ACTIA TGU-R
The Actia TGU-R is a ruggedized telematics gateway designed for harsh environments, offering multi-communication channels including 2G/3G/4G LTE, Wi-Fi, and Bluetooth. It features advanced cybersecurity, data logging, and GNSS support with GPS, GLONASS, BEIDOU, and GALILEO. The device supports CAN, LIN, RS232, and 1-wire interfaces, and is powered by a 32-bit ARM CPU with optional HSM. It is IP67/IP69k rated, operates in extreme temperatures, and is backed by ACTIA's expertise in worldwide certification processes. Customizable hardware and software make it adaptable for various applications.
Parameters (227)
ACTIA TGU-R
Flespi parses telemetry data from your ACTIA TGU-R into a standardized JSON and lets you send commands to ACTIA TGU-R via API.
    "device.type.id": "ACTIA TGU-R",
    "protocol.id": "actia"
iCAN_ID 20220
accelerometer.state.enum
Accelerometer function status (0: deactivated / 3: activated and calibration pending / 4: activated and calibration done)
iCAN_ID 20219
iCAN_ID 157
iCAN_ID 185,
iCAN_ID 20368
bluetooth.command.name
Bluetooth command name
iCAN_ID 159
bluetooth.mode
Bluetooth mode
iCAN_ID 20362
TGU-R ID 71
can.accelerator.pedal.up.distance
Accelerator pedal up distance from CAN bus
iCAN_ID 337
can.accelerator.pedal.up.duration
Accelerator pedal up time from CAN bus
iCAN_ID 336
can.adblue.refill.mileage
Mileage left until Adblue tank refill
iCAN_ID 20206
TGU-R ID 60,
iCAN_ID 20217
iCAN_ID 20099
can.alternator.status
TGU-R ID 43,
TGU-R ID 44
TGU-R ID 35
TGU-R ID 13
TGU-R ID 63
can.battery.max.voltage
Max Battery voltage from CAN bus
iCAN_ID 268
can.battery.min.voltage
Min Battery voltage from CAN bus
iCAN_ID 267
can.battery.regeneration.duration
Battery regeneration duration,read from CAN bus
iCAN_ID 20173
can.battery.regeneration.mileage
Battery regeneration mileage,read from CAN bus
iCAN_ID 20172
can.carbon.dioxide.exhausted
iCAN_ID 20253
can.connection.type
Type of service (OBD, OEM specific, etc...)
iCAN_ID 20066
can.diagnostic.attempt
Diagnostic attempt status at start of service (1: Diag attempted / 0: Diag not attempted)
iCAN_ID 20339
can.dpf.regeneration.active.duration
Duration of DPF regeneration in active mode
iCAN_ID 20181
can.dpf.regeneration.passive.duration
Duration of DPF regeneration in passive mode
iCAN_ID 20182
TGU-R ID 72
can.engine.cylinders.count
Number of Cylinders read from CAN bus
iCAN_ID 20129
TGU-R ID 54
can.engine.inappropriate.start.count
Enginge inappropriate start count from CAN bus
iCAN_ID 20069
TGU-R ID 14,
iCAN_ID 14,
iCAN_ID 20268
can.engine.oil.max.temperature
Maximum engine oil temperature, read from CAN bus
TGU-R ID 65,
iCAN_ID 20019
can.engine.oil.min.temperature
Minimum engine oil temperature, read from CAN bus
iCAN_ID 20018
TGU-R ID 61,
TGU-R ID 73
TGU-R ID 10,
iCAN_ID 10
can.engine.start.count
iCAN_ID 212
TGU-R ID 34,
iCAN_ID 34
can.excess.battery.voltage.count
Excess battery voltage count read from CAN bus
iCAN_ID 542
can.excess.battery.voltage.distance
Excess battery voltage distance read from CAN bus
iCAN_ID 544
can.excess.battery.voltage.duration
