Fitrider M2 eBike
Fitrider M2 is an electric bicycle with a swappable battery design and build-in IoT/GPS. The bike features 14 or 16-inch wheels, a 10.4Ah battery, air tires, rear-wheel drive, front/tail lights, a quick-folding frame, and a drum brake, gyroscope. The bike can operate in three modes: pedaling without electric assist, pedaling with electric assist, and 100% electric.
Parameters (27)
Settings (32)
Fitrider M2 eBike
Flespi parses telemetry data from your Fitrider M2 eBike into a standardized JSON and lets you send commands to Fitrider M2 eBike via API.
    "device.type.id": "Fitrider M2 eBike",
    "protocol.id": "fitrider"
How to send commands to Fitrider M2 eBike?
total.trip.duration
Total trips duration
A28. Alarm buzzer
alarm_buzzer
A53. Set APN settings
user: Username
A62. Battery lock
battery_lock
A60. Battery unlock
battery_unlock
A71. Chainlock unlock
chainlock_unlock
A5. Clear single riding mileage
clear_single_mileage
A7. Clear single riding time
clear_single_time
A9. Clear total riding mileage
clear_total_mileage
A11. Clear total riding time
clear_total_time
A73. Enter pause mode
enter_pause
A75. Exit pause mode
exit_pause
A101. Set IOT parameters
iot_params
ip: Server IP address
port: Server port
user: Username
A104. Modify IOT SN
iot_serial
sn: IOT serial number
A43. Lamp mode setting
lamp_mode
Used to set speed unit as kilometers/miles on display
A37. Lamp switch setting
lamp_switch
switch: Off/On
A107. Motor lock
motor_lock
A105. Motor unlock
motor_unlock
A3. Power OFF
power_off
A1. Power ON
power_on
A97. Query $G signal intensity
query_4g_signal
A83. Query status of chain lock
query_chainlock_status
A18. Query GPS location data
query_gps
A21. Query hardware and firmware version
query_hw_fw
A24. Query IMEI number
query_imei
A77. Query IOT Log
query_iot_log
A15. Query vehicle parameters
query_params
A35. Query server parameters
query_server_params
A20. Reboot IOT
A33. Set server parameters
server_params
port: Server port
times: Times of repeat packets
heartbeat: Heartbeat packet interval
veh_number: Vehicle number
rep_interval: GPS reporting interval
A58. Special alarm buzzer
special_alarm_buzzer
i: Time of buzzer ring
l: Time of that the buzzer does not sound
v: Number of rings
A13. Set the speed limit data
speed_limit
speed: Speed limit value
A39. Vibration sensitivity setting
vibration
sensitivity: Vibration sensitivity level
