Xirgo-mqtt protocol
Parse and decode Xirgo Global binary messages into JSON. Get the parsed data from Xirgo Global devices via MQTT. Forward normalized data from Xirgo Global trackers to cloud platforms (AWS, Azure, etc.).
flespi parses the Xirgo-mqtt protocol messages into a JSON object with the fields listed below in the Parameters tab.
General information
Xirgo MQTT Protocol has an embedded MQTT server inside. This allows full control over device connections:
  • securing data with TLS encryption
  • configuring your own authentication on the incoming connections
  • whitelisting the IP addresses allowed to connect to the channel.
The xirgo-mqtt channel is also equipped with TrafficViewer — an indispensable tool for debugging raw traffic between the channel and connected devices.
Configuration on the flespi side
  • create a channel and select protocol xirgo-mqtt (#309).
    flespi xirgo mqtt channel create
    You may configure any Username and/or Password in the channel just make sure to use the same ones in the device configuration.
  • The Host and Port of the xirgo-mqtt channel (created above) will serve as the MQTT broker address in the device configuration below.
    host port mqtt broker
Configuration on the device side
a) MQTT broker address. Destination address where the data will be sent (take Host and Port of your xirgo-mqtt channel).
mqtt broker address settings xirgo
b) MQTT authorization parameters. Define Username and Password in order to successfully authorize with the broker.
mqtt authorization parameters xirgo
Note: make sure to paste the same Username and/or Password that were specified in the channel configuration.
c) MQTT session parameters. Basic parameters for telemetry data sending to broker and connection timeouts.
mqtt session parameters xirgo
d) MQTT topic configuration. Most MQTT topics here define where the device will publish data. "Output control topic name" defines the topic that the device should subscribe to in order to receive commands. Make sure to specify the corresponding topic in the channel configuration (see "OUTC Command topic").
mqtt topic configuration xirgo
Tachograph functionality
Protocol supports downloading of all tachograph file types: driver cards and tachograph memory.
Authorization works via the native Tachograph receiver app or the Tacho Bridge App (TBA).
Notes: file upload is initiated from the device side. The server accepts all data sent by the tracker. The tracker can initiate loading when the card in the driver's slot is changed and no more than once every 6 hours.
Xirgo server settings: use the secondary_uri (which is displayed next to the channel address after enabling the configuration) as the server address in the tracker settings. The same secondary_uri must be used for both "tacho data server address" and "card server address" fields.
Tachograph receiver app: you can only specify the "tacho data server address" field to upload file data, since tachograph authentication is performed through the native application. In the "card server address" field, you need to specify the application identifier of the type FFFFFFFF*tacho.bce.lt (generated by app), which will be used by the manufacturer's server to communicate with the company's card.
Necessary settings in the tracker configurator:
  • Miscellaneous > Tachograph settings > Tacho file server > Tacho file server settings
  • Miscellaneous > Tachograph settings > Tacho file server > VU file settings
  • Hardware > CAN2 > CAN function ID > enable CAN function - Tachograph read
Sensor ID 0xA001
Sensor ID 0x2050
accelerometer.calibration.confidence
Accelerometer self-orientation confidence, raw device value
Sensor ID 0x3046
Sensor ID 0x3001,
Sensor ID 0x3002,
Sensor ID 0x3003
Sensor ID 0xC008
armed.status
Armed/disarmed status
Sensor ID 0x0060
Sensor ID 0x2041
Sensor ID 0x3004
Sensor ID 0x007F
can.activity.status
CAN activity status if there were messages received last 10 seconds on CAN1 or on CAN2.
