Jointech JT701D
Jointech JT701D is an intelligent 4G GPS tracking smart lock for asset management. The device features lock status security, unlocking with RFID/remote password, 9 alarm types, 10 polygonal geofences, 15,000mAh battery, IP67 waterproof casing, dual SIM support, data encryption, and more. JT701D can be connected with the sub-locks to monitor multi valve vans.
Parameters (56)
Settings (23)
Jointech JT701D
Flespi parses telemetry data from your Jointech JT701D into a standardized JSON and lets you send commands to Jointech JT701D via API.
    "device.type.id": "Jointech JT701D",
    "protocol.id": "jointech"
How to send commands to Jointech JT701D?
Data type
back.cap.closed.status
Back cap closed status
Device status
back.cap.open.alarm
Back cap open alarm
Device status
Report type P01
Device status
JT709 sensor data
Report type P01
Report type P14,
Report type P45
Report type P45
Report type P45
geofence.in.alarm
Geofence in alarm event
Device status
geofence.out.alarm
Geofence out alarm event
Device status
Report type P68
Report type P68
Data type
motor.fault.alarm
Motor fault alarm
Device status
motor.locked.status
Motor locked status
Device status
password.correct
Entered correct password
Report type P45
password.incorrect.attampts
The number of incorrect attampts to enter password
Report type P45
JT709 sensor data,
Report type P45
JT709 sensor data,
Report type P45
JT709 sensor data,
Report type P45
JT709 sensor data,
Report type P45
JT709 sensor data,
Report type P45
P45 Event source type
Report type P45
steel.string.connected.status
Steel string inserted status
Device status
steel.string.cut.alarm
Steel string cut alarm
Device status
JT709 sensor data,
Report type P45
Device status
unlock.alarm
Unlock alarm
Device status
unlock.valid.status
Unlock passed validation
Report type P45
vehicle.id
Vehicle ID connected with the device
Report type P45
Device status
wrong.password.alarm
Wrong password alarm
Device status
Alarm switch
alarm_switch
cut_off: Lock sling cut off alarm
unlocking: Unlocking alarm
vibration: Vibration alarm
low_battery: Low battery alarm
motor_fault: Motor fault alarm
exit_geofence: Exit Geofence alarm
open_back_cap: Open back cap alarm
enter_geofence: Enter Geofence alarm
unauthorized_rfid: Swipe unauthorized RFID card alarm
wrong_remote_command: Alarm by wrong remote command input 5 times continuously
Auto-Lock Time
auto_lock_time
Set auto-lock time when device is unlocked but lock rope is not pulled. Valid range: 1-10 minutes.
time: Time
Change the Unlocking Password
change_password
new_password: New password
old_password: Old password
Query Firmware Version
firmware_version
Read-only setting to query device firmware version. Sends P01 command to device. Firmware version is stored in settings. Battery level is registered as telemetry message only (dynamic value).
version: Firmware Version
Data Uploading Time and wake up time intervals
interval
upload: Upload interval after wake up
wake_up_time: Wake up time interval in sleep mode
Low Battery Alarm Threshold
low_battery_threshold
Set low battery alarm threshold as percentage. Valid range: 0-90%.
Awaken command by Message & calling command setting
message_calling_awaken
switch: Enable/Disable
Motion Detection Threshold
motion_detection_threshold
Set G-sensor motion detection threshold in milligravity (mg). Value 0 disables motion detection. Valid range: 0 or 63-500 mg.
VIP Phone Number 1
phone1
number: Phone Number
VIP Phone Number 2
phone2
VIP Phone Number 3
phone3
VIP Phone Number 4
phone4
VIP Phone Number 5
phone5
Power switch
power
Restart Device
Reporting Intervals for Locked/Unlocked
reporting_intervals
Set different reporting intervals for locked and unlocked states. When enabled, overrides the standard P04 upload interval. Valid range: 5-600 seconds for both intervals.
locked_interval: Locked Interval
unlocked_interval: Unlocked Interval
SIM1 IP Port and GPRS network parameters
sim1
SIM2 IP Port and GPRS network parameters
sim2
Query SIM ICCID
sim_iccid
Read-only setting to query SIM card ICCID. Sends P68,2,0 command to device. Response is stored in settings and registered as telemetry message.
iccid: ICCID
Query SIM IMSI
sim_imsi
Read-only setting to query SIM card IMSI. Sends P68,1,0 command to device. Response is stored in settings and registered as telemetry message.
imsi: IMSI
Unlock the device remotely
unlock
password: Unlock Password
Vibration Alarm Threshold
vibration_alarm_threshold
Set vibration alarm threshold in milligravity (mg). Value 0 disables vibration alarm detection. Valid range: 0 or 126-8000 mg. Note: Must be greater than motion detection threshold (P37).
Remote Unlock JT709 Sub-Lock
wlnet_unlock
Remotely unlock a JT709 sub-lock via LoRa. Requires JT709 sub-lock to be bound to the device. The sub-lock must be awake (blue LED blinking) to receive the command. Effective time should not exceed 5 minutes. Response confirms command received by device (not actual unlock). Actual unlock confirmation comes via WLNET,5 event data.
lock_id: Sub-Lock ID
effective_minutes: Validity (minutes)
Restart the device remotely
{"text":"(P15)"}
Make the device turn to sleep mode
{"text":"(P32)"}