Excess battery voltage duration read from CAN bus
iCAN_ID 543
can.excess.engine.coolant.temperature.count
Excess engine coolant temperature count read from CAN bus
iCAN_ID 516
can.excess.engine.coolant.temperature.distance
Excess engine coolant temperature drive distance read from CAN bus
iCAN_ID 518
can.excess.engine.coolant.temperature.duration
Excess engine coolant temperature duration read from CAN bus
iCAN_ID 517
can.excess.engine.oil.temperature.count
Excess engine oil temperature count read from CAN bus
iCAN_ID 524
can.excess.engine.oil.temperature.distance
Excess engine oil temperature distance read from CAN bus
iCAN_ID 526
can.excess.engine.oil.temperature.duration
Excess engine oil temperature duration read from CAN bus
iCAN_ID 525
can.excess.engine.rpm.count
Excess engine RPM count read from CAN bus
iCAN_ID 506
can.excess.engine.rpm.distance
Excess engine RPM drive distance read from CAN bus
iCAN_ID 508
can.excess.engine.rpm.duration
Excess engine RPM duration read from CAN bus
iCAN_ID 507
can.excess.speed.count
Excess vehicle speed count read from CAN bus
iCAN_ID 503
can.excess.speed.distance
Excess vehicle speed drive distance read from CAN bus
iCAN_ID 505
can.excess.speed.duration
Excess vehicle speed duration read from CAN bus
iCAN_ID 504
can.excess.throttle.count
Excess throttle count read from CAN bus
iCAN_ID 500
can.excess.throttle.distance
Excess throttle drive distance read from CAN bus
iCAN_ID 502
can.excess.throttle.duration
Excess throttle duration read from CAN bus
iCAN_ID 501
can.fault.reading.abs.esp.status
ABS/ESP fault reading status read from CAN bus
iCAN_ID 20128
can.fault.reading.airbag.status
Airbag fault reading status read from CAN bus
iCAN_ID 20125
can.fault.reading.central.ecu.status
Central ECU fault reading status read from CAN bus
iCAN_ID 20126
can.fault.reading.dashboard.status
Dashboard fault reading status read from CAN bus
iCAN_ID 20124
can.fault.reading.gearbox.status
Gearbox fault reading status read from CAN bus
iCAN_ID 20121
can.fault.reading.headlights.status
Headlights fault reading status read from CAN bus
iCAN_ID 20122
can.fault.reading.injection.status
Injection fault reading status read from CAN bus
iCAN_ID 20119
TGU-R ID 3,
iCAN_ID 20120
can.fault.reading.power.steering.status
Power steering fault reading status read from CAN bus
iCAN_ID 20123
can.fault.reading.tire.ecu.status
Tire ECU fault reading status read from CAN bus
iCAN_ID 20127
TGU-R ID 7,
iCAN_ID 8
TGU-R ID 55
iCAN_ID 20067
can.fuel.injection.cut.distance
Distance with injection cut-off from CAN bus
iCAN_ID 273
can.fuel.injection.cut.duration
Duration with injection cut-off from CAN bus
iCAN_ID 272
TGU-R ID 9,
iCAN_ID 20384,
iCAN_ID 9
iCAN_ID 2009
iCAN_ID 20385
TGU-R ID 48
can.harsh.acceleration.count
Harsh Accel count read from CAN bus
iCAN_ID 513
can.harsh.brake.count
Harsh Brake count read from CAN bus
iCAN_ID 512
can.nox.absorber.desulfurization.duration
Duration of NOX absorber desulfurization
iCAN_ID 20184
can.nox.absorber.regeneration.duration
Duration of NOX absorber regeneration
iCAN_ID 20183
can.nox.exhausted
mg
Amount of NOx emitted during the journey