Sensor ID 0x009F,
Sensor ID 0x00AB...0x00AC
Sensor ID 0x2021
Sensor ID 0x0079
Sensor ID 0x302A
Sensor ID 0x302D...0x3031
Sensor ID 0x2040
Sensor ID 0x0078
can.bitrate
CAN bitrate
Sensor ID 0x4058,
Sensor ID 0x4059
Sensor ID 0x0077
can.check.engine.status
CAN check engine warning is on
Sensor ID 0x007A
can.command.id
Command Identifier, that is used by canbase_b function on CAN
Sensor ID 0x302B,
Sensor ID 0x302C
Sensor ID 0x0076
can.cruise.state
Cruise control state
Sensor ID 0x2031
Sensor ID 0x008F
can.dpf.ash.load.percent
Sensor ID 0x2045,
Sensor ID 0x2046
can.dpf.soot.load.percent
Sensor ID 0x2043,
Sensor ID 0x2044
Sensor ID 0x0085
Sensor ID 0xC015
Sensor ID 0x0084
Sensor ID 0x2008,
Sensor ID 0x2014
Sensor ID 0x3021,
Sensor ID 0x303D
Sensor ID 0x200A,
Sensor ID 0x2013
Sensor ID 0x4002
Sensor ID 0x203F
Sensor ID 0x300C,
Sensor ID 0x303B
can.engine.torque.load
Engine torque load percentage read from CAN
Sensor ID 0x203A
Sensor ID 0x0081
can.fms.tco1.bitmask
CAN FMS TCO1 tachograph data bitmask
Sensor ID 0x500E
Sensor ID 0x0062
Sensor ID 0x0063
can.front.wipers.mode
Front wipers switch mode, read from CAN
Sensor ID 0x203D
Sensor ID 0x4001
Sensor ID 0x405A
Sensor ID 0xA01B
Sensor ID 0x3034
Sensor ID 0x0080
Sensor ID 0x2019
Sensor ID 0x203C
Sensor ID 0x3039
Sensor ID 0x008B
Sensor ID 0x0089
Sensor ID 0x0066
can.idle.fuel.consumed
Sensor ID 0x4068
Sensor ID 0x008A
Sensor ID 0x201A,
Sensor ID 0x203E
can.j1979.engine.coolant.temperature
CAN J1979 engine coolant temperature
Sensor ID 0x2014
can.j1979.engine.fuel.rate
CAN J1979 Engine fuel rate
Sensor ID 0x303D
can.j1979.engine.rpm
CAN J1979 Engine RPM
Sensor ID 0x303B
Sensor ID 0x2016,
Sensor ID 0x2018
can.master.warning.light.status
Status of master warning light, read from CAN
Sensor ID 0x007E
can.messages.missed
Counter of missed messages from CAN bus
Sensor ID 0x4057
can.messages.received
Counter of received messages from CAN bus
Sensor ID 0x4056
Sensor ID 0x0075
Sensor ID 0x0086
Sensor ID 0x008C
Sensor ID 0x009D
Sensor ID 0x203B
Sensor ID 0x009E
Sensor ID 0x0064
Sensor ID 0x0065
can.retarder.selection
Sensor ID 0x2039
Sensor ID 0x2038
can.retarder.torque.mode
Sensor ID 0x2037
Sensor ID 0x3038
Sensor ID 0x2015,
Sensor ID 0x2017
Sensor ID 0x2006
Sensor ID 0x007C
Sensor ID 0x4069
can.transmission.oil.life
Sensor ID 0x2042
Sensor ID 0x0067
Sensor ID 0x4003
Sensor ID 0x4062
Sensor ID 0x303A
Sensor ID 0x0093
Sensor ID 0x301D
cargo.temperature
Sensor ID 0x3033
Sensor ID 0x3040...0x3043
Sensor ID 0xC007
Sensor ID 0x4055,
Sensor ID 0x4067
Sensor ID 0x0003,
Sensor ID 0x0010,
Sensor ID 0x0011,
Sensor ID 0x0012,
Sensor ID 0x0013,
Sensor ID 0x0014,
Sensor ID 0x0015
Sensor ID 0x0094,
Sensor ID 0x0095,
Sensor ID 0x0096,
Sensor ID 0x009A
Sensor ID 0xC016...0xC017
Sensor ID 0x006D
engine.status
Engine status
Sensor ID 0x008D
event.function
Event function
Sensor ID 0x3000
Sensor ID 0xC012
Sensor ID 0x5008...0x500C
Sensor ID 0x2007,
Sensor ID 0x2009
Sensor ID 0x202C
Sensor ID 0x0006
gnss.agc.level
GNSS receiver automatic gain control (AGC) monitor value
Sensor ID 0x3020
Sensor ID 0x009B
gnss.signal.weak.status
GNSS signal weak
Sensor ID 0x0007
Sensor ID 0x000B
Sensor ID 0x300A
Sensor ID 0x0008
Sensor ID 0x3009
Sensor ID 0x3008
Sensor ID 0x2003
gsm.network.info
Mobile network (GSM, 3G, 4G, LTE, 5G, ...) information reported by the device as a single composite value, protocol-specific format
Sensor ID 0xC019
Sensor ID 0x0009
Sensor ID 0x000A
Sensor ID 0x2005
Sensor ID 0xC014
hardware.version.enum
Hardware version enum
Sensor ID 0x2030
Sensor ID 0x0088
Sensor ID 0x5000
Sensor ID 0x001E
last.success.registration.timestamp
Timestamp of last successful data registration
Sensor ID 0x4060
locked.status
Locked/unlocked status
Sensor ID 0x0061
Sensor ID 0xC01A
modem.power.status
Modem is powered on
Sensor ID 0x0001
Sensor ID 0x0002
Sensor ID 0x5004...0x5007,
Sensor ID 0xA000,
Sensor ID 0xA017,
Sensor ID 0xA018,
Sensor ID 0xA019,
Sensor ID 0xA01A
Sensor ID 0xE000...0xEFFF
pdp.active.status
PDP context (mobile data session) is active
Sensor ID 0x000C
Sensor ID 0x7003,
Sensor ID 0xD000
Sensor ID 0x300B,
Sensor ID 0xD000
Sensor ID 0x2002,
Sensor ID 0xD000
Sensor ID 0xB001,
Sensor ID 0xD000
Sensor ID 0xB000,
Sensor ID 0xD000
Sensor ID 0x2001,
Sensor ID 0xD000
Sensor ID 0x2000,
Sensor ID 0xD000
reset.event
Device reset event
Sensor ID 0x0000
reset.reason
Device reset reason
Sensor ID 0x2029
script.name
Script name
Sensor ID 0xC004...0xC006
sensor.boolean.value
User-defined sensor boolean value
Sensor ID 0x001F...0x005F
sensor.float.value
User-defined sensor float value
Sensor ID 0xA003,
Sensor ID 0xA004,
Sensor ID 0xA005,
Sensor ID 0xA006,
Sensor ID 0xA007,
Sensor ID 0xA008,
Sensor ID 0xA009,
Sensor ID 0xA00A,
Sensor ID 0xA00B,
Sensor ID 0xA00C,
Sensor ID 0xA00D,
Sensor ID 0xA00E,
Sensor ID 0xA00F,
Sensor ID 0xA010,
Sensor ID 0xA011
sensor.frequency
Frequency sensor value
Sensor ID 0x3022...0x3025
sensor.int16.value
User-defined 2 bytes sensor signed value stored as int16, indexed parameter
Sensor ID 0x7004...0x700D
sensor.int32.value
User-defined 4 bytes sensor signed value stored as int32, indexed parameter
Sensor ID 0x8000...0x8009
sensor.int8.value
User-defined 1 byte sensor signed value stored as int8, indexed parameter
Sensor ID 0x6000...0x6009
sensor.pulse.period
Time between two pulses on the input
Sensor ID 0x3026...0x3029
sensor.static.signal
User defined Static Signal flag, indexed parameter
Sensor ID 0x001B...0x001C,
Sensor ID 0x00A0...0x00A2
sensor.string.value
User-defined sensor string value
Sensor ID 0xC000,
Sensor ID 0xC001,
Sensor ID 0xC002,
Sensor ID 0xC003
sensor.uint16.value
Sensor ID 0x300D...0x301C
sensor.uint32.value
Sensor ID 0x4005...0x4054
sensor.uint64.value
Sensor ID 0x5001
sensor.uint8.value
Sensor ID 0x200B...0x2012
Sensor ID 0x204F
Sensor ID 0x0098,
Sensor ID 0x0099
Sensor ID 0x405C...0x405D
Sensor ID 0x202D,
Sensor ID 0x202E,
Sensor ID 0x500E
Sensor ID 0x202D,
Sensor ID 0x202E,
Sensor ID 0x500E
Sensor ID 0x500E
Sensor ID 0x500E
Sensor ID 0x500E
Sensor ID 0x500E
Sensor ID 0x500E
tacho.driving.direction
Sensor ID 0x500E
tacho.file.manager.state
Tachograph File Manager State
Sensor ID 0x202F
tacho.handling.info.status
Sensor ID 0x500E
Sensor ID 0xC01C
Sensor ID 0x500E
Sensor ID 0x500E
tacho.performance
Tachograph performance
Sensor ID 0x500E
Sensor ID 0x500E
tacho.slot.activity
Slot activity from tachograph
Sensor ID 0x202D,
Sensor ID 0x202E
tacho.slot.distance
Slot distance from tachograph
Sensor ID 0x405E...0x405F
tacho.slot.time
Slot time from tachograph
tacho.system.event.status
Tacho system event occurred
Sensor ID 0x500E
Sensor ID 0x4066
Sensor ID 0x405B
trailer.weight
Total weight of trailer
Sensor ID 0x3032
Sensor ID 0xA002
Sensor ID 0xB002
Sensor ID 0xC01D
Sensor ID 0xC01B
Sensor ID 0x0069
wiegand.code
Wiegand26 RFID code
Sensor ID 0x4061
Sensor ID 0x7000
Sensor ID 0x7001
Sensor ID 0x7002
ttl: Command TTL in seconds
output: Output ID
payload: Command payload in HEX format
Send script remote command
{"output":13,"payload":"616E792062696E617279207061796C6F6164"}
Custom SMS command
custom_sms
Send custom command to device over SMS
text: Command payload
Get bootloader version
{"text":"V"}
