MQTT topics guide
The structured collection of main flespi MQTT topics grouped by the entity.
Should you decide to consume updates from the flespi platform in a push-based MQTT way, you need to know the available MQTT topics to subscribe properly to the desired data source.
Important! You can not publish MQTT messages to any topic that starts from "flespi/". All topics in this article are reserved for exclusive publication by the flespi platform only usually as an indication of some event. Any MQTT message published by user to such a topic will be discarded by the Broker.
To get a copy of these messages in a topic of your own, see How to re-publish MQTT messages.
State and log topics carry the secret fields of item configurations, such as passwords and API keys, in their redacted form, see Secret fields.
Navigate to the list of MQTT topics for the required entity:
How to explore the topics?
We suggest using our MQTT Board tool as a friendly playground for all your MQTT experiments.
mqtt board add topic to explore
Just create a Subscriber, paste any of the below topics, and click the Play (Subscribe) button.
mqtt board topic payload
Devices
Since flespi is a device-centric platform, devices have the most topics associated with them.
Topic
Description
flespi/state/gw/devices/{id}/+
Device main fields
Access the device’s connected, last_active, and other useful characteristics.
flespi/state/gw/devices/{id}/telemetry/+
Device telemetry values.
Use this topic to separately get the latest value of each message parameter registered in the device.
flespi/message/gw/devices/{id}
New message received by the device
Use this topic to get new messages from the device in real-time.
flespi/interval/gw/calcs/+/devices/{id}/created,updated,deleted
Intervals generated by calculator assigned to the device were created, deleted or updated
Monitor intervals generated for this device and their status changes. Recommended for advanced usage of analytics events.
flespi/interval/gw/calcs/+/devices/{id}/activated,deactivated
Calculator assigned to the device triggered change to active or inactive state according to calculator configuration
Monitor current state change of the devices assigned to calculator. Recommended to use for notifications system on top of calculators.
flespi/state/gw/devices/{id}/settings/#
List of device settings
All device settings with all their current fields (the same as you can see on the Settings tab for the device).
flespi/state/gw/devices/{id}/settings/+
Settings: current value
Get the list of settings with their current values.
flespi/state/gw/devices/{id}/settings/+/pending
Settings: pending value
Get the list of settings that have the new value sent to them but not yet applied.
flespi/state/gw/devices/{id}/settings/+/status
Settings: status
Find out if the setting was read, applied, or unreadable. Find the table of possible setting statuses in devices API docs.
flespi/state/gw/devices/{id}/connections/+
List of active TCP connections from device
Device can establish only single primary connection and multiple secondary connections, for example during video streaming or uploading, sending its data via FTP, etc
flespi/log/gw/devices/{id}/settings/+/updated,set,accepted,rejected,canceled,cleared,unreadable,sent
Settings: logs
Get real-time logs indicating the statuses the device setting goes through. The status can be one of the following:
updated - device delivers new setting value by itself or upon request
set - flespi received a REST request to set a new setting value and accepted it for sending to the device
accepted - flespi sent a command to update the setting and the device responded “accepted successfully” (if the protocol supports such acknowledgment)
rejected - flespi sent a command to update the setting and the device responded with an error (if the protocol supports negative acknowledgment) or the device didn’t respond to 10 attempts to send a command
canceled - flespi received a REST request to delete a new setting value BEFORE the device confirmed its acceptance (or before the device responded with an error or before 10 attempts to send a command)
cleared - flespi received a REST request to delete the current setting value (that device accepted or previously sent to flespi)
unreadable - flespi sent a command to read a device setting 10 times and every time the device responded with an error or ignored the command; flespi will not attempt to read this setting until the user clears it via REST API
sent - once flespi sent the new setting value to the connected device
flespi/log/gw/devices/{id}/commands-queue/+/processed,queued,sent,canceled,expired
Commands queue: logs
Get real-time logs indicating the statuses the device command goes through in the commands queue. The status can be one of the following:
processed - flespi received request to place a new command in the commands queue
queued - command has been placedin the commands queue
sent - once flespi sent the new command to the connected device
expired - the command was deleted from the commands queue because the command TTL elapsed
flespi/log/gw/devices/{id}/mediastream/started,stopped
Live video streaming from device started or stopped
flespi/state/gw/plugins/+/devices/{id}/#
Plugins assigned to device
Get the list of plugins assigned to this device and their status.
flespi/log/gw/devices/{id}/#
Device logs
Detailed records about all events related to the given device.
Devices API docs:  https://flespi.io/docs/#/gw/devices
Channels
If you rely on channels to consume a flow of data from the telematics devices, these are the topics you may use:
Topic
Description
flespi/state/gw/channels/{id}/+
Channel main fields
Access the channel’s enabled, connections_count, messages_size, blocked status, and other useful characteristics.
flespi/state/gw/streams/{id}/channels/+/#
Streams assigned to channel
Get the list of all streams the channel is forwarding data through.
flespi/message/gw/channels/{id}/+
New messages from device(s) received by channel
Use this topic to get new messages arriving to the given channel in real-time (from devices operating via this channel’s protocol).
flespi/log/gw/channels/{id}/#
Channel logs
Detailed records about all events related to the given channel.
