Essentials
The /ai/ module provides programmatic access to flespi capabilities for AI agents.
There are four ways to access flespi AI services:
- MCP servers: for AI agents and IDEs (Claude Code, Cursor, etc.) that support the Model Context Protocol. MCP wraps the tools below with built-in instructions and the ability to execute flespi API calls directly. Two server types are available: one for development workflows and one for support diagnostics.
- REST API tools: standalone HTTP endpoints for scripts, CI/CD pipelines, or any system that needs direct request-response access without MCP. You control context and orchestration.
- AI skills: point your AI agent or IDE to SKILL.md to bootstrap its knowledge about flespi. This is the recommended starting point for agents that need foundational platform context.
- flespi AI agents: skip the integration entirely and let flespi host the agent, an autonomous AI worker living in your account that acts on your behalf, monitors your data, and asks your approval for account-changing operations. With a persona connector such an agent can also face your own customers under your name.
The MCP servers and the REST API tools expose the same set of tools:
| Tool | Credits | Description |
| search-api-methods | 0 | discover flespi REST API methods by natural language query |
| api-method-schema | 0 | retrieve full Swagger schema for a specific API method |
| flespi-api-read | 0 | execute a read-only GET request to the flespi REST API (MCP only) |
| flespi-api-write | 0 | execute a write operation (POST/PUT/PATCH/DELETE) on the flespi REST API (MCP only) |
| search-flespi-documentation | 5 | search flespi platform documentation |
| search-device-documentation | 10 | search device/protocol manufacturer documentation |
| consult-flespi-account | 30 | delegate complex analysis to a flespi platform expert with account read access |
| generate-pvm-code | 10 | generate PVM code from a task description |
| generate-flespi-expression | 2 | generate flespi expressions for selectors, calculators, webhooks, plugins, streams |
| classify-driving-events | 1-10 | classify ADAS/DSM driving events in the video or image of a vehicle camera and verify the ones a device reported |
On the MCP servers three tools are split: generate-pvm-code lives on the develop server only, search-device-documentation and classify-driving-events on the support one.
When choosing between search-flespi-documentation (5 credits) and consult-flespi-account (30 credits):
- use documentation search for general platform questions that can be answered from docs and API specs alone
- use account consultation when the answer requires reading your actual account data: device status, logs, configuration issues, or cross-component analysis
Tools that consume credits also count toward the per-minute ai_calls rate limit. When credits are exhausted the API returns HTTP 403, and when the rate limit is exceeded, HTTP 429.
MCP servers
MCP (Model Context Protocol) is a standard that allows AI agents to discover and use external tools. flespi provides two MCP servers, each tailored for a specific workflow:
- develop: for AI agents building applications on top of flespi. Instructions cover platform entities, API namespaces, and message parameters.
- support: for AI agents diagnosing customer issues, with built-in diagnostic patterns (connectivity checks, data gap analysis, stream failures, permission errors) and investigation guidance.
Both servers additionally expose flespi-api-read and flespi-api-write tools that execute REST API calls with the permissions of the provided token. This means your AI agent can read device messages, check logs, create entities, or send commands, all within the boundaries of the token's ACL.
The recommended way to connect a client is through a realm: the realm owner enables the realm OAuth server and allows the client, then each user signs in and approves access through the realm login flow. No token is created or shared, and the realm's Info tab provides ready integration buttons for Claude Code, Claude, Cursor, VS Code, LM Studio, and Goose. Alternatively, connect directly with a token.
Setup for Claude Code:
claude mcp add flespi "https://flespi.io/ai/mcp/develop" \
-t http -H "Authorization: FlespiToken YOUR_TOKEN"
Generic MCP client configuration (JSON):
"mcpServers": {
"flespi": {
"type": "http",
"url": "https://flespi.io/ai/mcp/develop",
"headers": {
"Authorization": "FlespiToken YOUR_TOKEN"
Replace develop with support for the support agent server.
REST API tools
The same tools are available as standalone REST API endpoints under /ai/tools/. Unlike MCP servers, REST API tools are stateless: each call is independent, and you control the context and orchestration in your application.
Each tool accepts one method: GET for search-api-methods and api-method-schema, POST for the rest. Every tool returns a JSON object with result (text or structured data) and credits (AI credits consumed).
Recommended API discovery workflow for agentic systems:
- Use
search-api-methodsto find relevant endpoints by natural language query. - Use
api-method-schemato retrieve the full Swagger schema with parameters, fields, and selectors. - Call the flespi REST API directly using the discovered method.
API discovery tools (search-api-methods and api-method-schema) are free and instant: AI agents can use them liberally to navigate the flespi API.
For general flespi REST API usage, authentication, and response format details, see flespi API basics.
AI skills
flespi publishes a machine-readable SKILL.md following the Agent Skills specification. The skill file provides AI agents with a compact, token-efficient overview of the flespi platform: core concepts, entity types and relationships, REST API guidelines (methods, selectors, response format), MQTT broker usage, flespi expression syntax, and pointers to further documentation and AI tools.
