Albatross GPRS S8.3
Albatross GPRS S8.3 is a 3G/LTE-M GPS tracker with multiple connectivity and integration options and CAN bus support. The device features 3 analog inputs, 2 open collector outputs, 2 reacting to mass inputs, RS-232-TTL (optional RS-232, RS-485), 1-Wire support, optional 550mAh internal battery, support for Mobileye technology, full MIDAS MOVON solutions support, cost control of the SIM card, and more.
Parameters (75)
Albatross GPRS S8.3
Flespi parses telemetry data from your Albatross GPRS S8.3 into a standardized JSON and lets you send commands to Albatross GPRS S8.3 via API.
    "device.type.id": "Albatross GPRS S8.3",
    "protocol.id": "albatross"
How to send commands to Albatross GPRS S8.3?
can.alternative.fuel.level
Alternative fuel level read from CAN
can.eco.accelerator.range
Range for accelerator parameter for Eco driving, CAN data
can.eco.brake.range
Range of brake parameter for Eco driving, CAN data
can.eco.engine.rpm.range
Range for engine speed parameter for Eco driving, CAN data
can.eco.pedal.range
Range of pedal press for Eco driving, CAN data
can.eco.speed.range
Range for speed parameter for Eco driving, CAN data
can.hydraulic.oil.temperature
Hydraulic oil temperature read form CAN
Tracking parameters setup
{"payload":"$AL+TRACKING=0000,7,15,500,0,1,3"}
Activate digital output 2 for 50 ms
{"payload":"$AL+OUTS=0000,2,1,50,0"}
