Hikvision AE-DI5052-G40 PRO
Hikvision AE-DI5052-G40 PRO is a vehicle industry dashcam that records up to 5 channels of video: 2 built-in channels (1620P front camera, 1080P rear camera with IR) plus 3 extension channels. It has a built-in 4G LTE module with dual Nano SIM slots, a Wi-Fi module that can act as an access point, and a Bluetooth module for third-party sensors. GPS, GLONASS and Galileo positioning lets it overlay time and speed on video. Interfaces include CAN, RS-232, 2 alarm inputs and 3 steering signal inputs. It stores video on two Micro-SD cards of up to 1 TB each. A 6-axis G-sensor locks emergency video after a collision. It supports ADAS, driver status monitoring, driver authentication, people counting and sentry mode, and runs on 12 V or 24 V vehicle power.
Parameters (163)
Settings (39)
Commands (9)
Flespi parses telemetry data from your Hikvision AE-DI5052-G40 PRO into a standardized JSON and lets you send commands to Hikvision AE-DI5052-G40 PRO via API.
    "device.type.id": "Hikvision AE-DI5052-G40 PRO",
    "protocol.id": "hikvision"
How to send commands to Hikvision AE-DI5052-G40 PRO?
Additional info ID 0x67
adas.blindspot.side
Additional info ID 0x65,
Additional info ID 0x66,
Additional info ID 0x67,
Additional info ID 0x68,
Additional info ID 0x70,
Message ID 0x1212
brake.status
Brake status
driver.card.reading.error
Driver card reading error
Message ID 0x0702
Message ID 0x0702
Message ID 0x0702
driver.registration.status
Driver registration status
Message ID 0x0702
driving.alarm.bitmask
Additional info ID 0x18
Additional info ID 0x18,
Alarm/Event type 7 of Additional info ID 0x65
dsm.fatigue.degree
Additional info ID 0x04,
Message ID 0x0301,
Additional info ID 0xB1
harsh.turn.event
Harsh turn event detected
media.filename
Multimedia file name
Message ID 0x1211,
Message ID 0x1212
media.filesize
Multimedia file size
Message ID 0x1211,
Message ID 0x1212
Message ID 0x1211,
Message ID 0x1212
memory.fault.status.bitmask
Additional info ID 0x17
passengers.in.count
Additional info ID 0xAB
passengers.out.count
Message ID 0x0F00...0x0FFF
Message ID 0x0702,
Message ID 0x1212
tire.error.status
Tire status error
tire.leak.status
Tire leak detected
tire.overpressure.status
Tire overpressure
tire.underpressure.status
Tire underpressure
upgrade.status.name
Upgrade status
Message ID 0x0108
upgrade.type
Upgrade type
Message ID 0x0108
video.alarm.bitmask
Video alarm flags bitmask
Additional info ID 0x14
Additional info ID 0x16
Additional info ID 0x15
Blocked alarms
alarm_blocked
Alarms the device does not report at all
sos: Emergency
crash: Crash
route: Route
theft: Vehicle theft
danger: Risk warning
geofence: Geofence
rollover: Rollover
power_cut: Failure of main power supply
fuel_level: Fuel level
route_time: Route driving time
battery_low: Low voltage of main power supply
lcd_failure: Display malfunction
vss_failure: VSS malfunction
gnss_failure: GNSS module malfunction
overspeeding: Overspeed
parking_time: Parking time over the threshold
speed_warning: Speed warning
camera_failure: Camera malfunction
fatigue_driving: Fatigue driving
route_deviation: Route deviation
illegal_ignition: Illegal ignition
illegal_movement: Illegal movement
cumulative_driving: Accumulated driving time of the same day
tts_module_failure: TTS module malfunction
ic_card_module_failure: IC card module malfunction
unauthorized_door_open: Door opened without authorization
driving_recorder_failure: Driving recorder malfunction
gnss_antenna_disconnected: GNSS antenna disconnected
gnss_antenna_short_circuit: GNSS antenna short circuited
Key alarms
alarm_key
Alarms the device treats as the key ones
sos: Emergency
crash: Crash
route: Route
geofence: Geofence
rollover: Rollover
Alarms triggering the camera
alarm_photo
sos: Emergency
crash: Crash
route: Route
geofence: Geofence
rollover: Rollover
Alarm photos kept on the device
alarm_photo_stored
Alarms whose photos are stored on the device instead of being uploaded right away
sos: Emergency
crash: Crash
route: Route
geofence: Geofence
rollover: Rollover
Special alarm recording
alarm_recording
duration: Maximum duration
Alarms reported by SMS
alarm_sms
sos: Emergency
crash: Crash
route: Route
geofence: Geofence
rollover: Rollover
username: Username
backup_name: Backup name
Continuous driving time limit
continuous_driving_time
Daily driving time limit
daily_driving_time
Driving time accumulated during the same day
Default report distance interval
default_distance_interval
distance: Distance
Default report interval
default_interval
Dormancy report distance interval
dormancy_distance_interval
distance: Distance
Dormancy report interval
dormancy_interval
Emergency report distance interval
emergency_distance_interval
distance: Distance
Emergency report interval
emergency_interval
Terminal factory reset
factory_reset
Fatigue driving warning difference
fatigue_warning_difference
How long before the continuous driving time limit the device starts to warn about the coming fatigue alarm
Geofence radius
geofence_radius
Irregular displacement threshold
radius: Radius
Heartbeat interval
heartbeat
Highest speed
highest_speed
Maximum parking time
max_parking_time
Video & Audio attributes
media_attributes
audio_codec: Audio codec
video_codec: Video codec
Minimum rest time
min_rest_time
Report distance interval without driver login
no_driver_distance_interval
distance: Distance
Report interval without driver login
no_driver_interval
Vehicle odometer
mileage: Mileage
Overspeed duration
overspeed_duration
Overspeed warning difference
overspeed_warning_difference
How much below the highest speed the device starts to warn about the coming overspeed alarm
Report scheme
report_scheme
Condition the device uses to choose the reporting interval
Report strategy
report_strategy
Terminal reset
Server
address: Server address
tcp_port: TCP port
Sleep and wake-up mode
sleep_wakeup
timed_wakeup: Timed wake-up
manual_wakeup: Manual wake-up
stream_parameters
bitrate: Bitrate
frame_rate: Frame rate
resolution: Resolution
audio_output: Audio output
encoding_mode: Encoding mode
Timed photo
timed_photo
ch1: CH1 enabled
ch2: CH2 enabled
ch3: CH3 enabled
ch4: CH4 enabled
ch5: CH5 enabled
unit: Interval unit
ch1_upload: CH1 upload
ch2_upload: CH2 upload
ch3_upload: CH3 upload
ch4_upload: CH4 upload
ch5_upload: CH5 upload
Turn point angle
turn_angle
Heading change that makes the device report an extra position
Blocked video alarms
video_alarm_blocked
bus_overload: Bus overload
Video analysis alarm
video_analysis_alarm
Check terminal parameter
{"message_id":"8104"}
alarm_id: Alarm ID
Send message to driver
notify_driver
text: Message
type: Message type
speak: Read aloud
urgent: Urgent
display: Show on the screen
encoding: Text encoding
storage_type: Storage type
Start audiostream
start_audiostream
Start audio stream session
type: Audio mode
quality: Quality
