Cantrack TK100N
TK100N is a multi-functional GPS tracker designed for vehicles, motorcycles, and e-bikes. It supports real-time tracking, ACC detection, and features an SOS panic button. The device can disable fuel or electricity and operates on a wide voltage range of 9V-90V DC. It uses the GT06N protocol and is compatible with major third-party platforms. The tracker is compact, with dimensions of 79x34x18mm and weighs 50g. It offers high GPS sensitivity and accuracy, with a robust operating temperature range and low power consumption.
Parameters (95)
Cantrack TK100N
Flespi parses telemetry data from your Cantrack TK100N into a standardized JSON and lets you send commands to Cantrack TK100N via API.
    "device.type.id": "Cantrack TK100N",
    "protocol.id": "cantrack"
How to send commands to Cantrack TK100N?
Protocol Number 0x16
Alarm bit 0x01 of Protocol Number 0x15,
Extended bit 0x04 of Protocol Number 0x16
Additional info ID 0x06,
Command *HTBT,
Alarm sign bitmask,
Command *V1,
Command *V2,
Command *V3,
Command *V5,
Extended bit 0x03 of Protocol Number 0x16
Command *V3,
Command *V5
Alarm bit 0x13 of Protocol Number 0x15,
Alarm bit 0x13 of Protocol Number 0x16
Alarm bit 0x09 of Protocol Number 0x15,
Command *V1,
Command *V2,
Command *V3,
Command *V5
Alarm bit 0x14 of Protocol Number 0x15,
Alarm bit 0x14 of Protocol Number 0x16
Alarm bit 0xFE of Protocol Number 0x15,
Alarm bit 0xFF of Protocol Number 0x15,
Command *V1,
Command *V2,
Command *V3,
Command *V5,
Alarm bit 0x0E of Protocol Number 0x15,
Alarm bit 0x0E of Protocol Number 0x16
Sub protocol number 0x00 of Protocol Number 0x94
Alarm bit 0x04 of Protocol Number 0x15,
Alarm bit 0x05 of Protocol Number 0x15,
Alarm bit 0x05 of Protocol Number 0x16
Additional info ID 0x5D,
Command *V3,
Command *V3,
Command *V3,
Command *V3,
Command *V3
Command *V3,
Command *ICCID,
Sub protocol number 0x0A of Protocol Number 0x94
Alarm bit 0xF0 of Protocol Number 0x13,
Alarm bit 0xF0 of Protocol Number 0x15,
Alarm bit 0xF0 of Protocol Number 0x16,
Alarm bit 0xF1 of Protocol Number 0x13,
Alarm bit 0xF1 of Protocol Number 0x15,
Alarm bit 0xF1 of Protocol Number 0x16,
Alarm bit 0x19 of Protocol Number 0x15,
Alarm bit 0x19 of Protocol Number 0x16
Alarm bit 0x06 of Protocol Number 0x15,
Alarm bit 0x06 of Protocol Number 0x16
Command *V1,
Command *V2,
Command *V1,
Command *V2,
Command *V1,
Command *V2,
Command *V1,
Command *V2,
Command *V1,
Command *V2,
Alarm bit 0x02 of Protocol Number 0x15,
Alarm sign bitmask,
Extended bit 0x02 of Protocol Number 0x16
rear.light.status
Rear light status
Command *V1,
Command *V2,
Command *V3,
Command *V4,
Command *V5,
Additional info ID 0x01,
Command *V1,
Command *V2,
Command *V3,
Command *V5
Command *V1,
Command *V2,
Command *V3,
Command *V5
Alarm bit 0x03 of Protocol Number 0x15,
Command *V1,
Command *V2,
Command *V3,
Command *V5,
Extended bit 0x01 of Protocol Number 0x16
Command *V5
Command *V5
Additional info ID 0x05
Send custom command to device, Scheme: "*,,#". You have to specify payload only
Cut fuel for stop car, model G06L
{"payload":"CMD,130305,stop654321"}
Set working mode 1, models GF40, GF50, GF60, GF70L
{"payload":"MD123456 1 3 8 1"}
Set Center number command S2, models TK100, TK100B, G05
{"payload":"S2,130305,13812341234"}
More devices from Shenzhen Cantrack Technology Co., Ltd (14)
Tags
Cantrack C32
cantrack
Cantrack G05
cantrack
Cantrack G08L
cantrack
Cantrack G09L
cantrack
Cantrack G900LS
cantrack
Cantrack GF40
cantrack
Cantrack GF60
cantrack
Cantrack GF60L
cantrack
Cantrack GF70L
cantrack
