AOVX VG200
AOVX VG200 is an ultra-small size low-cost motorcycle and vehicle GPS tracker. The device features ACC ignition monitoring, remote fuel and power cut-off, and more.
Parameters (70)
Settings (18)
AOVX VG200
Flespi parses telemetry data from your AOVX VG200 into a standardized JSON and lets you send commands to AOVX VG200 via API.
    "device.type.id": "AOVX VG200",
    "protocol.id": "aovx"
How to send commands to AOVX VG200?
air.pressure
Air pressure
Extension ID 0xF6 of Message ID 0x0200,
battery.charging.state
data.type.enum
Data type code
Message ID,
gpio.input
GPIO Input channel
gpio.output
GPIO Output channel
sensor.humidity.limit.max
Humidity sensor limit (max)
sensor.humidity.limit.min
Humidity sensor limit (min)
sensor.illuminance.limit.max
sensor.temperature.limit.max
sensor.temperature.limit.min
work.mode
Protocol-specific work mode
APN configuration
password: APN password
username: APN username
Bluetooth configuration
timeout: Nodes Timeout
max_nodes: Max Nodes
scan_time: Single scan time
work_mode: Work Mode
report_mask: Report Mask
Device configuration
device
timezone: Timezone
identifier: Device ID
Device information
Device information
iccid: ICCID
device_model: Device Model
factory
GNSS configuration
gnss
Heartbeat interval
heartbeat_interval
Set heartbeat interval
interval: Heartbeat interval
NTP configuration
ntp
NTP configuration
port: NTP server port
server: NTP server address
odometer configuration
value: Odometer
OTA upgrade
ota_upgrade
params: OTA params
Report configuration
report
Report interval configuration
report_interval
run: Run mode
sleep: Sleep mode
Device restart
restart
Server
Server configuration
ack: Server ACK Enable
protocol: Protocol Type
Speed configuration
speed
Speed configuration
max: Maximum
over_speed: Over-speed
Turn angle configuration
turn_angle
angle: Turn angle
Voltage configuration
voltage
run: Run voltage
stop: Stop voltage
sleep: Sleep voltage
WiFi configuration
wifi
WiFi configuration
max_ap: Max AP
Send transparent data
transparent_data
Downlink transparent transmission
type: Type
payload: Payload
