Cantrack G900LS
G900LS-4G Car GPS Tracker is a global 4G vehicle tracker supporting real-time tracking via app or platform. It features movement and ignition alarms, speeding and ACC detection, power cut alarm with internal battery, and optional fuel or electricity disable. The device operates on LTE/GSM/GPRS networks, with a location accuracy of less than 5 meters and a working voltage of 9-90VDC. It includes a 150mAh Li-Polymer backup battery and supports GT06 series protocol.
Parameters (95)
Cantrack G900LS
Flespi parses telemetry data from your Cantrack G900LS into a standardized JSON and lets you send commands to Cantrack G900LS via API.
    "device.type.id": "Cantrack G900LS",
    "protocol.id": "cantrack"
How to send commands to Cantrack G900LS?
Protocol Number 0x16
Alarm bit 0x01 of Protocol Number 0x15,
Extended bit 0x04 of Protocol Number 0x16
Additional info ID 0x06,
Command *HTBT,
Alarm sign bitmask,
Command *V1,
Command *V2,
Command *V3,
Command *V4,
Command *V5,
Extended bit 0x03 of Protocol Number 0x16
Command *V3,
Command *V5
Alarm bit 0x13 of Protocol Number 0x15,
Alarm bit 0x13 of Protocol Number 0x16
Alarm bit 0x09 of Protocol Number 0x15,
Command *V1,
Command *V2,
Command *V3,
Command *V4,
Command *V5
Alarm bit 0x14 of Protocol Number 0x15,
Alarm bit 0x14 of Protocol Number 0x16
Alarm bit 0xFE of Protocol Number 0x15,
Alarm bit 0xFF of Protocol Number 0x15,
Command *V1,
Command *V2,
Command *V3,
Command *V4,
Command *V5,
Alarm bit 0x0E of Protocol Number 0x15,
Alarm bit 0x0E of Protocol Number 0x16
Sub protocol number 0x00 of Protocol Number 0x94
Alarm bit 0x04 of Protocol Number 0x15,
Alarm bit 0x05 of Protocol Number 0x15,
Alarm bit 0x05 of Protocol Number 0x16
Additional info ID 0x5D,
Command *V3,
Command *V3,
Command *V3,
Command *V3,
Command *V3
Command *V3,
Command *ICCID,
Sub protocol number 0x0A of Protocol Number 0x94
Alarm bit 0xF0 of Protocol Number 0x13,
Alarm bit 0xF0 of Protocol Number 0x15,
Alarm bit 0xF0 of Protocol Number 0x16,
Alarm bit 0xF1 of Protocol Number 0x13,
Alarm bit 0xF1 of Protocol Number 0x15,
Alarm bit 0xF1 of Protocol Number 0x16,
Alarm bit 0x19 of Protocol Number 0x15,
Alarm bit 0x19 of Protocol Number 0x16
Alarm bit 0x06 of Protocol Number 0x15,
Alarm bit 0x06 of Protocol Number 0x16
Command *V1,
Command *V2,
Command *V4,
Command *V1,
Command *V2,
Command *V4,
Command *V1,
Command *V2,
Command *V4,
Command *V1,
Command *V2,
Command *V4,
Command *V1,
Command *V2,
Command *V4,
Alarm bit 0x02 of Protocol Number 0x15,
Alarm sign bitmask,
Extended bit 0x02 of Protocol Number 0x16
rear.light.status
Rear light status
Command *V1,
Command *V2,
Command *V3,
Command *V4,
Command *V5,
Additional info ID 0x01,
Command *V1,
Command *V2,
Command *V3,
Command *V4,
Command *V5
Command *V1,
Command *V2,
Command *V3,
Command *V4,
Command *V5
Alarm bit 0x03 of Protocol Number 0x15,
Command *V1,
Command *V2,
Command *V3,
Command *V4,
Command *V5,
Extended bit 0x01 of Protocol Number 0x16
Command *V5
Command *V5
Additional info ID 0x05
Send custom command to device, Scheme: "*,,#". You have to specify payload only
Cut fuel for stop car, model G06L
{"payload":"CMD,130305,stop654321"}
Set working mode 1, models GF40, GF50, GF60, GF70L
{"payload":"MD123456 1 3 8 1"}
Set Center number command S2, models TK100, TK100B, G05
{"payload":"S2,130305,13812341234"}
More devices from Shenzhen Cantrack Technology Co., Ltd (14)
Tags
Cantrack C32
cantrack
Cantrack G05
cantrack
Cantrack G08L
cantrack
Cantrack G09L
cantrack
Cantrack GF40
cantrack
Cantrack GF60
cantrack
Cantrack GF60L
cantrack
Cantrack GF70L
cantrack
Cantrack P60L
cantrack