For detailed lookups beyond the skill file, agents can use the machine-readable sources it points to: OpenAPI specifications for each module (Gateway, Platform, Realm, MQTT, Storage, Auth, AI), the MQTT topics dictionary and the log event codes dictionary. These files are large, so fetch them on demand and filter for the needed entries instead of loading them into context.
Claude Code (plugin)
/plugin marketplace add flespi-software/skills
/plugin install flespi@flespi-software-skills
VS Code / GitHub Copilot
Add to your .vscode/mcp.json:
"inputs": [
"id": "flespiToken",
"type": "promptString",
"description": "Flespi Token",
"password": true
"servers": {
"flespi-develop": {
"type": "http",
"headers": {
"Authorization": "FlespiToken ${input:flespiToken}"
For knowledge context, also copy .github/copilot-instructions.md to your project's .github/ directory.
Cursor
Add to your .cursor/mcp.json:
"mcpServers": {
"flespi-develop": {
"headers": {
"Authorization": "FlespiToken ${FLESPI_TOKEN}"
For knowledge context, also copy .cursorrules to your project root.
Windsurf
Add to your .windsurf/mcp.json:
"mcpServers": {
"flespi-develop": {
"serverUrl": "https://flespi.io/ai/mcp/develop",
"headers": {
For knowledge context, also copy .windsurfrules to your project root.
OpenCode
Copy AGENTS.md to your project root, or add to your opencode.json:
"instructions": ["path/to/skills/flespi/SKILL.md"]
Manual (any agent)
Copy SKILL.md into your agent's context or instructions file. The content is plain Markdown and works with any LLM-based coding assistant. More information on our GitHub page.
AI credits
AI credits are the unit of consumption for flespi AI services: the REST API tools and MCP servers above, and flespi AI agents. Each tool has a fixed credit cost per call, listed in the tools table above. The only exception is classify-driving-events, which is charged by the footage it reviews. An agent consumes 25, 100 or 250 credits per reasoning step depending on its intelligence level: everything inside the step is covered, and its computational processing between steps is free.
Every flespi plan includes free AI credits per month: 2,000 on Free, 3,000 on Start, 5,000 on Pro, 10,000 on Enterprise and 20,000 on Ultimate. When the monthly budget is exhausted:
- Free accounts: AI tool calls stop until the next month, and each agent is blocked once the credits left cannot pay its next step.
- Commercial accounts: additional credits are charged at €1 per 100 credits (per-plan maximum limits exist).
Agents blocked by exhausted credits do not lose their tasks: they resume once the counter recovers. Conversations with the AI assistant in HelpBox chat consume no AI credits.
You can monitor credit usage and rate limits on the AI tile in the flespi panel dashboard or via the /ai/logs endpoint. Credit allocation for subaccounts is configurable through the ai_credits parameter in limit settings. To disable access to AI services for subaccounts you may zero ai_credits and ai_calls settings in their limits.
Token security
The flespi-api-read and flespi-api-write MCP tools execute flespi REST API calls using the permissions of the token you provide. The write tool can create, modify, and delete platform items if the token allows it.
Recommendations:
- Create a dedicated ACL token for each AI agent. ACL tokens deny everything by default, so you explicitly grant access only to the API sections and HTTP methods the agent needs.
- For MCP servers, grant POST access to the
ai/mcpmodule: it opens the MCP session and covers every tool called through it. - For REST API tools, grant GET access to
ai/toolsfor the discovery tools (search-api-methods,api-method-schema) and POST access toai/toolsfor the rest. - Grant the downstream API sections separately:
flespi-api-read,flespi-api-write, andconsult-flespi-accountare checked a second time against the actual path they call, using the same token. - For read-only agents: grant only GET access to the required sections (e.g.,
gw/devices,gw/channels,storage/containers). - Avoid providing Master or Standard tokens to AI agents: these grant broad access that cannot be restricted per-method.
- For realm users, prefer connecting via realm OAuth: access is approved through the realm login flow and no token is shared with the client.
- Set a reasonable TTL or expiration time on the token.
Troubleshooting
All AI operations are recorded to the /ai/logs subsystem with the following event codes:
| Event code | Description |
| 1700 | AI tool call (REST API) |
| 1701 | MCP server activity |
| 1703 | Reasoning step of a flespi AI agent |
| 1710 | AI calls were blocked (credits exhausted or rate limit exceeded) |
| 1711 | AI calls were unblocked |
Each tool call entry contains the tool name, credits consumed, call duration, status code, token ID, and request arguments. Use filter expressions to narrow down the logs, for example:
tool=="search_flespi_documentation": filter by tool namecredits>0: only calls that consumed creditsstatus_code==2: blocked calls and delayed agent stepsduration>10: slow calls (over 10 seconds)event_code==1703&&agent==123: reasoning steps of one agent
AI logs are also accessible in the flespi panel under Toolbox and via MQTT subscription to flespi/log/ai/# topic.
See the tools at work in a video demo: AI integration tools in action.
