Globalstar SmartOne C
Globalstar SmartOne C is a compact, feature-rich asset tracker for intelligent management of assets. It supports battery and line power, uses GPS and motion sensors for accurate tracking, and sends automatic alerts if assets move outside a set range. The device features a low-power profile, quick installation, customizable reports, and Global LEO Satellite communication through the Globalstar Network. It offers operational efficiency with lightweight monitoring and has a rugged, weatherproof IP68-rated design.
Parameters (35)
Flespi parses telemetry data from your Globalstar SmartOne C into a standardized JSON and lets you send commands to Globalstar SmartOne C via API.
    "device.type.id": "Globalstar SmartOne C",
    "protocol.id": "globalstar"
changed.din
DIN changed status, indexed parameter
gnss.fail.count
Number of times the GNSS has failed to obtain a valid fix
gnss.fix.duration
missed.din
State change of the input was missed due to the transmission of a higher priority message, indexed parameter
position.fix.type
scheduler.status
Scheduler operational status
send.timestamp
Message send timestamp
transmission.count
Overall transmission count since last Diagnostic message
transmission.min.interval
Minimum transmission interval
transmitter.status
Transmitter operational status
vibration.status
