The "wialon-reverse-geocoding" plugin type is used to apply Wialon reverse geocoding functionality to resolve position coordinates into the specific address.
Let's define a new plugin to resolve coordinates into addresses. Specify the required plugin type in the Type id field. You can also specify whether to add a prefix with the service name to each parameter (Parameter naming field).
And then you should be able to see the address fields in the new device messages. Go to the Logs & Messages tab for the given device to check:
Done.
- The use of plugins may result in slower messages registration in the flespi platform since it is preceded by requests to the third-party system.
- We cannot guarantee the performance or stability of the third-party systems involved in the process — in case of their service interruptions flespi will not be able to save messages to devices and will respond with negative ACK and will also terminate the connection if the required flag is set.
Change log
Subscribe to the Wialon reverse geocoding plugin change log to stay in sync with any updates.
More plugin types
