Topflytech WarriorX 300
WarriorX 300 is a robust, waterproof asset tracker designed for outdoor usage with a long battery life of over 6 years. It features flexible reporting intervals, an IP67 waterproof rating, removal alerts, easy installation options, LTE connectivity for reliable data transmission, and integrated GNSS capabilities for accurate positioning using GPS, Glonass, Beidou, and Galileo systems.
Parameters (185)
Settings (10)
Flespi parses telemetry data from your Topflytech WarriorX 300 into a standardized JSON and lets you send commands to Topflytech WarriorX 300 via API.
    "device.type.id": "Topflytech WarriorX 300",
    "protocol.id": "topflytech"
How to send commands to Topflytech WarriorX 300?
Message Type 0x16,
Message Type 0x18
accident.event
Accident event detected
Message Type 0x07
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x18,
Message Type 0x62,
Message Type 0x64
Message Type 0x27,
Message Type 0x64
Alarm Code 3,
Alarm Type 3,
Message Type 0x10,
Message Type 0x12
alarm.time
Message Type 0x13,
Message Type 0x14
Alarm Code 116,
Alarm Code 117,
Alarm Type 16
Message Type 0x02,
Message Type 0x04,
Message Type 0x16,
Message Type 0x18
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x18,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x62,
Message Type 0x64
Alarm Code 6,
Alarm Code 7,
Alarm Type 2,
Alarm Type 36
battery.type
Message Type 0x02,
Message Type 0x24,
Message Type 0x25
Message Type 0x02,
Message Type 0x13,
Message Type 0x14,
Message Type 0x27,
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x10,
Message Type 0x12
Message Type 0x27
Alarm Code 35,
Alarm Code 4
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
can.alternator.error
Message Type 0x62,
Message Type 0x64
can.alternator.status
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
can.doors.position.enum
Message Type 0x62,
Message Type 0x64
can.doors.status2.enum
Message Type 0x62,
Message Type 0x64
Message Type 0x09
Message Type 0x09
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x18,
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x18
Message Type 0x13,
Message Type 0x14,
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x16,
Message Type 0x18,
Message Type 0x62,
Message Type 0x64
Message Type 0x13,
Message Type 0x14,
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x18,
Message Type 0x62,
Message Type 0x64
can.fuel.rate
Fuel rate read from CAN
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x16,
Message Type 0x18
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x16,
Message Type 0x18
Message Type 0x02,
Message Type 0x04,
Message Type 0x16,
Message Type 0x18
Message Type 0x02,
Message Type 0x04,
Message Type 0x16,
Message Type 0x18
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
can.pto.run.time
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
can.ramp.position.enum
Message Type 0x62,
Message Type 0x64
can.retarder.selection
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
can.retarder.torque.mode
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x16,
Message Type 0x18
Message Type 0x62,
Message Type 0x64
Message Type 0x13,
Message Type 0x14
Message Type 0x62,
Message Type 0x64
case.status
Case opened status
Alarm Code 2,
Alarm Code 22,
Alarm Code 34
crash.status
Alarm Code 10,
Alarm Code 16,
Alarm Code 27,
Alarm Code 39
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x09,
Message Type 0x10,
Message Type 0x11,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x15,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x21,
Message Type 0x22,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x44,
Message Type 0x62,
Message Type 0x64,
Message Type 0x81
device.state.bitmask
Device state bitmask
Message Type 0x27
Message Type 0x02,
Message Type 0x13,
Message Type 0x14,
Message Type 0x24,
Message Type 0x25,
Message Type 0x62,
Message Type 0x64
Alarm Code 25,
Alarm Code 37,
Alarm Code 8
device.temperature.low.status
Alarm Code 30,
Alarm Code 31,
Alarm Code 48,
Alarm Code 49
device.wifi.mac.address
Message Type 0x15,
Message Type 0x24,
Message Type 0x25
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x18,
Message Type 0x62,
Message Type 0x64
displacement.status
Alarm Code 1,
Alarm Code 21,
Alarm Code 33
Message Type 0x13,
Message Type 0x14,
Message Type 0x62,
Message Type 0x64
Message Type 0x10,
Message Type 0x12
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x18
Alarm Code 22,
Alarm Code 23,
Bit14 of Digital I/O status,
Bit2 of Status,
Message Type 0x02,
Message Type 0x04,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x18,
Message Type 0x21,
Message Type 0x23,
Message Type 0x62,
Message Type 0x64
Message Type 0x13,
Message Type 0x14
Message Type 0x09
Message Type 0x02,
Message Type 0x13,
Message Type 0x16,
Message Type 0x18,
Message Type 0x24,
Message Type 0x25
Alarm Type 1,
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x18,
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x18,
Message Type 0x62,
Message Type 0x64
Alarm Code 24,
Alarm Code 36,
Alarm Code 5
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x16,
Message Type 0x18
Message Type 0x62,
Message Type 0x64
Alarm Code 14,
Alarm Code 15,
Alarm Code 20,
Alarm Code 21,
Alarm Type 5,
Alarm Type 6
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
gps.signal.level
GPS signal level
Message Type 0x27
gsm.band.name
