Syrus 3G+
The DCT Syrus 3G+ is a hardwired vehicle fleet telematics hub by Digital Communications Technologies (DCT), designed for IoT/M2M applications. It features 3G UMTS/HSPA+ penta-band connectivity, an integrated GPS receiver (MTK MT3339, 66 channels), and an IP65 sealed polycarbonate enclosure for water and dust resistance. The device includes a built-in rechargeable 250mA Polymer Li-Ion backup battery, RS232 serial interface, and a 1-Wire bus for iButton driver identification. A 3-axis ±16G digital accelerometer enables motion, shock, and aggressive driving detection. Operating on 8–32VDC vehicle power, it supports up to 100 geofences, OTA configuration, multiple accessory ports, and integrates with DCT's Pegasus Gateway REST API platform.
Parameters (161)
Syrus 3G+
Flespi parses telemetry data from your Syrus 3G+ into a standardized JSON and lets you send commands to Syrus 3G+ via API.
    "device.type.id": "Syrus 3G+",
    "protocol.id": "dct-syrus"
How to send commands to Syrus 3G+?
Report EV
acknowledgement.time
Acknowledge time. It is an accumulative time counter that it is incremented with the time that the application waits for the acknowledge of an event triggered
Report EV
Report EV,
backup.battery.status
Backup battery usage status
Report EV
Report EV
bytes.received
Number of bytes received by the device
Report EV
bytes.sent
Number of bytes transmitted by the device
Report EV
Report GTASC
Report GTASC
Report GTASC
Report GTASC
Report GTASC
Report GTASC
Report GTASC
Report GTASC
Report GTASC
counter.over.rpm
Value of over rpm counter
Report EV
counter.overspeeding
Value of over speed counter
Report EV
counter.value
Current value of counter
Report EV
Report GTCRG
Report GTASP,
Report GTSSP,
Report GTTSP,
Report RESP
device.tamper.status
Report EV
Report EV
Report EV,
Report EV,
dout.short.circuit.status
Short circuit status for digital output
Report EV
Report EV,
Report EV,
error.code
Operation error code
Report ER
error.command
Configuration command that generated an error
Report ER
event.definition
Event definition
Report ED,
Report EV
Report EV,
Report TX
Report EV,
Report GTGSS
gprs.bearer.count
GPRS Bearer counter. Number of times that the GPRS bearer has changed from down to up
Report EV
gprs.count
GPRS counter. Number of times that the device has registered on GPRS network
Report EV
Report EV,
gsm.count
Mobile network (GSM, 3G, 4G, LTE, 5G, ...) counter. Number of times that the device has registered on the network
Report EV
Report EV,
Report EV,
Report EV,
Report EV,
Report EV
Report EV
Report EV
Report BUFF,
Report RESP
Report EV,
Report GTSTT
Report EV
packets.sent
Report EV
Report TX
Report EV,
position.corrected.status
Report EV,
Report TX
Report EV,
Report TX
position.fix.type
Report EV,
Report TX
Report EV,
Report EV,
Report TX
Report EV,
Report TX
Report EV
Report EV,
Report EV,
Report TX
Report EV
Report GTPNA
Report ACK,
Report BUFF,
Report RESP
Report BUFF,
Report GTASP,
Report GTSSP,
Report GTTSP,
Report RESP
Report GTTOW
retransmission.count
Retransmissions counter. Number of retries for transmitting events when the device does not received an ACK from server
Report EV
safe.shutdown.state
Safe shutdown state
Report GTSEI
Report GTASC
signal.name
Signal name
Report EV
signal.state
Current signal state
Report EV
signal.threshold
Signal threshold exceed
Report EV
signal.value
Current value of the variable associated with signal
Report EV
Report ACK,
Report BUFF,
Report EV,
Report RESP
Report ACK,
Report BUFF,
Report RESP
total.idle.time
Report EV
Report GTSTT
vehicle.altitude.change
Altitude change trend of the vehicle: 0: Unknown, 1: Vehicle going downhill, 2: There aren't significant altitude changes, 3: Vehicle going uphill
Report EV
Report GTASP,
Report GTSSP,
Report GTTSP,
vehicle.odometer
Report EV
vehicle.speed
Vehicle speed
Report EV
Report GTSTT
Report GTEPS
x.axis.angle
X-axis angle to horizon
Report EV
x.reference.angle
X-axis reference angle, the calibrated baseline orientation the current angle is measured against
Report EV
y.axis.angle
Y-axis angle to horizon
Report EV
y.reference.angle
Y-axis reference angle, the calibrated baseline orientation the current angle is measured against
Report EV
z.axis.angle
Z-axis angle to horizon
Report EV
z.reference.angle
Z-axis reference angle, the calibrated baseline orientation the current angle is measured against
Report EV
