A-telematics protocol
Protocol used by GPS tracking devices manufactured by A-Telematics headquartered in China.
flespi parses the A-telematics protocol messages into a JSON object with the fields listed below in the Parameters tab.
To connect your tracker using the A-Telematics protocol, you need to have an a-telematics channel created first.
Then create a device instance for your tracker and use a device's serial number in the ident field.
accelerometer.alarm.event
Accelerometer alarm event
Alarm data 0x82
Peripheral key 0x24,
Peripheral key 0x2E,
Peripheral key 0x2F
arm.status
Position data 0x80
Peripheral key 0x27
Peripheral key 0x0B
Position data 0x80
Alarm data 0x82,
Peripheral key 0x20
Alarm data 0x82
Peripheral key 0x42
ble.lock.battery.voltage
BLE (Bluetooth Low Energy) Electronic Lock battery voltage
Peripheral key 0x42
ble.lock.rfid.code
RFID card number read by the electronic lock
Peripheral key 0x42
ble.lock.status.enum
Electronic lock combined lock and rope status code
Peripheral key 0x42
ble.lock.tag.code
BLE (Bluetooth Low Energy) Electronic Lock Tag ID
Peripheral key 0x42
ble.lock.temperature
Electronic lock temperature sensor value
Peripheral key 0x42
ble.lock.unlock.method.enum
Electronic lock unlock method and authorization code
Peripheral key 0x42
Peripheral key 0x43
Peripheral key 0x43
Peripheral key 0x43
Peripheral key 0x43
Peripheral key 0x27
Peripheral key 0x27
Peripheral key 0x27
Peripheral key 0x27
Peripheral key 0x27
Peripheral key 0x27
Peripheral key 0x27
Peripheral key 0x27
Peripheral key 0x27
Peripheral key 0x27
Peripheral key 0x27
Alarm data 0x82
Position data 0x80
Alarm data 0x82,
Position data 0x80
Position data 0x80
Peripheral key 0x18
Alarm data 0x82,
Position data 0x80
Peripheral key 0x0E,
Peripheral key 0x17
Alarm data 0x82
fuel.refuelling.level
Re-fuel amount as a percentage
Peripheral key 0x30
Peripheral key 0x40
Peripheral key 0x19
Alarm data 0x82
geofence.in.alarm
Geofence in alarm event
Alarm data 0x82,
Position data 0x80
geofence.out.alarm
Geofence out alarm event
Alarm data 0x82,
Position data 0x80
Alarm data 0x82,
Position data 0x80
Peripheral key 0x2B
Alarm data 0x82
Peripheral key 0x2B
Peripheral key 0x2B
Peripheral key 0x2B
Position data 0x80
Peripheral key 0x41
Alarm data 0x82
harsh.acceleration.number
Number of harsh Acceleration events
Peripheral key 0x27
Alarm data 0x82
harsh.braking.number
Number of harsh braking events
Peripheral key 0x27
Alarm data 0x82
Alarm data 0x82,
Position data 0x80
Alarm data 0x82
location.source.gps
Location is obtained via GPS
Position data 0x80
location.source.gsm
Location is obtained by Mobile network (GSM, 3G, 4G, LTE, 5G, ...) cell towers
Position data 0x80
lock.failure.alarm
Locking failure alarm event
Position data 0x80
Position data 0x80
low.speed.event
Low speed detected
Alarm data 0x82,
Position data 0x80
Peripheral key 0x10
Position data 0x80
Alarm data 0x82,
Position data 0x80
Alarm data 0x82,
Position data 0x80
Alarm data 0x82,
Position data 0x80
Position data 0x80
Alarm data 0x82,
Position data 0x80
Alarm data 0x82
Peripheral key 0x03,
Peripheral key 0x16
rfid.status.enum
RFID sign action or card event status code
Peripheral key 0x16
Peripheral key 0x2A
Peripheral key 0x0D,
Peripheral key 0x22
Position data 0x80
Alarm data 0x82,
Position data 0x80
Alarm data 0x82,
Position data 0x80
Position data 0x80
Alarm data 0x82
Alarm data 0x82
Alarm data 0x82,
Position data 0x80
Alarm data 0x82
Peripheral key 0x27
Peripheral key 0x27
Peripheral key 0x27
turnover.event
Turnover event
Alarm data 0x82
ultrasonic.real.fuel.level
Indexed parameter for real time ultrasonic fuel level
Peripheral key 0x25
ultrasonic.smooth.fuel.level
Indexed parameter for smooth ultrasonic fuel level
Peripheral key 0x25
Position data 0x80
Peripheral key 0x29
hex: Binary payload in HEX form
command: Command ID
Set device odometer value
{"hex":"0123000108AC","command":"DC"}
