Flow Builder: no-code automations for your trackers
Click together an automation for your trackers: a trigger, a condition, an action. Built by a flespi AI agent, running on standard flespi components
Flow Builder is a web app where you click together an automation for your trackers: when something happens, check a condition, do something. A speed alert to Telegram, a command when the ignition turns on, your tracker messages forwarded to your server, an email when a vehicle leaves an area you draw, a morning list of the trackers that are offline. No code, no AI in the loop: every flow you turn on runs on standard flespi components in your own account and keeps running on its own.
The app is also a showcase of apps built by flespi AI agents: a flespi AI agent developed it from a chat request, release by release, and the flespi team now maintains it as a free tool, provided as is. Open it at db609927971b9a80.flespi.app/apps/flow-builder and sign in with your flespi account. The user guide, written by the same agent with screenshots of the real app, walks you from the first sign-in to a working Telegram speed alert in five minutes.
1. What you can build
A flow has three parts: the trackers it runs on, a trigger, and the steps that follow.
  • when — every new message, a tracker goes offline and comes back, a tracker enters or leaves an area, a trip starts or ends, a condition lasts some minutes, or on a schedule;
  • check and compute — only continue if a parameter meets a condition, calculate a value, if / otherwise branches, check areas, add a street address;
  • act — send a command, change a setting, send to my server, publish to flespi MQTT or another MQTT broker, send to Telegram, send an email, write to the event log, forward to another platform, add an event to the trackers' messages for another flow to pick up.
Flow Builder: drawing an area on the map for an area alert
Templates cover the common cases: a speed alert, data to your server, a command on an event, an offline alert, an area alert. Start from one or from a blank flow, and export a flow to a file to import it elsewhere.
Flow Builder home page with flow templates
2. How to start
Press New flow, pick the trackers, then choose a template or build the steps yourself on the canvas or in the list view. Each block opens its settings on the right, with values picked from your trackers' real parameters. The Setup tab shows what the account holds, and can add a channel and devices for a fresh account.
Press Try before anything goes live: the app runs the steps over the last messages of a tracker and shows what each step would do. Nothing is sent, saved or queued.
Flow Builder: a flow on the canvas and the Try result over recent messages
Save and press Turn on. The app shows a plain-language plan of what it will create in your account, and only after your confirmation deploys the flow. From then on new messages of the flow's trackers go through it. The Activity view shows the flow working, Live data shows the latest values of each tracker, and Pause or Undeploy stop it at any time.
Flow Builder: the plan of changes shown before a flow is turned on
3. Good to know
  • what it creates — each flow lives in a dedicated subaccount of your account, tagged Flow Builder, holding the plugins, webhooks, streams and storage the plan listed. Undeploy removes them, and you stay in control without the app too: block the subaccount in the flespi panel to switch the automation off, or delete it to drop everything the flow created. Stored messages are never changed, a flow acts on new data only.
  • costs — the app is free. The components a flow creates count against your plan like any plugin, webhook or stream you create yourself.
  • sign-in — the flespi login window hands the app a token for your account, kept in the browser session only. Sign out when you leave a shared computer.
  • your own version — point your agent at the app link: it copies the app into your account and adapts it to your needs, so the app stays with you even if its maintainer stops.
  • support — the flespi team maintains the app, with no guarantee of availability or compatibility. Report issues in the flespi panel chat with the text from the page's Diagnostics link.
Want a tool shaped to your own work, a dashboard, a portal, a console? Ask your agent, as described in Building apps with flespi AI agents.
Ask your flespi AI agent for a web app: a live fleet map, a management dashboard, a customer portal. It builds, publishes and maintains the app on flespi
