The "item-fields" plugin type is used to add static fields to the designated devices.
Let's define a new plugin for devices that will add a customer_id field that is a positive integer and a required field:
Note: by default, the plugin fields will be added and stored in the message and telemetry (edit the "store" setting to change that behavior).
And then you should be able to see the new field in the new device messages. Go to the Logs & Messages tab for the given device to check:
Done.
Change log
Subscribe to the item fields plugin change log to stay in sync with any updates.
More plugin types
