAN bus
iCAN_ID 20114
iCAN_ID 20111
TGU-R ID 19,
iCAN_ID 19
TGU-R ID 2
iCAN_ID 20033
TGU-R ID 153,
iCAN_ID 153
iCAN_ID 157
ecu.error.code
ECU error code
iCAN_ID 802,
iCAN_ID 803
iCAN_ID 157
event.name
Protocol-specific event name
iCAN_ID 157
iCAN_ID 20093
iCAN_ID 157
TGU-R ID 57
TGU-R ID 59
TGU-R ID 58
iCAN_ID 20058
fuel.consumed.algorithm
Algorithm used to calculate fuel usage
iCAN_ID 20085
fuel.consumed.diesel
Fuel volume totally consumed by vehicle counted by Diesel algorithm
iCAN_ID 20087,
iCAN_ID 20088
fuel.consumed.gasoline
Fuel volume totally consumed by vehicle counted by Gasoline algorithm
iCAN_ID 20086
gnss.fix.duration
iCAN_ID 20381
gsm.network.name
iCAN_ID 20349
iCAN_ID 20350
iCAN_ID 20229
iCAN_ID 20230
iCAN_ID 20032
harsh.acceleration.distance
Harsh acceleration distance
iCAN_ID 20107
harsh.acceleration.duration
Harsh acceleration event duration
iCAN_ID 20105
iCAN_ID 157
harsh.brake.distance
Harsh brake distance
iCAN_ID 20106
harsh.brake.duration
Harsh brake duration
iCAN_ID 20104
iCAN_ID 157
iCAN_ID 157
harsh.event.latitude
Latitude at the end of the harsh event
iCAN_ID 20189
harsh.event.longitude
Longitude at the end of the harsh event
iCAN_ID 20190
harsh.event.speed
Speed at the end of the harsh event
iCAN_ID 20191
iCAN_ID 157
iCAN_ID 157
key.switch.state
Key switch state: -1 = Invalid, 0 = Key Off, 1 = Key On
iCAN_ID 157
low.speed.event
Low speed detected
iCAN_ID 157
iCAN_ID 20380
message.seqnum
iCAN_ID 32767
message.type.enum
Message Type
iCAN_ID 20361
iCAN_ID 157
TGU-R ID 105,
iCAN_ID 105
TGU-R ID 107,
iCAN_ID 107
position.fix.enum
iCAN_ID 103
iCAN_ID 20378
TGU-R ID 101,
iCAN_ID 101
TGU-R ID 102,
iCAN_ID 102
TGU-R ID 104,
iCAN_ID 104
TGU-R ID 106,
iCAN_ID 106
iCAN_ID 100,
iCAN_ID 108
iCAN_ID 20210
iCAN_ID 11007
service.d2hub.name
D2Hub service name, retrieved from D2Hub
iCAN_ID 20370
service.d2hub.number
D2Hub service number
iCAN_ID 20371
iCAN_ID 157
shock.event.min.time
Minimum time between two shock alert
iCAN_ID 20386
shock.threshold
Shock detection threshold value
iCAN_ID 20279
iCAN_ID 20278
smartevo.serial.number
SmartEVO serial number
iCAN_ID 20334
iCAN_ID 20393
iCAN_ID 157
TGU-R ID 100,
TGU-R ID 108
total.idle.time
iCAN_ID 20270,
iCAN_ID 216
iCAN_ID 20376
iCAN_ID 20179
iCAN_ID 20269
trip.highway.duration
Highway driving duration during trip
iCAN_ID 20083
trip.highway.duration.ratio
Highway driving duration as a percentage of total trip duration
iCAN_ID 11006
trip.highway.fuel.consumed
Highway fuel consumption during trip
iCAN_ID 20074
trip.highway.mileage
Highway driving distance during trip
iCAN_ID 20077
iCAN_ID 20218
trip.idle.count
Number of idle phases during the trip
iCAN_ID 20209
iCAN_ID 20271
trip.low.speed.count
Number of slow motion phases during the trip
iCAN_ID 20212
trip.low.speed.duration
Time spent in slow motion during the trip
iCAN_ID 20211
trip.low.speed.event.latitude
Latitude of low speed event during the trip
iCAN_ID 20213
trip.low.speed.event.longitude
Longitude of low speed event during the trip
iCAN_ID 20214
trip.low.speed.event.speed
Speed of low speed event during the trip
iCAN_ID 20215
trip.max.engine.coolant.temperature
Max engine coolant temperature
iCAN_ID 20009
iCAN_ID 20010
trip.max.harsh.acceleration
Max harsh acceleration value
iCAN_ID 20015,
iCAN_ID 20109
trip.max.harsh.brake
Max harsh brake value
iCAN_ID 20016,
iCAN_ID 20108
iCAN_ID 20008
iCAN_ID 2010
trip.min.engine.coolant.temperature
iCAN_ID 20017
trip.mixed.duration
Mixed driving duration during trip
iCAN_ID 20082
trip.mixed.duration.ratio
Mixed driving duration as a percentage of total trip duration
iCAN_ID 11005
trip.mixed.fuel.consumed
Mixed fuel consumption during trip
iCAN_ID 20073
trip.mixed.mileage
Mixed driving distance during trip
iCAN_ID 20076
trip.no.fix.duration
iCAN_ID 20383
trip.pto.run.time
Power Take-Off run time during the trip
iCAN_ID 20273
trip.rolling.duration
Rolling duration during the trip
iCAN_ID 20331
trip.rolling.electric.duration
Rolling electric mode duration during the trip
iCAN_ID 20332
trip.rolling.electric.mileage
Rolling electric mode distance during the trip
iCAN_ID 20333
trip.seqnum
Trip count number
iCAN_ID 20092
trip.start.altitude
Trip start altitude
iCAN_ID 289
trip.start.engine.oil.level
Engine oil level at the start of the trip
iCAN_ID 10011
trip.start.fuel.level
Fuel level upon trip start
iCAN_ID 20030
iCAN_ID 200
iCAN_ID 201
trip.start.mileage
Trip start odometer value
iCAN_ID 20045
trip.start.satellites
iCAN_ID 291
iCAN_ID 202,
iCAN_ID 203
trip.start.vehicle.autonomy.mileage
Vehicle autonomy mileage at trip start
iCAN_ID 20113
trip.start.vehicle.battery.level
Vehicle battery level at trip start
iCAN_ID 20110
iCAN_ID 157
trip.stop.altitude
Trip stop altitude
iCAN_ID 290
trip.stop.fuel.level
Fuel level upon trip end
iCAN_ID 20031
iCAN_ID 204
iCAN_ID 205
trip.stop.mileage
Trip end odometer value
iCAN_ID 20046
trip.stop.satellites
iCAN_ID 292
iCAN_ID 206,
iCAN_ID 207
trip.stop.vehicle.autonomy.mileage
Vehicle autonomy mileage at trip end
iCAN_ID 20115
trip.stop.vehicle.battery.level
Vehicle battery level at trip end
iCAN_ID 20112
trip.towing.mileage
Power Take-Off mileage during the trip
iCAN_ID 20377
trip.urban.duration
Urban driving duration during trip
iCAN_ID 20081
trip.urban.duration.ratio
Urban driving duration as a percentage of total trip duration
iCAN_ID 11004
trip.urban.fuel.consumed
Urban fuel consumption during trip
iCAN_ID 20072
trip.urban.mileage
Urban driving distance during trip
iCAN_ID 20075
iCAN_ID 20275
unplug.count
Hot unplug counter
iCAN_ID 20090
TGU-R ID 15,
iCAN_ID 15
