Essentials
- A device is a virtual instance representing your physical tracker in the flespi platform.
- Devices in flespi are distinguished by a unique ident which most of the time corresponds to the tracker’s IMEI and device_type which is linked to specific channel protocol.
- You can configure different models of trackers from a single friendly interface (or via the API). Bulk updates are also supported.
- Devices can store messages in flespi for up to 10 years.
- Any device can be disabled. This feature can help mitigate channel loading bursts caused by channel inaccessibility or connectivity issues. Once a device is disabled, existing connections will be closed and new connections will be rejected. Only disabled devices can be moved between subaccounts.
- There is no specific hard link between devices and channels. To start receiving data from the device it is enough to create in your account channel working on the device type's protocol and configure tracker to channel's URI. Channel determines which device to use based on the combination of ident and protocol_id properties configured in device. If you occasionally configured 2 devices with the same ident that use the same protocol (even if different device types, but within the same protocol) - one of them will be automatically blocked by the platform.
- flespi currently supports 1000+ device types.
Important: You must have at least one channel to make your flespi devices work.
How devices work
Devices extend the functionality of channels in the following ways:
Each registered device has its own message buffer (100 MiB for the free account, 10 000 MiB for the commercial account) with up to 10 years of storage period.
You can perform calculations on device messages — extract trips/stops, detect geofence ins/outs, and a lot more.
You can apply plugins to device messages to modify their content.
You can configure your telematics devices remotely via API or a Setbox tool.
Devices feature telemetry that contains the latest values of all parameters received from the device and the time they were updated.
You can integrate video telematics features into your application.
You can remotely download tachograph files through a connected tracker and store them in the device media storage.
Device location can be visualized in TrackIt! — open-source web application for basic GPS tracking.
Charts with values from historical device message parameters can be visualized in grafana.
You can also export trips for your device in KML, GPX, or GeoJSON format.
You can safely change device ident whenever needed. However if you change device type attribute the current values of device settings may be lost.
In terms of IoT, a registered device is a kind of thing twin in AWS IoT hub or device shadow in MS Azure IoT. Even if your physical device is offline, you can get its last telemetry and plan to send a command as soon as the device connects to flespi. Moreover, the device can be configured via SMS which allows you to force the device to do something.
Device messages storage buffer is fully separated from channel's messages storage buffer. In the channel's messages buffer messages are stored with original parameters according to the protocol implementation of flespi parsing engine. Also in channel they are stored ordered by the server.timestamp value - e.g. in the order in which device reported them and no matter what time was specified in timestamp parameter (telemetry gathering time according to device's internal clock). While in device's buffer messages are stored after they are being processed by all plugins to which this device is assigned to and ordered by the timestamp value which was reported by the device.
How to create a device?
- Log in to the flespi panel
- Navigate to Telematics hub -> Devices and click the "+" button in the bottom right corner to add a new device:
Note: you should have a channel of the proper protocol created; however, if you don't, you will be reminded to create a channel upon device creation. - Give the new device a meaningful name and pick the device type from the drop-down and enter the device identifier (usually an IMEI):
- If you've already pointed your GPS tracker to the proper channel, you should soon start getting messages inside your flespi device. Open the Logs & Messages tab for your device to check:
If you want to automatically create devices when they connect to the channel you can use webhooks. You can also create devices in bulk from channel's Connections tab, import them from CSV file or just use REST API directly.
Devices API
To perform any operations with the devices, use the devices API.
To store in devices any custom user data you may use metadata. JSON object fields inside metadata can also be used to select device for any REST API operation.
To simulate device behavior you post messages via REST API directly into the device. This will trigger full processing cycle for the message including its processing by plugins, telemetry update and publication of various events into device MQTT topics.
Troubleshooting
In case of any issues, check the Logs & Messages tab on the device screen:
If you do not see expected messages in Messages pane but you see that device communicated with flespi channel according to Logs it can be due to a few reasons:
- Check if device is configured to store messages at all with non-zero messages_ttl.
- Ensure that channel received any message from this device at that time. To check this, open Logs & Messages pane of corresponding channel, enter filter by device's ident: ident="<device's ident>" and press Enter. In channel, messages are sorted by server.timestamp (reception time) and not processed by plugins so you should see there original telemetry reported by the device.
- Ensure that this channel is the one serving the device across the subaccount hierarchy: a device is served by a channel of its protocol in its own account, or, if there is none there, by the nearest such channel up the chain of parent accounts. So a channel of the same protocol created inside the device's subaccount takes the device over from the parent account channel. The tracker keeps connecting to the parent channel and its messages land in the channel buffer, but they are no longer registered in the device.
- If you do not see any messages in the channel from this device, right click on the log line and check raw traffic. It may be so that device just connects and authorizes but do not send any meaningful data.
- If you see expected messages in the channel, but do not see them in device take attention to the timestamp parameter (telemetry gathering time reported by the device) - it may be far in the future or in the past.
- Check plugins logs for any plugin to which device is assigned to. Plugins may discard message or modify any of its parameter, including timestamp.
Use raw traffic viewer to investigate parsing issues. By mouse right-click on the error log you may select "View error traffic" to see exact byte that caused parsing issue.
If you want to analyze your device data and state with AI you should use flespi AI assistant - Codi. It operates with theoretical knowledge from device manuals and has access to real device data - properties, settings, telemetry and logs. It is able to combine together all these informational sources and provide deep analysis of your device.
You may trace the whole history of message - when it was recorded by the device, reported to flespi channel, what plugins processed it and so on by clicking on the message and switching to plugins pipeline view in message information window:
If you accidentally deleted device you may restore the device with all its messages from recycle bin.
What's next?
- To forward the parsed data from your devices, explore our streaming options.
- To transform device messages, use plugins.
- To apply real-time analytics to device messages, use calculators.
- Connect grafana to your flespi device to visualize message parameter values.
Before you will start using flespi on a full scale we suggest to watch detailed videos from our conference. Invest your time into watching them now to save much more time and money later, when you will implement your project:
