MettaX MC904P
MettaX MC904P is a 4G AI-enabled MDVR that supports 4 channels of 1080P AHD video input plus 1 IP camera. It features large storage capacity with one 1TB SSD and one 512GB SD card. The device has an aluminum alloy shell for excellent heat dissipation and supports emergency alarm function, 4-channel digital signal input, 1-channel digital signal output, and 2 RS232 serial ports for connecting peripherals. Built-in AI algorithms include ADAS (Advanced Driver Assistance System), DMS (Driver Monitoring System), and BSD (Blind Spot Detection) to enhance transportation safety and reduce accidents. The device operates on LTE/WCDMA/GSM networks and includes WiFi connectivity for comprehensive fleet monitoring and management.
Parameters (131)
Settings (15)
Commands (8)
MettaX MC904P
Flespi parses telemetry data from your MettaX MC904P into a standardized JSON and lets you send commands to MettaX MC904P via API.
    "device.type.id": "MettaX MC904P",
    "protocol.id": "mettax"
How to send commands to MettaX MC904P?
Additional info ID 0x64,
Additional info ID 0x67
adas.blindspot.side
Additional info ID 0x65,
Additional info ID 0x67,
Message ID 0x1212
brake.status
Brake status
driver.card.reading.error
Driver card reading error
Message ID 0x0702
Message ID 0x0702
Message ID 0x0702
driver.registration.status
Driver registration status
Message ID 0x0702
driving.alarm.bitmask
Additional info ID 0x18
Additional info ID 0x18,
dsm.fatigue.degree
Additional info ID 0x04,
Message ID 0x0301,
media.filename
Multimedia file name
Message ID 0x1211,
Message ID 0x1212
media.filesize
Multimedia file size
Message ID 0x1211,
Message ID 0x1212
Message ID 0x1211,
Message ID 0x1212
memory.fault.status.bitmask
Additional info ID 0x17
Message ID 0x0F00...0x0FFF
Message ID 0x0702,
Message ID 0x1212
upgrade.status.name
Upgrade status
Message ID 0x0108
upgrade.type
Upgrade type
Message ID 0x0108
video.alarm.bitmask
Video alarm flags bitmask
Additional info ID 0x14
Additional info ID 0x16
Additional info ID 0x15
username: Username
backup_name: Backup name
Default report interval
default_interval
Dormancy report interval
dormancy_interval
Emergency report interval
emergency_interval
Terminal factory reset
factory_reset
Heartbeat interval
heartbeat
Highest speed
highest_speed
Video & Audio attributes
media_attributes
audio_codec: Audio codec
video_codec: Video codec
Vehicle odometer
mileage: Mileage
Overspeed duration
overspeed_duration
Report strategy
report_strategy
Terminal reset
Server
address: Server address
tcp_port: TCP port
udp_port: UDP port
Timed photo
timed_photo
ch1: CH1 enabled
ch2: CH2 enabled
ch3: CH3 enabled
ch4: CH4 enabled
ch5: CH5 enabled
unit: Interval unit
ch1_upload: CH1 upload
ch2_upload: CH2 upload
ch3_upload: CH3 upload
ch4_upload: CH4 upload
ch5_upload: CH5 upload
Check terminal parameter
{"message_id":"8104"}
alarm_id: Alarm ID
storage_type: Storage type
Start audiostream
start_audiostream
Start audio stream session
type: Audio mode
quality: Quality
resolution: Resolution