iCAN_ID 20252
CAN at least one PTO engaged
TGU-R ID 56
can.pto.run.time
iCAN_ID 20272
TGU-R ID 4
TGU-R ID 41,
TGU-R ID 42
iCAN_ID 10025,
iCAN_ID 20192
can.service.start.battery.voltage
Battery voltage at start of service from CAN bus
iCAN_ID 245
can.service.start.tell.tale.state
Tell-tale status at the start of service
iCAN_ID 243
can.service.stop.battery.voltage
Battery voltage at end of service from CAN bus
iCAN_ID 246
can.service.stop.tell.tale.state
Tell-tale status at the end of service
iCAN_ID 244
iCAN_ID 10015,
iCAN_ID 20193
TGU-R ID 33
iCAN_ID 221
TGU-R ID 66
can.vehicle.autonomy.mileage
Vehicle autonomy mileage, read from CAN bus
iCAN_ID 20114
iCAN_ID 20111
TGU-R ID 19,
iCAN_ID 19
TGU-R ID 2
iCAN_ID 20033
TGU-R ID 153,
iCAN_ID 153
iCAN_ID 157
ecu.error.code
ECU error code
iCAN_ID 802,
iCAN_ID 803
iCAN_ID 157
event.name
Protocol-specific event name
iCAN_ID 157
iCAN_ID 20093
iCAN_ID 157
TGU-R ID 57
TGU-R ID 59
TGU-R ID 58
iCAN_ID 20058
fuel.consumed.algorithm
Algorithm used to calculate fuel usage
iCAN_ID 20085
fuel.consumed.diesel
Fuel volume totally consumed by vehicle counted by Diesel algorithm
iCAN_ID 20087,
iCAN_ID 20088
fuel.consumed.gasoline
Fuel volume totally consumed by vehicle counted by Gasoline algorithm
iCAN_ID 20086
gnss.fix.duration
iCAN_ID 20381
gsm.network.name
iCAN_ID 20349
iCAN_ID 20350
iCAN_ID 20229
iCAN_ID 20230
iCAN_ID 20032
harsh.acceleration.distance
Harsh acceleration distance
iCAN_ID 20107
harsh.acceleration.duration
Harsh acceleration event duration
iCAN_ID 20105
iCAN_ID 157
harsh.brake.distance
Harsh brake distance
iCAN_ID 20106
harsh.brake.duration
Harsh brake duration
iCAN_ID 20104
iCAN_ID 157
iCAN_ID 157
harsh.event.latitude
Latitude at the end of the harsh event
iCAN_ID 20189
harsh.event.longitude
Longitude at the end of the harsh event
iCAN_ID 20190
harsh.event.speed
Speed at the end of the harsh event
iCAN_ID 20191
iCAN_ID 157
iCAN_ID 157
key.switch.state
Key switch state: -1 = Invalid, 0 = Key Off, 1 = Key On
iCAN_ID 157
low.speed.event
Low speed detected
iCAN_ID 157
iCAN_ID 20380
message.seqnum
iCAN_ID 32767
message.type.enum
Message Type
iCAN_ID 20361
iCAN_ID 157
TGU-R ID 105,
iCAN_ID 105
TGU-R ID 107,
iCAN_ID 107
position.fix.enum
iCAN_ID 103
iCAN_ID 20378
TGU-R ID 101,
iCAN_ID 101
TGU-R ID 102,
iCAN_ID 102
TGU-R ID 104,
iCAN_ID 104
TGU-R ID 106,
iCAN_ID 106
iCAN_ID 100,
iCAN_ID 108
iCAN_ID 20210
iCAN_ID 11007
service.d2hub.name
D2Hub service name, retrieved from D2Hub
iCAN_ID 20370
service.d2hub.number
D2Hub service number
iCAN_ID 20371
iCAN_ID 157
shock.event.min.time
Minimum time between two shock alert
iCAN_ID 20386
shock.threshold
Shock detection threshold value
iCAN_ID 20279
iCAN_ID 20278
smartevo.serial.number
SmartEVO serial number
iCAN_ID 20334
iCAN_ID 20393
iCAN_ID 157
TGU-R ID 100,
TGU-R ID 108
total.idle.time
iCAN_ID 20270,
iCAN_ID 216
iCAN_ID 20376
iCAN_ID 20179
iCAN_ID 20269
trip.highway.duration
Highway driving duration during trip
iCAN_ID 20083
trip.highway.duration.ratio
Highway driving duration as a percentage of total trip duration
iCAN_ID 11006
trip.highway.fuel.consumed
