Affortech Quadro
Affortech Quadro is an advanced asset tracking device available in IP65 and IP67 models for precise monitoring in any environment. It uses dual-core microcontroller technology for efficient operation and offers robust solutions for asset management, with features like GNSS (GPS, GLONASS, Galileo, SBAS), LBS, WiFi, BLE 5.0, temperature telemetry, humidity and luminosity sensors, and LTE global connectivity.
Parameters (64)
Settings (17)
Affortech Quadro
Flespi parses telemetry data from your Affortech Quadro into a standardized JSON and lets you send commands to Affortech Quadro via API.
    "device.type.id": "Affortech Quadro",
    "protocol.id": "affortech"
How to send commands to Affortech Quadro?
air.pressure
Air pressure
battery.charging.state
data.type.enum
Data type code
Message ID
gpio.input
GPIO Input channel
gpio.output
GPIO Output channel
sensor.humidity.limit.max
Humidity sensor limit (max)
sensor.humidity.limit.min
Humidity sensor limit (min)
sensor.illuminance.limit.max
sensor.temperature.limit.max
sensor.temperature.limit.min
work.mode
Protocol-specific work mode
APN configuration
password: APN password
username: APN username
Bluetooth configuration
timeout: Nodes Timeout
max_nodes: Max Nodes
scan_time: Single scan time
work_mode: Work Mode
report_mask: Report Mask
Device configuration
device
timezone: Timezone
identifier: Device ID
Device information
Device information
iccid: ICCID
device_model: Device Model
factory
GNSS configuration
gnss
G-Sensor configuration
g_sensor
time: G-sensor time
range: Range
times: G-sensor times
trigger: G-sensor trigger interval,
sensitivity: Sensitivity
Heartbeat interval
heartbeat_interval
Set heartbeat interval
interval: Heartbeat interval
Light sensor configuration
light_sensor
trigger_interval: Trigger interval
NTP configuration
ntp
NTP configuration
port: NTP server port
server: NTP server address
OTA upgrade
ota_upgrade
params: OTA params
Report configuration
report
Device restart
restart
Server
Server configuration
ack: Server ACK Enable
protocol: Protocol Type
Temperature & humidity sensor configuration
temp_humi
humi_lower_limit: Lower Humidity Limit
humi_upper_limit: Upper Humidity Limit
temp_lower_limit: Lower Temperature Limit
temp_upper_limit: Upper Temperature Limit
Conditional trigger function
triggermode
AT+TRIGGERMODE Configure The Conditional TriggerFunction
report: Report interval
sampling: Sampling interval
workmode: Workmode
condition: Condition
WiFi configuration
wifi
WiFi configuration
max_ap: Max AP
More devices from Affortech
No results found.
