Fetch vehicles position information to a channel from Scania Fleet Management Services using Scania API.
To use the channel you need to have an active Control package from a Scania dealer with your 'User ID' and 'Password'.
Obtain the 'Client ID' and 'Secret Key' fields for proper flespi channel configuration:
- Open Scania Developer Portal
In 'Login As' drop-down select 'Scania Data Access User', enter 'User ID' and 'Password', and log in. - Open 'My Application' tab, then click 'Create Application' button, enter application name and description, and hit 'Save'.
- Copy generated 'Client ID' and 'Secret key' strings into corresponding channel configuration fields.
After creation please check the channel logs for errors using Toolbox.
flespi channel relies on the LastReported request from the Positions API and the RfmsStatusCurrent request from the rFMS API. All explanations for the error codes can be found in the respective sections of the Scania API.
Note: Scania vehicles will only send data to their servers when the engine is running or ignition is on.
Learn more about getting Scania data into flespi and forwarding it to other platforms in our dedicated blog post.
Engine ignition status
