Digital-matter-edge protocol
Protocol used by GPS tracking devices manufactured by Digital Matter headquartered in Australia.
flespi parses the Digital-matter-edge protocol messages into a JSON object with the fields listed below in the Parameters tab.
To connect your tracker using the Digital Matter Edge protocol, you need to have a digital-matter-edge channel created first. The protocol only supports HTTP data parsing.
According to the manufacturer's recommendations, devices that use the Edge protocol should initially be directed to the manufacturer's OEM server, and from there redirected to a 3rd party server (flespi). This is necessary so that the device can successfully determine coordinates using the Location Engine developed by the manufacturer, since the device cannot do this on its own. Instructions for configuration.
The channel's domain name:port have to be specified as server settings for data transfer.
accelerometer.wakeup.number
Device Counters
battery.capacity.used
Battery Capacity Used
Device Counters
battery.capacity.used.initial
Battery Capacity Used Initial
Device Counters
Percentage used on GNSS
Device Counters
Percentage used on LoRaWAN
Device Counters
Device Counters
Percentage used on sleeping
Device Counters
Percentage used on WiFi
Device Counters
Device Counters
Analogue values,
Device Counters
battery.voltage.initial
Device Counters
beacon.uptime
Beacon uptime
Device Counters
Position info
ble.failures.count
BLE failures counter
Device Counters
ble.scans.count
BLE scans counter
Device Counters
ble.uptime
BLE uptime counter
Device Counters
charger.connections.count
Charger connections count
Device Counters
counter.rx.range
Device Counters
counter.tx.power
Device Counters
counter.uploads
Device Counters
counter.uploads.failed
Device Counters
counter.uploads.failed.time
Device Counters
counter.uploads.time
Device Counters
device.state.bitmask
Device state bitmask
Analogue values
device.temperature.max
Device Counters
Device Counters
ess.failed.exchanges
Device Counters
ess.successful.exchanges
Device Counters
Average Failed GPS Fix Time
Device Counters
gnss.average.fix.duration
Device Counters
gnss.average.refresh.time
Average GPS Freshen Time
Device Counters
gnss.position.fixes
Device Counters
gnss.position.fixes.failed
Device Counters
Device Counters
gnss.position.fixes.time
Device Counters
gnss.refresh.attempts
Device Counters
gnss.refresh.duration
Device Counters
Position info
Cell tower data
Cell tower data
Cell tower data
Cell tower data
Cell tower data
hardware.version.enum
Hardware version enum
jostle.position.fixes
Device Counters
jostle.position.fixes.uploads
Device Counters
last.release.time
Last release time
Device Counters
loaded.battery.voltage
Loaded battery voltage
Analogue values
lora.application.id
LoRaWAN Application ID
Lora details
lora.device.address
LoRaWAN Device Address
Lora details
lora.device.id
LoRaWAN Device ID
Lora details
lora.gateway.id
LoRaWAN Gateway identifier
Lora details,
Lora gateway
lora.rssi
LoRaWAN Received Signal Strength Indication
Lora details,
Lora gateway
lora.snr
LoRaWAN Signal-to-Noise Ratio
Lora details,
Lora gateway
Analogue values
position.gdop
Geometric dilution of precision
Position info
Position info
Position info
position.source.enum
Number of position source
Position info
Device Counters
radar.failures.count
Radar failured count
Device Counters
radar.scans.count
Radar scans count
Device Counters
reboot.count
Device Counters
recovery.mode.status
Recovery Mode On/Off
Log reasons
Log reasons
resets.brownout.count
Device Counters
resets.count
Device Counters
sensor.sample.count
Sensor sample count
Device Counters
total.battery.consumption
cycles
Total battery consumption
Device Counters
total.release.attempts
Total release attempts
Device Counters
trip.average.wakeup.number
Average Wakeups Per Trip
Device Counters
Device Counters
Log reasons
wifi.channel
WiFi channel number
Wi-Fi data
wifi.failed.scans
Count of failed Wi-Fi scans
Device Counters
Wi-Fi data
wifi.scan.fail.time
Wi-Fi scan fail time
Device Counters
wifi.scan.success.time
Wi-Fi scan success time
Device Counters
Wi-Fi data
wifi.successful.scans
Device Counters