Highway fuel consumption during trip
iCAN_ID 20074
trip.highway.mileage
Highway driving distance during trip
iCAN_ID 20077
iCAN_ID 20218
trip.idle.count
Number of idle phases during the trip
iCAN_ID 20209
iCAN_ID 20271
trip.low.speed.count
Number of slow motion phases during the trip
iCAN_ID 20212
trip.low.speed.duration
Time spent in slow motion during the trip
iCAN_ID 20211
trip.low.speed.event.latitude
Latitude of low speed event during the trip
iCAN_ID 20213
trip.low.speed.event.longitude
Longitude of low speed event during the trip
iCAN_ID 20214
trip.low.speed.event.speed
Speed of low speed event during the trip
iCAN_ID 20215
trip.max.engine.coolant.temperature
Max engine coolant temperature
iCAN_ID 20009
iCAN_ID 20010
trip.max.harsh.acceleration
Max harsh acceleration value
iCAN_ID 20015,
iCAN_ID 20109
trip.max.harsh.brake
Max harsh brake value
iCAN_ID 20016,
iCAN_ID 20108
iCAN_ID 20008
iCAN_ID 2010
trip.min.engine.coolant.temperature
iCAN_ID 20017
trip.mixed.duration
Mixed driving duration during trip
iCAN_ID 20082
trip.mixed.duration.ratio
Mixed driving duration as a percentage of total trip duration
iCAN_ID 11005
trip.mixed.fuel.consumed
Mixed fuel consumption during trip
iCAN_ID 20073
trip.mixed.mileage
Mixed driving distance during trip
iCAN_ID 20076
trip.no.fix.duration
iCAN_ID 20383
trip.pto.run.time
Power Take-Off run time during the trip
iCAN_ID 20273
trip.rolling.duration
Rolling duration during the trip
iCAN_ID 20331
trip.rolling.electric.duration
Rolling electric mode duration during the trip
iCAN_ID 20332
trip.rolling.electric.mileage
Rolling electric mode distance during the trip
iCAN_ID 20333
trip.seqnum
Trip count number
iCAN_ID 20092
trip.start.altitude
Trip start altitude
iCAN_ID 289
trip.start.engine.oil.level
Engine oil level at the start of the trip
iCAN_ID 10011
trip.start.fuel.level
Fuel level upon trip start
iCAN_ID 20030
iCAN_ID 200
iCAN_ID 201
trip.start.mileage
Trip start odometer value
iCAN_ID 20045
trip.start.satellites
iCAN_ID 291
iCAN_ID 202,
iCAN_ID 203
trip.start.vehicle.autonomy.mileage
Vehicle autonomy mileage at trip start
iCAN_ID 20113
trip.start.vehicle.battery.level
Vehicle battery level at trip start
iCAN_ID 20110
iCAN_ID 157
trip.stop.altitude
Trip stop altitude
iCAN_ID 290
trip.stop.fuel.level
Fuel level upon trip end
iCAN_ID 20031
iCAN_ID 204
iCAN_ID 205
trip.stop.mileage
Trip end odometer value
iCAN_ID 20046
trip.stop.satellites
iCAN_ID 292
iCAN_ID 206,
iCAN_ID 207
trip.stop.vehicle.autonomy.mileage
Vehicle autonomy mileage at trip end
iCAN_ID 20115
trip.stop.vehicle.battery.level
Vehicle battery level at trip end
iCAN_ID 20112
trip.towing.mileage
Power Take-Off mileage during the trip
iCAN_ID 20377
trip.urban.duration
Urban driving duration during trip
iCAN_ID 20081
trip.urban.duration.ratio
Urban driving duration as a percentage of total trip duration
iCAN_ID 11004
trip.urban.fuel.consumed
Urban fuel consumption during trip
iCAN_ID 20072
trip.urban.mileage
Urban driving distance during trip
iCAN_ID 20075
iCAN_ID 20275
unplug.count
Hot unplug counter
iCAN_ID 20090
TGU-R ID 15,
iCAN_ID 15
