Arnavi Integral 3
Arnavi Integral 3 is a compact, economical, and easy-to-install GPS tracker. The device features RS-485 or RS-232 (depending on the version) and 1-WIRE interfaces, 1 analog input, 3 discrete inputs, 2 discrete outputs, backup battery, and more.
Parameters (113)
Arnavi Integral 3
Flespi parses telemetry data from your Arnavi Integral 3 into a standardized JSON and lets you send commands to Arnavi Integral 3 via API.
    "device.type.id": "Arnavi Integral 3",
    "protocol.id": "arnavi"
How to send commands to Arnavi Integral 3?
ble.asset.battery.voltage
bluetooth.state
Bluetooth state
can.agro.equipment.bitmask
Agricultural equipment bitmask, read from CAN. Hexadecimal string of bitwise flags. Refer to the device documentation for more deatils
can.log.number
CAN log number
can.movement.state.bitmask
Characteristic of movement, read from CAN. Hexadecimal string of bitwise flags. Refer to the device documentation for more deatils
case.status
Case opened status
device.state.bitmask
Device state bitmask
ecu.error.code
ECU error code
frequency.counter.din
gyroscope.state.enum
Gyroscope state
scooter.bms.error.code
Scooter BMS error code
scooter.motor.error.code
Scooter motor-wheel controller error code
sdcard.log.enum
SD card log id
sensor.frequency
Frequency sensor value
sim.card.slot
Currently used SIM card slot
vehicle.speed
Vehicle speed
payload: Command payload as HEX string
wait_response: Wait Response
transmit a packet with coordinates
{"payload":"0101"}