Channels API docs: https://flespi.io/docs/#/gw/channels
Streams
If you use a stream to forward data from the flespi platform to a specific destination platform, you may find some of the topics below useful.
Topic
Description
flespi/state/gw/streams/{id}/+
Stream main fields
Access the stream’s enabled, connected, URI, queue_size, and other useful characteristics.
flespi/state/gw/streams/{id}/devices/+/#
Devices assigned to the stream
Get the list of all devices the stream is forwarding data from.
Channels assigned to the stream
Get the list of all channels the stream is forwarding data from.
flespi/log/gw/streams/{id}/#
Stream logs
You can use this topic to monitor the operability of your stream. Find the event codes and error codes to catch in the streams API docs.
Streams API docs: https://flespi.io/docs/#/gw/streams
Calculators
As a key entity of the flespi analytics engine, calculators feature a few MQTT topics to subscribe to the frequently required data.
Topic
Description
flespi/state/gw/calcs/{id}/+
Calculator main fields
Access the calculator’s counters, selectors, intervals_rotate, intervals_ttl, and other useful characteristics.
flespi/state/gw/calcs/{id}/devices/+/synced
Calculator state (synced or not)
Get the current calculator sync state for each of the assigned devices (or for some of them).
flespi/state/gw/calcs/{id}/devices/+/last
Last detected interval
Get the freshest interval generated by the calculator for each of the assigned devices (or for some of them).
flespi/state/gw/calcs/{id}/devices/+/active
Active interval
Use to monitor the current state of the interval (active or not).
flespi/interval/gw/calcs/{id}/devices/+/created,updated,deleted
Interval created, updated, and deleted events
Use to catch intervals status changes: created, updated, deleted. Recommended for advanced usage of analytics events.
flespi/interval/gw/calcs/{id}/devices/+/activated,deactivated
Calculator assigned to the device triggered a change to active or inactive state according to calculator configuration
Use to track active intervals when they appear (get triggered) and disappear (become no more actual).
Calculators API docs: https://flespi.io/docs/#/gw/calculators
AI agents
flespi AI agents publish their runtime state, activity, and logs:
Topic
Description
flespi/state/ai/agents/{id}/+
Agent runtime fields (retained): status, title, steps, approvals_count, messages_read, etc.
flespi/state/ai/agents/{id}/approvals/{timestamp}
Pending approval requests (retained), one topic per request, cleared on resolution
flespi/state/ai/agents/{id}/messages/pending/{timestamp}
Messages awaiting a busy agent (retained), one topic per message, marked seen once the agent reads it and cleared on delivery or retraction
flespi/message/ai/agents/{id}/history
Live agent history: messages exchanged and operations performed
flespi/message/ai/agents/{id}/status
Live status line: what the agent is doing right now within a reasoning step (not stored)
flespi/message/ai/agents/{id}/activity
Live tool activities of the working agent, one message at start and one at finish of each (not stored)
flespi/log/ai/agents/{id}/#
Agent logs: reasoning steps with their charges, approvals lifecycle, activity journal, configuration changes
flespi/log/ai/agents/{id}/execution/#
The activity journal alone: scripts executed, events received, messages sent, handler runs
flespi/log/ai/connectors/{id}/calls/+
Connector call records: every read (calls/read) and change (calls/mutation) the agent performs in the connected system
AI agents API docs: https://flespi.io/docs/#/ai/agents
Complete list of flespi MQTT topics
Above we expanded only the most widely used MQTT topics. The exhaustive list of ALL MQTT topics for ALL flespi entities is available in the flespi panel: https://flespi.io/#/topicsdirectory
flespi mqtt topics directory
Flespi MQTT extras
In addition to + or # topic multipliers in the subscription (e.g. subscribe to flespi/# to receive all messages from all flespi topics) you can use so-called topic selectors - use comma-separated list of words in each topic part. For example instead of subscribing to 4 topics for device ID 100 and 200 for analytics events activation and deactivation it is possible to subscribe to a single topic flespi/interval/gw/calcs/+/devices/100,200/intervals/activated,deactivated which will provide equivalent results.
For even more customization you may apply powerful filtering for incoming messages on the MQTT broker side.
Even though the flespi MQTT broker is completely MQTT5-compliant, it also features some extra functionality that makes working with the flespi topics structure more convenient.
File storage with public links and an own domain for static sites.
Add a flespi sign-in to your own web page: users log in with a flespi account or as realm users and the page gets a flespi token without pasting it.
