Iridium Teltonika
Iridium Teltonika is a Teltonika device that utilizes Iridium Edge modem to deliver data packets to flespi via satellite communication. User-defined payload within Iridium Teltonika is parsed according to specific Teltonika protocol.
Iridium Edge is a cost-effective satellite IoT communications device with an all-in-one SBD module, antenna, and power supply. The plug-and-play satellite IoT terminal can be easily paired with FMB devices in order to expand their functionality to no GSM coverage zones. Current Iridium implementation offers the ability to generate and send SBD records after set period after the GSM signal is lost. This ensures constant connectivity for the clients as Iridium network is available globally.
Check more details here: https://wiki.teltonika-gps.com/view/Iridium_Edge
Parameters (31)
Iridium Teltonika
Flespi parses telemetry data from your Iridium Teltonika into a standardized JSON and lets you send commands to Iridium Teltonika via API.
    "device.type.id": "Iridium Teltonika",
    "protocol.id": "iridium"
can.8bit.value
Custom 8bit CAN value
Information Element 0x02
Information Element 0x01,
iridium.cep
Iridium Circular Error Probability radius
Information Element 0x03
iridium.position.latitude
Iridium position latitude
iridium.position.longitude
Iridium position longitude
sbd.event.enum
SBD event code
session.seqnum
Iridium CDR Reference(Auto ID)
session.state.enum
Iridium session state
session.timestamp
Iridium session duration
user.data.value
User data value