Mobile network (GSM, 3G, 4G, LTE, 5G, ...) band name as reported by the device
Message Type 0x05,
Message Type 0x11
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x62,
Message Type 0x64
Alarm Code 102,
Alarm Code 103,
Alarm Code 66,
Alarm Code 67,
Alarm Type 33,
Alarm Type 34
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x62,
Message Type 0x64
gsm.network.name
Message Type 0x05,
Message Type 0x11
Message Type 0x05,
Message Type 0x11
gsm.pcid
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x18,
Message Type 0x62,
Message Type 0x64
Message Type 0x05,
Message Type 0x11
Message Type 0x05,
Message Type 0x11
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x09,
Message Type 0x10,
Message Type 0x11,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x15,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x21,
Message Type 0x22,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x44,
Message Type 0x62,
Message Type 0x64,
Message Type 0x81
Message Type 0x05,
Message Type 0x06
Message Type 0x05,
Message Type 0x06
Message Type 0x06
Alarm Code 78
Message Type 0x23
Alarm Code 18,
Alarm Code 19,
Alarm Code 24,
Alarm Code 25,
Alarm Type 25,
Alarm Type 32,
Message Type 0x62,
Message Type 0x64
Alarm Code 23,
Alarm Code 4
light.sensor.voltage
Front light sensor voltage
Message Type 0x02
lock.data
Lock data in HEX format
Message Type 0x17
lock.state
Message Type 0x02,
Message Type 0x17,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27
Message Type 0x44
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x23,
Message Type 0x27
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x09,
Message Type 0x10,
Message Type 0x11,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x15,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x21,
Message Type 0x22,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x44,
Message Type 0x62,
Message Type 0x64,
Message Type 0x81
movement.distance
Message Type 0x13
Alarm Type 8
Alarm Code 16,
Alarm Code 17,
Alarm Code 22,
Alarm Code 23,
Message Type 0x02
nfc.code
NFC card code (UID)
Message Type 0x27
onewire.payload.hex
Message Type 0x23
Message Type 0x23
Alarm Code 112,
Alarm Code 113,
Alarm Code 57,
Alarm Code 70,
Alarm Code 71,
Alarm Type 4,
Alarm Type 41,
Message Type 0x05
Message Type 0x81
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x62,
Message Type 0x64
Message Type 0x13,
Message Type 0x14,
Message Type 0x24,
Message Type 0x25,
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x62,
Message Type 0x64
Alarm Code 29
Alarm Code 20
Alarm Code 32,
Alarm Code 41
Message Type 0x23
Message Type 0x21
Message Type 0x21
sensor.mac.address
External sensor MAC address
Message Type 0x27
Message Type 0x27
solar.panel.charging.status
Solar panel charging device
Message Type 0x02,
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x27
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
Message Type 0x62,
Message Type 0x64
tilt.status
Alarm Code 11,
Alarm Code 17,
Alarm Code 28,
Alarm Code 40
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x09,
Message Type 0x10,
Message Type 0x11,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x15,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x21,
Message Type 0x22,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x44,
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x09,
Message Type 0x10,
Message Type 0x11,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x15,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x21,
Message Type 0x22,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x44,
Message Type 0x62,
Message Type 0x64,
Message Type 0x81
time.valid.status
Time is accurate
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x09,
Message Type 0x10,
Message Type 0x11,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x15,
Message Type 0x16,
Message Type 0x17,
Message Type 0x18,
Message Type 0x21,
Message Type 0x22,
Message Type 0x23,
Message Type 0x24,
Message Type 0x25,
Message Type 0x27,
Message Type 0x44,
Message Type 0x62,
Message Type 0x64
Alarm Code 113,
Alarm Code 114,
Alarm Code 119,
Alarm Code 72,
Alarm Code 77,
Alarm Type 7
Alarm Code 79
usb.connection.status
Alarm Code 12,
Alarm Code 13,
Alarm Code 18,
Alarm Code 19,
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x16,
Message Type 0x18,
Message Type 0x24,
Message Type 0x25,
Message Type 0x62,
Message Type 0x64
Message Type 0x09,
Message Type 0x22
vibration.status
Alarm Code 26,
Alarm Code 38,
Alarm Code 9
Message Type 0x15,
Message Type 0x24,
Message Type 0x25,
Message Type 0x62,
Message Type 0x64
Message Type 0x15,
Message Type 0x24,
Message Type 0x25,
Message Type 0x62,
Message Type 0x64
Message Type 0x02,
Message Type 0x06,
Message Type 0x07,
Message Type 0x24,
Message Type 0x25
Message Type 0x02,
Message Type 0x06,
Message Type 0x07,
Message Type 0x24,
Message Type 0x25
Message Type 0x02,
Message Type 0x06,
Message Type 0x07,
Message Type 0x24,
Message Type 0x25
Detect ACC
accdet
backend_server2
Communication Mode Setup
dmode
report_mode: Report mode
Setup Heartbeat Interval
hbt
Set the device odometer value
mileagec
odometer: Odometer value
Setup Report Workmode
timer
distance: Distance
acc_on_period: ACC ON period
Device Version
modem: Modem Version
firmware: Firmware Version
hardware: Hardware Version
Get device IP2 setting
{"payload":"IP2,2#"}
{"payload":"DMODE,2#"}
