How to send data from one flespi account to another?
Establishing secure transfer of parsed messages between accounts.
You may find yourself in a situation when you need to send the telemetry data from one flespi account into another, e.g.:
  • From parent account to child account (learn more about subaccounts)
  • From dev account to prod account
  • From one user account to another user account, etc.
To address such cases we added the flespi-gateway stream and flespi-gateway channel that can be used to transfer data between different flespi accounts via HTTPS.
The process is fairly simple:
  • Create a “flespi-gateway” channel in the receiving account:
    create flespi gateway channel
  • You will need its domain name and port in the stream configuration:
    flespi gateway channel domain name port
  • Create a “flespi-gateway” stream in the account you want to send data from and specify the domain name and port of the receiving “flespi gateway” channel in the configuration:
    flespi gateway stream config
  • Subscribe the stream to the desired sources of data (channels or devices):
    subscribe flespi gateway stream to channel
  • Open the Toolbox tab to see if the stream started to send  messages:
    flespi gateway stream toolbox
  • Open the Toolbox tab for the receiving channel in the different account:
    flespi gateway channel toolbox
  • You should see fresh messages in the Messages pane. Now you can consume them via REST or MQTT API a usual.
Sending telemetry data from flespi to SENT-GEO
